01-30-2013, 12:09 PM
#1 |
Motodetailistic functioni
Oddometer: 1,316
Turn signal button fix
Anyone have a recommendation for fixing a broken button? Bike is a 2002 Honda XR650L.
![]() The unit is fully functional but the button is broken. When I actuate the signal the sharp metal tab rips a layer on my glove. A friend has used a product called liquid plastic but I'm unsure if it'll work. I'm still on the search for a fix but thought I'd add a post for suggestions. Thanks. prince_ruben screwed with this post 01-30-2013 at 12:23 PM |
01-30-2013, 12:17 PM
#2 |
Where fun goes to die....
Oddometer: 3,149
If an older bike I would look for a used switch pod if in good condition swap it out, if not just swap out the broken bit.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
01-30-2013, 01:42 PM
#3 |
Maybe some of that plastic dip stuff?
01-30-2013, 01:53 PM
#4 |
pistolero
Oddometer: 1,177
I'd go down to the hardware store or parts store and pick up a tube of that Quick Steel. It is soft so you can form it and I would reform the end of the button the way I wanted it. You could even file some little groves in it like the original.
84 Honda Goldwing (GL1200) 03 XR650L |
01-30-2013, 04:26 PM
#5 |
Oddometer: 7,984
I have a switch assy that has a bad hi/low rocker but the turn switch is still good. You want?
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
01-30-2013, 07:03 PM
#6 |
Oddometer: 1,316
01-30-2013, 07:46 PM
#7 |
Oddometer: 668
I saw on another thread where someone had the same problem. He found a key from an old computer keyboard that fit perfectly.
01-31-2013, 09:36 AM
#8 |
Oddometer: 1,316
