02-08-2011, 05:47 PM
#1 |
Oddometer: 22
K75 won't Start
Need a little help, my trusty 1992 K75 would not start yesterday, here’s what I have checked.
· Battery: great shape, cranks the engine like a banshee. · Fuel: Filter changed last year, tank nice and clean, good gas. · Plugs: four months old gaped properly. · Kill switch in correct position. SO, I pulled a plug and the plug had fuel on it, though I may have flooded it; however, I grounded the plug against the engine and cranked her over….yep… no spark. Checked engine ground that was good, checked the other plugs and they too would not spark. So that leaves the coils or the ignition control unit. My money’s on the ignition control unit; however, is there something I’m missing, something really simple? Many thanks in advance.
During Prohibition, sometimes I was forced to live for days on nothing but bread and water. (W.C. Fields)
02-08-2011, 05:55 PM
#2 |
Red Clay Halo
Oddometer: 11,163
Does this bike have clutch and sidestand safety switches?
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
02-08-2011, 07:17 PM
#3 |
Oddometer: 1,459
If the plugs in a K-Bike are wet with fuel, they often will not spark. Try it again with a fresh plug or a screwdriver in the cap. Use sensible precautions.
What was the ambient temperature? |
02-08-2011, 11:05 PM
#4 |
BMW uber alles!
Oddometer: 969
Boon Boon read my mind........had the same problem one time...
=Zagando= 1994 BMW K75S 2003 Honda Ruckus Recent K75S renovation: www.tinyurl.com/njaltf ex: '92 R100GSPD '85 K100RS '73 R75/5 '65 R60/2 |
02-09-2011, 01:09 PM
#5 |
Old Fart
Oddometer: 877
When it gets close to freezing, the K75 will flood at starting. If you have a fully charged battery, you can try this: Hold the throttle almost full. While holding the throttle, with your left hand push and hold the starter button. While cranking slowly close the throttle. If it starts firing, hold the throttle there and keep on running the starter until the engines runs clean. Unless it is super flooded, this will work. Next time for starting in cold weather hold the throttle a bit open while you crank.
02-09-2011, 02:34 PM
#6 |
Oddometer: 2,291
You can't even turn the starter over with either of those going on, so that's not the issue.
1974 BMW R90 /6 1968 Bultaco Matador MK3 1973 BMW R75 /5 Toaster LWB 1969 Bultaco Bandido MK2 2012 Husqvarna Terra TR650 |
02-09-2011, 05:25 PM
#7 |
Oddometer: 22
Yes, the bike does have clutch and side stand safety switches; also, although my bike is in the garage it was very cold. I work long hours so I will try Paul Mihalka starting method asap. Dirty or broken switches??? Many thanks guys.
02-10-2011, 05:10 PM
#8 |
Oddometer: 1,536
This is why Airheads, points ignition and carbs are so popular. You can actually fix the MFer.
02-11-2011, 05:12 PM
#9 | |
Oddometer: 22
![]() Well, grounded a new plug and no spark at the plugs, any ideas other than the ignition module? Thanks.
02-11-2011, 05:27 PM
#10 | |
iron butt'r
Oddometer: 28
02-14-2011, 06:01 PM
#11 |
Oddometer: 22
Checked the coils with my meter, they read correctly according to my manual; however, the plug wires show no continuity; how is this possible? All three wires show an open circuit, the wires should read 1 ohm max. What gives?
02-14-2011, 06:05 PM
#12 | |
Red Clay Halo
Oddometer: 11,163
...but since you have no spark, maybe your wires are shot.
02-14-2011, 06:55 PM
#13 |
Carbon-Based Humanoid
Oddometer: 2,712
I'm not a guru in the mechanical arts but I once had a K100RT that would not start, intermittently. Turned out to be the ignition/key switch--just needed a cleaning.
08 GS ● 02 KLR ● 12 WR250R ● 04 KDX200 ● 00 VFR |
02-15-2011, 04:27 AM
#14 | |
Von Hochstaden's son
Oddometer: 44,967
Check your ignition switch it might be dirty.
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
02-21-2011, 02:53 PM
#15 |
Oddometer: 22
Well I broke everything down, disconnected everything from the plugs to the ignition module, switch, battery, load shedding relay, you name it it came apart and was cleaned and put back together. I did not notice anything that was dirty or loose; however, after I put it all back together she fired-up on the first try and ran like she was new, I don't understand it but I'm not going to look a gift horse in the mouth, thanks for all the help.
