Old 01-29-2013, 03:09 AM   #1
Tony T OP
Oddometer: 1,429
21" Front Wheel in 1980 XL250S
Hi folks, would anyone know if there's a 21" front wheel that will go pretty much straight into an XL250S that has a 23" wheel normally?
Thanks in advance for any words of wisdom..
Tony T is offline   Reply With Quote
Old 01-29-2013, 08:50 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
Could you not just but a new 21" rim and have it laced on?
Rob Farmer is offline   Reply With Quote
Old 01-29-2013, 10:53 AM   #3
jellycow
Back on track!
jellycow's Avatar
Oddometer: 851
What would be the fun in that?
I seem to recall the later ones (eg XL125S,) have the same drum so it should fit. I had a XL125S a few years ago and had a 23" wheel laying around, they looked the same to me but I never did any measurements or anything so might be a near mis...
I'll let the final verdict to the guys who actually know this, it might be worth investigating.
[Sir Mix-a-lot mode] I like big tanks and I can not lie [/Sir Mix-a-lot mode]
R100GS rescue: only the brave put it on hold for now
Workshop credo: if it ain't broke, fix it till it is.
jellycow screwed with this post 01-29-2013 at 11:55 AM
jellycow is offline   Reply With Quote
Old 01-29-2013, 08:55 PM   #4
redprimo
Oddometer: 403
I think a front wheel from a 78 cr will bolt right up and uses the same brake drum tab on the forks, I'm not 100% sure so double check that thats the year.
redprimo is offline   Reply With Quote
Old 01-31-2013, 02:34 AM   #5
gkam
gkam's Avatar
Oddometer: 68
I think the front wheel from the XL 250 R is the same.
gkam is offline   Reply With Quote
Old 02-03-2013, 05:06 PM   #6
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,578
I assume you want to chainge the wheel because you are having trouble finding tyres.
From what I have seen speedway bikes use a 23" front wheel, will tyres made for them work?
tEAM iDIOT.
"Far to the general now, and without great final hope of victory, he has nothing to lose. And it must above all have rabies. For the moment, it dominates this special."
Joan Barreda
tHEtREV is offline   Reply With Quote
Times are GMT -7.   It's 06:21 PM.
