Old 01-30-2013, 09:24 AM   #16
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,825
A quck search cannot locate a 10 x 180mm bolt above metric grade 8.8 (5). I have my bike on the rack right now, just installed a relocator and a bash plate- it'd be SO EASY just to replace the bolt in question.
Alas....
2011 White 990 Adv S
2014 500EXC Black
FakeName screwed with this post 01-30-2013 at 09:39 AM
FakeName is online now   Reply With Quote
Old 01-30-2013, 09:33 AM   #17
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,970
I go to a metric land (Aus) next week for a 6 weeks or so, I am sure I can find one there.
When it broke it just let go with a bang. I could even find the end with the nut on it.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 01-30-2013, 11:28 AM   #18
RoundOz
Plenty of seasoning
Oddometer: 1,014
Fastenal
Fastenal has several M10x1.5x180 hex head listed. Grade 10.9 (SAE 8). Also threaded rod in grade 10.9, but only in 1m lengths.
Grainger has a socket head M10 Grade 12.9...$23.61 for pack of 5. item number 6CU50
Thanks for the heads up...will be keeping an eye on mine, or if you order a pack I would gladly buy a couple from you.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 01-31-2013, 08:27 AM   #19
ciedema OP
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Well the BDCW guys have offered to replace the bolt. Very, very good of them. Not what I expected or requested. Especially as I said in the first post, that I don't consider the breakage to be a product fault.
Great guys.
Old 02-05-2013, 09:09 AM   #20
what car??
down the road
Oddometer: 372
Best solution of them all that I{ve read, get a CJ Designs side stand relocator. Burly and does not involve the engine bolts at all. Best design out there!!!
what car?? is offline   Reply With Quote
Old 02-05-2013, 09:40 AM   #21
charlie264
charlie264's Avatar
Oddometer: 8,326
Best design is on the 950RR.
Old 02-05-2013, 11:24 AM   #22
charlie264
charlie264's Avatar
Oddometer: 8,326
Originally Posted by MortimerSickle View Post
I am not too familiar with the BD bracket, but if this bolt goes into the engine case, I wouldn't want a stronger bolt.
Correct.
Old 02-05-2013, 04:14 PM   #23
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,004
Originally Posted by charlie264 View Post
Correct.
Why?, all it offers is a higher sheer strength which is what Craig is looking at, I can't see why that would be a bad thing as it will cause no other trouble.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is online now   Reply With Quote
Old 02-05-2013, 05:40 PM   #24
charlie264
charlie264's Avatar
Oddometer: 8,326
Because it’s the flexing of the plate acting on the bolt, not the bolts lateral strength. Think iron vs steel.
Old 02-05-2013, 05:53 PM   #25
charlie264
charlie264's Avatar
Oddometer: 8,326
Given enough stress, something will break: broken bolt- $2.00, broken engine case-$5000
Yep. Bust bolt, replace. Irrespective of material hardness the bolt will be under the same tension, harder steel is more susceptible to bend fatigue, but is also more resistant to bend. It’s all a compromise, the KTM design is stupid hence look at the 950RR. Its side stand is welded to the frame.
charlie264 screwed with this post 02-05-2013 at 06:02 PM
Old 02-05-2013, 09:02 PM   #26
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,004
Would you like more elastic with that story .. a little over the top comparison.
How about bolt done up properly with no flex allowed between casings, mounts and bolts, I little less dramatic.
Old 02-06-2013, 09:17 AM   #27
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,822
Two moto Kiwis,
I would think that with all the trouble you've had with your new KTM, you wouldn't be so quick to dismiss this. If you break a case, as many have, we don't want to hear that it was the fault of the seller or improper installation.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 02-06-2013, 10:22 AM   #28
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,004
Originally Posted by brents347 View Post
Two moto Kiwis,
Cool with that and not dismissing anything, but it has to be kept in perspective too.
I am not dismissing anything as we have the same kit on ours so my eyes are open but from an engineering perspective a nice snug bolt that takes out any amount of flex is not a bad thing, not trying to upset anyone (which seems to be easy here for some reason) just keep it in perspective.
As noted above, everything is a compromise so nothing it perfect and it doesn't matter who makes what there is usually room for improvement and this only comes from gear being used in the field.
Great news BDCW stepped up to offer Craig a new bolt, excellent service to say the least
Old 02-06-2013, 11:30 AM   #29
charlie264
charlie264's Avatar
Oddometer: 8,326
I don’t think you’re getting it; the long bolt goes through the two halves of the engine cases with the paper gasket that sits in-between. You can put a super high tensile bolt in, above 12.9 and torque it up as much as you want, result will overload on the ally parts which will cause damage, with the inevitable loads it will fail and go off like bullet.
Tighten the wheel bolts on your car to 4x the recommended torque; the bolts will take that load stationary with no problem. Start driving like that and the wheels will snap the studs off and pass you on the road.
Old 02-06-2013, 11:51 AM   #30
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,004
I don’t think you’re getting it.
Actually I get it totally, I am not saying over torque it at all .... NOT once have I suggested that FFS and yes I know where it goes.
I won't bother any more, you seem to want to belittle anything I say so yeap it is all yours ... hope you are happy now.
Craig sorry your thread turned into a pissing match of others trying to twist my words and make suggestion of me trying to do you wrong.
Times are GMT -7.   It's 06:48 PM.
