Old 01-31-2013, 08:58 AM   #1
buzybraza OP
buzybraza's Avatar
Oddometer: 380
airbox deleted 950SE
So, I decided to get rid of the airbox on my 2008 950SE with about 7k miles.
This is what I removed:
An inmate here sent me an aluminum base plate, which I used as a template to make my own:
Then I cut the trumpets to fit inside the “sausage” JC30 from ITG. I probably cut too much off…
Plate mounted on the bike:
Filter on:
Ready to run:
How does it run? Like a bat out of hell !!! It is a kick ass setup for power! Not as good for dust protection or submarine capabilities!
Jetting:
Factory Pro needles in the second position.
175 mains
Mixture screws at 2.5 turns out
The rest is stock.
buzybraza screwed with this post 01-31-2013 at 12:30 PM Reason: more info
buzybraza is offline   Reply With Quote
Old 01-31-2013, 10:08 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,948
Correct me if wrong, but in the way you have cut the trumpets, their tops will be pressed against the underside of the filter. Maybe this reduces a fair bit the breathing?
Old 01-31-2013, 10:52 AM   #3
buzybraza OP
buzybraza's Avatar
Oddometer: 380
No, the reason I cut the trumpets is so they don't touch the filter.
At the closest spot to the inside of the filter cage there is about 15mm clearance between the trumpet and the filter.
And trust me on this one, the bike is not breathing any less than it was before with the airbox!
buzybraza screwed with this post 01-31-2013 at 12:31 PM Reason: more info
Old 01-31-2013, 11:43 AM   #4
mousitsas
mousitsas's Avatar
Oddometer: 2,948
According to my measurements, the clearance between the trumpets and the seat pan on the SE is about 25mm, the filter itself is about 20mm thick, so how is this possible?
I am also thinking that maybe a bigger plate (wider and longer) would help to totally eliminate the flow of hot air from the engine underneath (if any).
mousitsas screwed with this post 01-31-2013 at 11:52 AM
Old 01-31-2013, 11:53 AM   #5
buzybraza OP
buzybraza's Avatar
Oddometer: 380
Your measurements could be wrong, as mine could also be wrong. I did not do any kind of precisely scientific measurements I did it "by feel". I am happy with my setup. My trumpets do not contact the airfilter and there is space between the two. Thanks for your opinion!
Old 01-31-2013, 11:55 AM   #6
mousitsas
mousitsas's Avatar
Oddometer: 2,948
You are welcome! I am also thinking to do the same, but this trumpet thing has put me off so far...
Old 01-31-2013, 12:02 PM   #7
buzybraza OP
buzybraza's Avatar
Oddometer: 380
Yes, I did not like the idea of cutting mine either. That is why I tried to cut as little as possible. Some other folks have done the cut differently, just a straight cut at 1 inch measured from the bottom of the trumpets. This way both trumpets are the same. I don't know... if I eventually feel anything funky I can always cut more and even it out. I only have a couple days riding this new setup. Time will tell....
Old 01-31-2013, 12:03 PM   #8
bigkuri
bigkuri's Avatar
Oddometer: 842
Looks really good!
What would happen if you built up a plastic "curtain wall" around the whole thing, that goes up a few inches in order to preserve some wading depth of the bike?
If deep fording then the bike is moving; bow wave, so most of the water height is on that leading edge, and I think there is plenty of clearance, so the plastic wall could theoretically be similar height to the snorkel?
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Old 01-31-2013, 12:13 PM   #9
buzybraza OP
buzybraza's Avatar
Oddometer: 380
Originally Posted by bigkuri View Post
Looks really good!
Obviously, there are lots of things that can be done, but at that point I would just put the stock airbox back on. I only did this mod because it was easy to do, just a flat piece of 3mm thick aluminum.
Also I live in southern California, mostly desert. Even if I were to do deep water crossings, I still think my setup is going to be more "waterproof" than most dirt bikes anyways......
Old 02-01-2013, 04:42 AM   #10
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Congrats
Sporting Wood is offline   Reply With Quote
Old 02-01-2013, 04:57 AM   #11
charlie264
charlie264's Avatar
Oddometer: 8,366
I've got a feeling that the RC8 and S Duke velocity stacks are shorter than stock SE, seem to remember someone upgraded the Adv/SE for RC8 ones.
Might be worth a look,
Old 02-01-2013, 05:54 AM   #12
KarimADV
Oddometer: 67
What about if you find some kind of water? I mean a river crossing or a offroad dirt?
Won't you kill your engine with this setup?
KarimADV is offline   Reply With Quote
Old 02-01-2013, 08:43 AM   #13
buzybraza OP
buzybraza's Avatar
Oddometer: 380
I don't think so. I believe my intake is still higher up than most dirt bikes with airboxes under your butt. Plus as I said in post #9 river crossing are not my concern.
As for off-road dirt (I think you mean dust) you are right, I am not as protected against dust. That is why I will be running an oiled filter skin over the air filter even though I use my 950 on the asphalt.
If water or dust were a big concern for me I would NOT have done this modification.
Old 02-01-2013, 08:44 AM   #14
buzybraza OP
buzybraza's Avatar
Oddometer: 380
Originally Posted by Sporting Wood View Post
Congrats
Old 02-01-2013, 08:48 AM   #15
KarimADV
Oddometer: 67
I was meaning mud ( sorry but english is not my motherlanguage ) but you answered anyhow :)
Times are GMT -7.   It's 04:46 PM.
