Old 02-01-2013, 03:59 AM   #1
foxtrapper OP
Oddometer: 752
Harley Turn Signal Switch Conversion
I want to convert my Harley over to a Japanese bike style turnsignal switch. I know, I'm supposed to love the Harley design of a button on each side of the handlebars, I don't. It definately wreaks havoc with me and my braking for a right hand turn.
I've been looking around for someone making a kit or such that would let me switch over to the single switch on the left bar, like every other bike I've ever had in my life. But darned if I can find such a critter.
Surely I'm not the only person who wants this?
foxtrapper is offline   Reply With Quote
Old 02-01-2013, 04:53 AM   #2
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,806
Just change the left switch out with a dirtbike switch (a lot of Harleys have 1" bars vice the 7/8" you find on japanese bikes)
You'll have to rewire but that shouldn't be that complicated.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 02-01-2013, 05:26 AM   #3
bobw
Harden the phuck up
Oddometer: 898
BMW has/had the same until just recently going to the one switch does it all design. Give it a genuine effort by practicing and it becomes second nature in no time. Used to have bike with shift levers on opposite sides, etc., and it is livable.
Other than that, plus 1 on Tripped 1's suggestion and I would first make sure the wiring mods were compatible with canbus/sensors/ridebywire/etc. if this is a newer bike, older would be fairly simple.
bobw is offline   Reply With Quote
Old 02-01-2013, 07:12 AM   #4
Randy
Randy's Avatar
Oddometer: 2,346
I have to agree. After many years of riding bikes with the typical Japanese style turn signal switchgear, I bought my GS. After years of reading magazine testers bitching about the BMW style switches I fully expected to hate it like everyone else seemed to. But after a relatively short time I got used to it and it was no big deal, and I began to wonder what all the hoopla was about. Then after a longer period of time I jumped on one of my other bikes with the "normal" switchgear and I felt lost!
I then realized that I had become a convert and begin to believe that the BMW designers were "right" in designing a superior system. I was actually more than a little disappointed when I read that BMW had changed to the more "normal" system on their newer bikes.
Then, I got my H-D and discovered that the H-D designers had one upped BMW with their system. The H-D, two button system with auto cancel is better than the three button, non-self cancelling signals on my GS, IMO.
Just activate your signal a little earlier, before you begin braking and then just forget about it and let the self cancel do it's thang. I also like the push once to activate and push again to cancel, feature on the H-D, over the separate cancel button found on the BMW.
So, I'd say to give it a little time to get used to it and it should become second nature. A lot of things about riding a motorcycle are foreign when we first ride one, but as you know, it all becomes instinctive with a little saddle time. Nothing really different about getting used to something a little new, IMO.
Other than that, I'm not sure what options you have. AFAIK, H-D is unusual in using the 1" bars. Every dirt bike I've ever dealt with or owned had 7/8" bars. Even Buell used 7/8" bars, although they did use the left side does all turn signal switch. I don't know of any manufacturer that uses 1" bars and the standard turn signal switchgear, unless you can find another line of cruisers that uses that combination. Do any of the Japanese cruisers use 1" bars? What about Victory? The only other option I can think of would be to convert your 1' bars to 7/8" bars, but that would require changing out all of the bar controls, which would be expensive!
I'll wish you good luck in getting used to them first, and then if that fails, I wish you luck in finding a solution that works for you.
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy is offline   Reply With Quote
Old 02-01-2013, 07:38 AM   #5
EricD10563
EricD10563's Avatar
Oddometer: 696
You'll get used to it if you give it time. Thirty years of owning bikes that had the usual setup took me some time but now the Harley system is normal to me.
In 2009 I rode 18,589 miles on an island that's 72 miles long. That's 50 miles a day everyday for 365 days. I think I'll go home now. 96k miles and still riding http://travelwithe.com/blogengine.net/ my YouTube Channel http://www.youtube.com/channel/UCTJA4CrFRY-_rvDejPct73g
EricD10563 is offline   Reply With Quote
Old 02-01-2013, 08:05 AM   #6
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,379
As far as I know HD has had these system for at least the last 13 years. My first HD, a 2000 Sporty, had the same setup as my '12 Road Glide. I had been off bikes for 20 years before that Sporty and it wasn't until later when I picked up a Triumph followed by a Suzuki that I realized the other mfgs didn't design their systems like HD.
Personally I much prefer the HD design with the self cancelling feature as it's just a quick bump with the thumb rather than a push left or push right on other bikes and no need to hit again to stop.
Like Randy says, just tap the button with your thumb right before you begin your braking and forget about it.
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 02-01-2013, 08:12 AM   #7
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,806
CanBUS only works between the gauge and the ECM/sensors most of the time. A switch is a switch is a switch, it doesn't really matter what you are plugging them into as long as it has the right number of poles.
Old 02-01-2013, 08:14 AM   #8
davevv
One more old rider
Oddometer: 2,345
This. If as you say, "It definately wreaks havoc with me and my braking for a right hand turn", then you aren't giving people much warning before you start into the turn. How is the guy behind you supposed to know you're going to be slowing for a turn if you're already reaching for the brake before you turn on the indicator? It's a pretty simple matter to have the turn signal activated before you ever need to reach for the brake.
"Fast is fine, but accuracy is everything"--Wyatt Earp
'13 Yamaha Super Tenere.
'04 Sportster XL1200R
davevv is offline   Reply With Quote
Old 02-01-2013, 08:15 AM   #9
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,806
https://www.kisantech.com/index.php?cat_id=4
Self cancelling signal for damn near anything.
Old 02-01-2013, 08:16 AM   #10
davevv
One more old rider
Oddometer: 2,345
The Harley signals are already self cancelling. They come that way from the factory.
Old 02-01-2013, 08:19 AM   #11
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,806
I'm aware of that, I was referring to the guys talking about other makes.
I can't stand the dual switch set up either.
Old 02-01-2013, 08:41 AM   #12
foxtrapper OP
Oddometer: 752
All right, I'll keep trying to get used to it. Weather and such is keeping riding down to a minimum right now.
Normally I do give lots of advance warning with signals. But I'm also pretty durn good at swerving around someone who just cut me off or such while hitting the turnsignal at the same time. That's the part I can't do with the Harley. It's semi-new Harley for the record, an 04 Road King.
Old 02-01-2013, 11:31 AM   #13
DAKEZ
DAKEZ's Avatar
Oddometer: 19,702
It will become intuitive
Push Right go Right
Push Left go Left
Then you will be looking for a Harley or BMW system to put on your other bikes.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 02-01-2013, 12:57 PM   #14
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 1,999
I grew up on the standard Japanese system but when I had a Harley in '95 I adapted pretty quickly. I actually grew to like their system, the self cancelling feature works very well. Just push the button and forget it, it shouldn't interfere with braking at all. Unless it's the really old-school harley system where you have to hold the button down to keep the signals flashing. Then all bets are off.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 02-02-2013, 10:55 AM   #15
Shooter1
Shooter1's Avatar
Oddometer: 463
I bought an '89 FXRS-Sp new and it had individual buttons on each bar side, but to activate the sigs, you had to hold the button down and let up when you wanted to cancel the sig. It was not self cancelling. Try making turns and using the clutch or front brake while holding the sig button down with your thumb, and operating either the throttle or clutch lever!! For some reason it was an aquired skill and never really bothered me untill I got older and have a touch of arthritis in my hands, then it got to hurt a little bit. Three years ago I bought a used '00 FXDX SG Sport and it has the HD self cancelling sigs with a button on each side. Shit, I thought I was in heaven compared to the old FXRS signals. I love them and still do. Kinda like moving into the 21st century as far as turn sigs goes! I think you'll get used to them and like 'em.
-Harvey
#1017
'00 FXDX SG Sport, '06 300XCW,
'07 EXC450, '01 640 Lc4E
Shooter1 is offline   Reply With Quote
Times are GMT -7.   It's 03:32 AM.
