Old 09-19-2012, 12:16 AM   #1
TouratechUSA OP
Made For Adventure
TouratechUSA's Avatar
Oddometer: 473
Touratech USA: GPS mounts
Greetings ADV,
We will be highlighting and describing our GPS mounts and bike-specific adapters
We welcome any and every question or inquiry.
Touratech USA ADV Vendor Thread:
ADV Vendor Thread
Free shipping on select Klim Gear
(Taken automatically at checkout. Free ship valid for whole order if combined w/ non-Klim products)
Under construction.
Thanks, TT USA
TouratechUSA screwed with this post 09-19-2012 at 12:30 AM
TouratechUSA is offline   Reply With Quote
Old 09-19-2012, 12:17 AM   #2
TouratechUSA OP
Made For Adventure
Oddometer: 473
All GPS Mounts
Garmin Montana Mount
The Touratech locking mount for the Garmin Montana GPS navigator provides the ultimate in locking and vibration resistant protection for your GPS while on any kind of motorcycle adventure.
Because of the locking mechanism, you will no longer have to worry about your expensive GPS while running in to pay for gas, or grabbing a bite to eat. The Montana GPS mount also incorporates anti-vibration dampeners to cut down on harsh vibrations to your GPS from your motorcycle's engine or the road conditions. This mount is perfect for both street touring on a large sport touring bike, or hard off road riding on a single cylinder enduro.
Note: This mount requires the use of the Garmin plastic integrated motorcycle mount and power cradle for installation. If you do not already have this cradle, it can be purchased separately here.
  • Color: Silver or Black anodized
  • Made out of stainless steel and anodized aluminum
  • Fits Garmin Montana series GPS units
  • Works in conjunction with Garmin's plastic power cradle
  • Made in Germany by Touratech
  • Locks with key
  • Can be keyed to match other locking Touratech items
  • Crossbar mounts can be configured to either portrait or landscape orientation
Garmin Zumo & Nuvi Mounts
The ZUMO 660 & 665 locking mount V2.0 from Touratech is an easy and convenient way to secure the GPS unit to your motorcycle. The spring actuated opening mechanism makes it quick and easy to lock the unit into place and just as easy to retrieve it. This mount secures the ZUMO GPS unit with a positive closing structure that locks with a key. The mount further protects the valuable GPS with a vibration absorbing mounting system.
Touratech locking GPS mounts have been used by motorcycle travelers the world over. They are built to withstand the rigors of off-road riding or a trip around the world.
  • Easy and convenient way to secure GPS unit to your motorcycle
  • Secures your GPS device with a mechanical closure with key lock
  • Protects GPS electronics from motorcycle vibration
  • Reinforces and protects the plastic Garmin cradle
  • Prevents original Garmin cradle from accidentally being opened while riding, or protects it from theft
  • Made of stainless steel and Silver or Black anodized aluminum
  • Designed to mount to 1/2 inch cross bar or Touratech GPS Mount adapter
  • Can also be adapted to any motorcycle with RAM mount system
  • Precision crafted at the Touratech factory in Germany
TOURATECH's Zumo 550/450 motorcycle mounts offer increased security to protect the plastic Garmin cradle. It is designed to bolt to a 1/2" crossbar, but can be adapted to almost any motorcycle with a RAM system. Key Lock provides more security while filling gas, etc.
"Touratech's locking GPS mount holds my Garmin Zumo 550 more securely than anything else I've tried."
Tim Carrithers - Motorcyclist Magazine
  • Anodized Silver or Black
  • More vibration protection
  • Locks with Key
  • Does not fit Zumo 660
  • Heavy vibration (for thumpers, etc.) MvG version available here
  • Non-locking version available here
The ZUMO 350LM locking mount from Touratech is an easy and convenient way to secure the GPS unit to your motorcycle. The elastic band actuated opening mechanism makes it quick and easy to lock the unit into place and just as easy to retrieve it.
This mount secures the ZUMO 350LM GPS unit with a positive closing structure that locks with a key. The mount further protects the valuable GPS with a vibration absorbing mounting system.
The ZUMO GPS device and the Garmin plastic cradle shown in the photos are original Garmin parts, and are not supplied with the Touratech locking mount. They do however come with the Garmin Zumo GPS.
  • Available in Black or Silver anodized finishes.
  • Made of stainless steel and silver or black-anodized aluminum
This handlebar mounting wraps itself around the Nuvi 500/550 & Zumo 220 like a hand. The device fits easily in the stainless steel base plate. After activation of the precision-lasered, CNC-shaped, forcibly guided closing mechanism, the upper part of the bracket lowers down over the device like a hand. The selected attachment points on the housing of the Nuvi 5xx and Zumo 220 hold the device firmly and securely in position. So whatever lies ahead - high-frequency engine vibrations, or large potholes, or curbs - you can focus on your ride and the action.
Clamps to 1/2" crossbar, also pre-drilled for the 1.90" RAM diamond base (GRAD).
  • Stainless steel and anodised aluminium construction
  • Key-lock
  • Clamping mechanism holds the Nuvi securely
  • Fit to 1/2inch crossbar or to RAM system (GRBH)
  • Use Power Cable GC12VUSB with this mount
  • Heavy vibration (for thumpers etc.) MvG version available here
Garmin 62 & 60 mounts
Specially developed for the Garmin 62 series GPS navigators, this mount from Touratech firmly and securely holds the GPS unit in place on your motorcycle, in any conditions.
Our specially developed vibration dampening system, proven in rally racing, protects your valuable GPS from harsh vibrations from off-road riding, or rough paved roads.
The key lock allows you to leave the GPS on your motorcycle during a gas or lunch break and not have to worry about theft. If you have other locking Touratech items and would like the key to match, please make a note of your key number in the comments field of the web order, or give us a call.
  • Made from Laser-Cut anodized aluminum and stainless steel
  • Closing mechanism holds the device safely and firmly in position
  • Special dampers protect GPS against vibration
  • Mounts to 1/2" cross bar or can be adapted to any motorcycle using the RAM mount system
  • All functions of the GPS are still easily accessible
At Touratech, we are huge fans of the Garmin 60 series GPS units! This is why we built the best possible locking mount for this GPS model.
Constructed from laser-cut stainless steel and aluminum, the Touratech mount secures the GPS into the mount with a positive closure that locks with a key.
The mount also protects the GPS from vibration with Touratech's vibration isolation technology which is built into the unit.
The Touratech locking mount is the ultimate solution for 60C, 60CS, 60CX, 60CSX GPS units.
The Touratech mount comes with all the hardware to bolt directly to a cross bar or Touratech GPS mount adapter. The GPS mount can also be adapted to nearly any motorcycle with RAM components or the GEEAD tripleclamp mount system.
  • Fits 60C, 60CS, 60CX, 60CSX
  • Key-lock, can be matched to Touratech pannier locks
  • Vibration reducing rubber buffers
  • Engineered linkage mechanism
  • Attaches to 1/2 inch crossbar or Touratech GPS mount adapter
  • To fit larger diameter bar, mount can be adapted with (RAM mount GRBH part # 065-0040.) Add (part # GCSEC) to GRBH to restore locking security
  • Mount holds powercord in place
  • Includes rubber cap for powercord
  • Made at the Touratech factory in Germany
TouratechUSA screwed with this post 11-01-2012 at 10:25 PM
Old 09-19-2012, 12:17 AM   #3
TouratechUSA OP
Made For Adventure
Oddometer: 473
ALL Touratech GPS Mount Adapters
1200GS (2004 - on & not ADV) GPS Mounting Bracket
Sturdy stainless steel bracket adapter for nearly all Touratech GPS handlebar brackets. You can thus position your GPS unit properly above the instruments of your R1200GS.
The inclination of the bracket can be set in different positions and the bracket is wide enough for you to be able to position a GPS unit, for example, wherever you want.
BMW 1200GS Adventure GPS Mount Adapter
Touratech bridges the gap between your R1200GS Adventure and your Touratech GPS mount with this bracket that connects to the windscreen support bar. The GPS Mount Adapter allows you to locate the GPS above the instruments, an optimum location for viewing.
Crafted from CNC aluminum and lazer cut stainless steel, the kit comes with everything you need to install the bracket.
To mount a GPS on your R1200GS Adventure you will need to purchase this GPS Mount Adapter in addition to the Touratech GPS Mount.
NOTE: Full windscreen adjustment may not be possible with some of the largest GPS mounts. Will not work with some "MVG" mounts, call for more details.
  • Connects a Touratech GPS Mount to your R1200GS Adventure
  • Allows GPS mount angle adjustment
  • Will not work with some "MVG" mounts, call for more details
  • CNC aluminum and laser-cut stainless steel
  • Fits all model years
  • Made at Touratech factory in Germany
BMW 1200GS/ADV/HP2 Crossbar GPS Mount (2008 - on)
The Touratech GPS Mount Adapter places a crossbar mount at the center of the R1200GS/ADV handlebar clamps. Stainless steel supports for a 100mm long "crossbar" at the R1200GS handlebar clamp bolts. Special bolts make it possible to remove the adapter without loosening handlebar clamps.
NOTE: if bar risers installed use item 044-1072 which has 25mm longer bolts.
For 2007 and old 1200GS use item 040-0664. If bar risers installed use item 040-0665.
BMW F800GS / F700GS / F650GS-twin GPS Bracket Adapter
The bracket adapter is simply fitted to the handlebar mounting clamps on your BMW.
Our GPS brackets all fit perfectly on its 12-mm round bar. For easy, safe attachment of your GPS.
With virtually no impairment of the view of the instruments.
  • Stainless Steel
  • Aluminum bar
  • All hardware included
  • Easy installation
  • Fits BMW F800GS, F700GS, F650GS Twin, 2008-on
BMW G650GS / Sertao - 2011 on GPS Bracket Adapter
Successful rally racers have been doing it for years: they install their navigation tools in the central field of vision.
This GPS bracket adapter from Touratech lets you keep your GPS device or road book firmly in view, above the BMW G650GS gauges. No more looking down or distractions to the side - your eyes are always pointed at the road.
The mounting plate attaches neatly to the existing mounting points behind the windscreen on the BMW G650GS. No drilling or modifications required. Nearly all Touratech GPS mounts can be easily fitted to the mounting adapter's 12 mm center bar.
  • Easy Installation
  • Mounts GPS above gauges
  • Fits BMW G650GS & Sertao 2011-on
BMW G650XC/C/M, KTM LC8 & 690 GPS Bracket Adapter
Attaches to the G650X handlebar clamps. The mounting holes are spaced 40mm x 90mm.
Fits KTM LC8 950ADV and 990ADV, 950SE/SD; and KTM LC4 690
  • Includes all hardware
  • Stainless Steel and Aluminum
  • May fit other bikes
KTM 990 ADV 2009-on GPS Mount Adapter
This GPS Mount adapter from Touratech allows you to attach your Touratech GPS mount to your KTM 990 Adventure right in the line of sight, above the cockpit.
This adjustable bracket is the link between your KTM 990 and any one of our lockable GPS mounts. It provides a 12mm cross bar above your gauges, instead of on your handlebars, making it easier to see your GPS screen while riding.
  • Can only be used in conjunction with the original cockpit, from 2009
  • Mounts your GPS above the cockpit
KTM 950 / 990 Adventure - up to 2008 GPS Mount Adapter
The Touratech GPS Mount Adapter fits above the gauges on the KTM LC8 original fairing. It provides a 1/2 inch bar to allow attachment of some Touratech Crossbar GPS Mounts.
Does NOT fit StreetPilot mounts 065-0032, 065-0039, 065-0056. These mounts can be modified to fit by drilling new holes.
NOTE: does not include GPS mount. This adapter just provides a place for attaching Touratech mounts
Triumph Tiger 800/800XC/Explorer 1200 GPS Bracket Adapter
Touratech's GPS bracket adapter for the Triumph Tiger 800, 800XC, and Explorer 1200 simply attaches onto the Triumph's handlebar mounting clamps and provides a place to mount your navigation equipment using a Touratech mount.
Nearly all our GPS mounts fit perfectly on its 12 mm strut. Does not block your view of the instruments.
  • Fits Triumph Tiger 800, 800XC, and Explorer 1200
  • Easy to install
Triumph Tiger 800/XC Windshield Adjustment Bracket w/ GPS Mounting Bar
With the success of the Touratech Desierto fairings for the BMW GS motorcycles, Touratech decided to apply the same technology to the Triumph Tiger 800 and 800XC. This windscreen adjustment bracket for the Tiger 800 gives you infinite angle adjustment for the stock Triumph windscreen. As an added bonus, this bracket even includes a GPS mounting bar to locate your Touratech GPS mount over the motorcycle's gauges in the line-of-sight.
  • Adjustable angle
  • Provides GPS mounting location
  • Integrates with stock Triumph windshield
Triumph Tiger Explore 1200 Above Gauges GPS Mount Adapter
Mount your GPS securely above your Triumph Tiger Explorer 1200's gauges with this GPS mounting adapter from Touratech. With your navigation screen directly in the line of sight, you will no longer have to look down or to the side while you're riding, greatly increasing safety while you travel.
Precision engineered, this adapter is manufactured in Germany by Touratech out of laser-cut stainless steel and aluminum. The bracket provides a 12mm (1/2") cross bar right above your gauges, the perfect location for your GPS screen. The 12mm cross bar provides a robust mount for any one our our Touratech locking mounts.
  • Easy to install
  • No modifications to motorcycle necessary
  • Provides 12mm (1/2") diameter bar for mounting
  • Compatible with any Touratech locking GPS mount and many other navigation devices
  • Made of stainless steel and aluminum
Yamaha 1200 Super Tenere GPS Handlebar Bracket Adapter
This GPS bracket adapter from Touratech is a great place to mount your GPS or other navigation devices to the handlebar mounting clamps on your Yamaha XT1200Z Super Tenere.
All of the Touratech GPS brackets will fit perfectly on its 12-mm brace. The height of this bracket adapter allows minimal impairment of the view of your gauges.
  • Easy to install
  • Made of laser-cut stainless-steel and anodized aluminum
Yamaha 1200 Super Tenere Windshield Adjustment Bracket w/ GPS Mounting Bar
Touratech developed this windscreen adjustment design in 2005 for their Desierto fairings. This method was tested on the YAMAHA Super Tenere when the bike was released in 2010 and resulted in increased comfort for the rider. The ingenious and simple arrangement of hand-tightened knobs allows infinite windscreen adjustments. For example you might place the windscreen upward and forward for longer trips. Moving the screen forward allows some air to come in below the windscreen, smoothing the turbulence around the rider's head noticably. In this way your motorcycle behaves as if it has a larger windscreen, without disturbing the appearance of the bike.
As an added bonus, our design includes a GPS mounting bar to position your Touratech GPS mount over the motorcycle's gauges in the line-of-sight.
  • Easy installation
  • Adjustable in height and angle
  • Integrates with stock Yamaha windshield
Enduro Engineering - Universal Crossbar - fits other BMW and many other bikes
This crossbar adapter system allows you to mount any computer, route chart holders, gps system. Our TOURATECH GPS mounts fit perfectly on this adapter. Up or down, forward or backward, this mount fits anywhere. Great for working with tapered bars and or steering stabilizers. Extremely adjustable, perfect for our Touratech GPS mounts.Verticals are 2.7 inches long and can be cut shorter. Comes with 4.5 inch horizontal (as shown) and a 10 inch bar too.
NOTE: Does not include GPS mount. This adapter just provides a place for attaching Touratech mounts.
  • Fits almost any motorcycle or ATV
  • Bars are extra long, can be cut
  • Includes all screws for Metric motorcycles (M8)
Universal Enduro GPS Mounting Adapter
Stable GPS mounting adapter, which is fitted to the handlebar clamp. Any Touratech GPS bracket can thus be attached to the middle of the handlebar.
  • 79.5mm to100.5mm
Touratech Universal Mount Adapter
Universal adapter can be attached to nearly any motorcycle at the clutch or brake resovoir on the handlebars.
Provides a 1/2 inch bar to allow mounting a Touratech GPS Mount. Adapts nearly all Touratech GPS Mounts and other accessories designed to mount on a half-inch crossbar.
NOTE: does not include GPS mount . This adapter just provides a place for attaching Touratech mounts.
  • Does NOT work well with Touratech Zumo mounts
TouratechUSA screwed with this post 12-15-2012 at 06:02 PM
Old 09-19-2012, 12:25 AM   #4
TouratechUSA OP
Made For Adventure
Oddometer: 473
Ram Adapters & Accessories
Old 10-17-2012, 10:28 PM   #5
TouratechUSA OP
Made For Adventure
Oddometer: 473
Seattle, WA
(October 16, 2012) Touratech is excited to introduce two locking mount and power cradle packages for the Garmin Montana GPS system. An excellent choice for any adventure motorcyclist, the Garmin Montana is a touch screen GPS device designed specifically for adventure motorcycle travel. The Montana is available in two models, the 650T and 600, both offering a fully customizable user interface, including programmable shortcuts that activate multiple functions and settings with just one click. Additionally, the Montana has the brightest and most visible touch screen on the market with a display that can be viewed in either portrait or landscape mode.
To compliment Garmin’s new Montana GPS system, Touratech has developed a vibration-dampened, locking mount that keeps your GPS unit secure while you’re riding and when you’re off the bike. A Garmin power cradle is included in Touratech’s locking mount package, allowing you to charge your GPS unit while riding. Additionally, this locking mount can be secured to the bike in either portrait or landscape position and is available in black and silver anodized finishes.
The Montana display is the brightest on the market for an outdoor GPS. The 4" diagonal size and the unit’s support for Portrait or Landscape orientation didn't hurt either.This GPS is the perfect compromise between large screen and weight. I can still put it in my jacket pocket or a belt-case when I'm off the bike "
-Dan Townsley, Tour Guide & GPS Expert, GlobeRiders
Garmin Montana 650T + Locking Mount & Cradle (M650TPKG)
http://www.touratech-usa.com/Store/P...Cradle-Package
The Garmin Montana 650T is a great GPS choice for your dual-sport or adventure motorcycle expedition. Featuring a 5 megapixel camera, preloaded Topo 100K mapsets, one of the most sensitive receivers on the market, and an extremely rugged case, the Montana 650T is one of the most capable and durable GPS's on the market. Touratech has put together this Garmin Montana 650T and Touratech locking mount package which includes a vibration-dampened, aluminum Touratech locking GPS mount (part #065-0600), a Garmin motorcycle power cradle, and the Garmin Montana 650T GPS Unit.
Retail value: $917 Package price: $829
Garmin Montana 600 + Locking Mount & Cradle (M600PKG)
The Garmin Montana 600 GPS has proven itself to be one of the most rugged and capable GPS units on the market for dual-sport and adventure motorcycle riders. With its large 4" touch-screen display, ruggedized case, and high sensitivity receiver, the Montana is a great choice and Touratech makes it easy to set-up on your bike with this GPS and mount kit. Just add a City Navigator or Topo map package and you'll be ready to hit the road or trail.
The Garmin Montana 600 and Touratech locking mount package includes a vibration-dampened, aluminum Touratech locking GPS mount (part #065-0600), a Garmin motorcycle power cradle, and the Garmin Montana 600 GPS Unit.
Retail value: $769 Package price: $699
-A video review of Touratech’s locking mount and power cradle package for both the Garmin Montana 650T and 600 GPS units is available at: http://youtu.be/GfWrFKUyEvY
-Read GlobeRiders guide and renowned GPS expert, Dan Townsley’s, top ten reasons why he chooses the Garmin Montana GPS system: http://www.touratech-usa.com/Adventu...in-Montana-GPS
Paul Guillien| General Manager
Touratech-USA / CycoActive, Inc.
P (206) 323-2349 ext. 226
www.streetline-usa.com
www.cycoactive.com
TouratechUSA screwed with this post 10-17-2012 at 10:34 PM
Old 11-01-2012, 10:31 PM   #6
TouratechUSA OP
Made For Adventure
Oddometer: 473
The COBDR and all our BDRs feature free GPS tracks (.gpx) to follow this epic route.
Please follow the release progress here:
http://www.advrider.com/forums/showthread.php?t=744112
And for now enjoy this trailer
We'll see you on the COBDR next summer!
Old 05-12-2014, 03:26 PM   #7
Geppe
Joven
Oddometer: 2
Hello I'm planning to buy the Montana 650t + Charging Mount + Cradle, but I wonder if there is a way to mount it (out of the box) on a flat surface.
This is where I'm planning to install the GPS. In the flat surface above the instruments.
Thanks.
Geppe is offline   Reply With Quote
Old 05-12-2014, 08:55 PM   #8
Hikertrash
Oddometer: 2,868
Thanks.
You can mount it there with the AMPS cradle mount.
IBA #50489
Hikertrash is offline   Reply With Quote
Old 06-03-2014, 08:19 PM   #9
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,401
Touratech USA, I'll reach out to you here in hopes of a response.
FYI I asked this same question of Touratech Canada via a website submission and received zero response.
I have a locking mount for an old Garmin 2720.
http://shop.touratech-canada.com/nav...-lockable.html
I've lost the key for it. What are my chances of getting another one?
Thanks.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is online now   Reply With Quote
Old 03-11-2015, 10:37 PM   #10
minnow
Let's go...
minnow's Avatar
Oddometer: 834
Pissed Lockable RAM mounts - a joke
I have a F 800 GS with Desertio 3 fairing and TT tank.
My Garmin Montana was mounted to the handlebars locked in via the lockable Ram mount in turn locked into the TT lockable mount.
According to the Ram Mount website they describe the mount as...'you can lock it in place and feel safe that your mounted device will stay right where you left it."
Hum... bulls*%t. Thieves came along and somehow got it off w/o dmaaging the ball mount on handlebar or the fairing or anything else and stole Garmin, TT mount and the 'theft' proof Ram mount.
Wrote to Ram told them of issue and had one measly response to which i replied and nothing since (been over 3 weeks).
Soooo - my lesson is that it doesnt work and Ram dont give a s*&t!
“Imagination is more important than knowledge. Knowledge is limited to what we all know now and understand, while imagination embraces the entire world, and all there ever will be to know and understand” Albert Einstein.
minnow is offline   Reply With Quote
Times are GMT -7.   It's 04:40 PM.
