Old 02-01-2013, 10:54 AM   #16
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,014
It is not just the rubber o-rings that hold the link on. That wouldn't last very long. :-)
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 02-01-2013, 03:17 PM   #17
Kronhjort OP
Oddometer: 5
Now I feel stupid. I press the plate on. But what keep the plate from sliding off? Is it really enough to just press it on? When I use a rivet link the tool expand the end of the pins so the plate can't come off. My guess was that the o-rings kept the plate from coming off.
I hope you undestand my Swedish English.
Kronhjort is offline   Reply With Quote
Old 02-01-2013, 04:44 PM   #18
P B G
Oddometer: 10,001
Originally Posted by Anorak View Post
Look up Hi-Lock fasteners, they hold a lot of the airframe together on commercial aircraft. The nut shears off at a specific torque. These look very similar.
That's what it looks like to me as well.
Similar to pop-riveting, the central core looks like it is "weakened" so that it snaps precisely when it is tensioned appropriately.
Hence I would not recommend using a caliper to measure the link, as if this is the case the product is engineered to be run till it cracks off.
Old 02-05-2013, 02:23 PM   #19
GISdood
GISdood's Avatar
Oddometer: 856
Originally Posted by It'sNotTheBike View Post
If he had done so, which took me all of 20 seconds, he would have come up with
at least these search returns, and perhaps more :
http://www.r1-forum.com/forums/showthread.php?t=234825
http://www.svrider.com/forum/showthread.php?t=46043
Ever think that he - like myself - might give more weight to recommendations based on first-hand use from inmates here instead of anonymous interweb folks? Cut him some friggin slack, we were all noobs once.
GISdood is offline   Reply With Quote
Old 02-06-2013, 01:38 PM   #20
rkover1
doc
rkover1's Avatar
Oddometer: 195
Originally Posted by Yossarian™ View Post
Just curious, have you used them in applications where the chain goes through a chain guide under the swingarm, as it feeds onto the rear sprocket?
On my 2006 BMW F650GS, they do stick out far enough to interfere with the Touratech chain guide. I haven't bothered with trying to file them down shorter. In the meantime, the chain guide is lying on my bench.
doc
Ua mau ke ea o ka aina i ka pono
rkover1 is offline   Reply With Quote
Old 02-06-2013, 01:45 PM   #21
motorat
TBD
motorat's Avatar
Oddometer: 927
i prefeer the rivet link.
the cycle gear had a sale on the tool that is used to break the chain and install the new rivet.
i would be concerned that the screw link might be a little wide.
just my opinion.....YMMV.
welcome to the forum.
to ignore the facts does not change the facts
motorat is offline   Reply With Quote
Old 02-06-2013, 01:47 PM   #22
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,670
doc
Thank you for the information; it confirms what I had suspected.
Times are GMT -7.   It's 01:53 AM.
