Old 02-01-2013, 09:46 AM   #1
bembe OP
Oddometer: 71
What to do to Faded Plastics ?
Good morning.
Any suggestions as to a PROVEN product to use on Faded Plastics ?
I have a number of perfect fenders and panels that could be brought back
to SHINE with a proven product out on the market.
Any suggestions ?
Thank you, TOMAS.
bembe is offline   Reply With Quote
Old 02-01-2013, 09:54 AM   #2
endlesshydro
Oddometer: 18
Endless Hydrographics :)
Check out my brothers DRZ-400 and matching ATV
https://www.facebook.com/media/set/?...type=3&theater
endlesshydro is offline   Reply With Quote
Old 02-01-2013, 04:06 PM   #3
Bayner
Oddometer: 1,557
I've been impressed with this stuff:
http://www.motorcycle-superstore.com...-Detailer.aspx
Just spray it and let it soak in for an hour or so. Repeat on areas that have soaked it all in. Makes cleanup easier too.
Bayner is offline   Reply With Quote
Old 02-01-2013, 07:29 PM   #4
Rd650
Rd650's Avatar
Oddometer: 238
Heat gun
Rd650 is offline   Reply With Quote
Old 02-01-2013, 07:32 PM   #5
Hastelloy-X
Oddometer: 323
Like he said; heat gun.
Hastelloy-X is offline   Reply With Quote
Old 02-02-2013, 12:47 AM   #6
heirhead
Oddometer: 564
303 aerospace protectant. Similar to ArmorAll but WAY better.
Sure makes an old kayak look like new.
Heirhead
heirhead is offline   Reply With Quote
Old 02-02-2013, 02:05 AM   #7
aussie_king_mick
Oddometer: 166
Thumb
This is what you need…
http://www.pcracingusa.com/Plastic-Renew--Motorcycle_p_79.html
aussie_king_mick is offline   Reply With Quote
Old 02-02-2013, 05:13 AM   #8
AllenL
Oddometer: 79
Heirhead
I second the 303 aerospace protectant. Its awesome on any plastic that is going to spend some time out in the sun.
1986 XR600R --> 2014 XR700CW - work in progress
AllenL is offline   Reply With Quote
Old 02-02-2013, 10:00 AM   #9
kubiak
Oddometer: 4,829
i like to sand the plastic to get to the good color then clearcoat.
Old 02-02-2013, 10:34 AM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,618
May depend how much faded. Holy cripes do I have something here to practice on.25 years of fading. And have already practiced but not with 303, looked a couple weeks back and price was a little rich for me. Maybe next time....! But sure tried the others....Armor All, Mothers etc....etc nothing worked.
In the meantime I tried another trick I may just have learned here. Brake fluid. Now that's DOT4. Apparently the DOT5 is better for that, has sillicone in it but again local price was a little too much if just for practices.Maybe next time....!
Anyway you can see where I removed the Honda decal and then tried Dot4 under. May need a little wetsanding at the appropriate grit(s) lubed with brake fluid. This is just a quick buffing with a dirty rag and older brake fluid. Been like that for over a year so seems to work. Maybe someday I'll finish it, that is put more than 5 minutes of efforts into it.
Sure doesn't look like the Glycol ate the plastics. Never tought it would but......I have another tank for that bike.
Have tools, will travel!
H96669 screwed with this post 02-02-2013 at 10:43 AM
Old 02-02-2013, 04:47 PM   #11
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,545
Details on heat gun, please. Or is it obvious? The color just comes back?
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 02-02-2013, 08:56 PM   #12
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,625
I tried the heat gun thing on my faded '92 KLR blue plastic. No luck on the first go round. I then went after it with Soft Scrub followed by wax and it worked somewhat.
Forward 2-3 years down the line and the fade is back. Soft-scrub just didn't seem to be getting it now.
So out comes the heat gun and more determination and ta-da ! This time I got results.
What I did was work on a small area with the gun on low , never stop moving the flow, but stay in a small area until you see the surface change. The oils will rise to the top and shine then keep moving the gun to spread this effect over the whole area.It takes about 20-25 minutes to do a front fender.
As the plastic cools some of the shine goes away but, you can get most of it back with a good waxing.
The next time I went riding with my usual crew a couple of them asked if I'd gotten new plastic.The treatment is still holding up after a year.
Old 02-03-2013, 07:14 AM   #13
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,545
Good deal. Thanks.
Old 02-04-2013, 10:10 PM   #14
Young-Gun
KTM Tragic
Young-Gun's Avatar
Oddometer: 964
I've tried this and it works!
All you need:
- single sided razor blade that you can hold along the one edge
- Heat gun
http://www.youtube.com/watch?v=KJb5IPOx2l0
Young-Gun is offline   Reply With Quote
Old 02-05-2013, 12:22 AM   #15
simmersonwheels
Asleep at Switch
simmersonwheels's Avatar
Oddometer: 116
Wurth
I've been reconditioning bikes for years, worth cockpit silicone is a miracle on any black plastic. Faded signals, instruments, trim etc, maes it literally like new
simmersonwheels is offline   Reply With Quote
Times are GMT -7.   It's 06:09 AM.
