Old 02-01-2013, 11:34 AM   #1
Megaplow OP
Megaplow's Avatar
Oddometer: 85
New (to me) KTM 525 EXC
Hey All,
Last night I picked up a 07' KTM 525 EXC. Its my 1st dirt bike and wanted a little advise. I am not sure what I am feeling is normal or needs adjusting.
I feel I can't get the idle low enough. There is an unknown aftermarket air filter and a stock exhaust. Is there a baseline or a known good setup on this bike? Why not use the stock air filter? What is the basic carb/jetting setup for sea level to say 4000ft? When I "parking lot tune" it and go from idle to floored, it stalls.
Seems like a serious bike that I have a lot of growing into.
Joe
07' KTM 525 EXC
Past:
08' KTM 990 Adv Black (I miss you baby)
05' BMW 1200 ST
00' BMW 1150 GS
Megaplow is offline   Reply With Quote
Old 02-01-2013, 11:56 AM   #2
zestymac
zestymac's Avatar
Location: WJoisey....The good part with farms and dirt roads
Oddometer: 115
You'll find a good home here:
http://ktmtalk.com/index.php?showforum=7
zestymac is offline   Reply With Quote
Old 02-01-2013, 12:46 PM   #3
CJBDRdude
Dirtyrider
Oddometer: 273
+1 - nuff said
CJBDRdude is offline   Reply With Quote
Old 02-01-2013, 12:51 PM   #4
Megaplow OP
Megaplow's Avatar
Oddometer: 85
Signed up and reading now.
If all the info for my bike is on ktmtalk does this mean I am going to have to break up with adv?
Joe
07' KTM 525 EXC
Past:
05' BMW 1200 ST
00' BMW 1150 GS
Old 02-01-2013, 01:03 PM   #5
OrangeYZ
Oddometer: 618
Joe
In the future, if you want to recommend somebody buy a KTM and have it turn into an argument, come back to ADV. We'll be waiting
OrangeYZ is online now   Reply With Quote
Old 02-01-2013, 03:03 PM   #6
Megaplow OP
Megaplow's Avatar
Oddometer: 85
I could never break up with you adv.
This site and the inmates are too bad ass to leave.
07' KTM 525 EXC
Past:
05' BMW 1200 ST
00' BMW 1150 GS
Old 02-01-2013, 03:21 PM   #7
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,716
read til your eyes bleed
http://www.advrider.com/forums/showthread.php?t=201026
although it's geared towards the d/s end of the spectrum, tons and tons of good info here
imho ktmtalk is a better place to find parts / specific answers to specific questions
none of us is as dumb as all of us
clapped_r6 is online now   Reply With Quote
Old 02-01-2013, 04:23 PM   #8
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,247
The RFS motors are supposed to idle a little high, below around 1500rpms the autodecomp is affecting the valve system. You want it to idle just above that which is a little high compared to other brands.
I also just picked up a tagged '07 but it's the 525XCW, baiscally the same bike but it came without lights. It's under the knife at the moment for some trickery
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 02-01-2013, 05:22 PM   #9
davesupreme
grand poobah
Oddometer: 1,643
i gotta '06 450, alotta the same stuff.... lotta voodoo in the carb, accelerator pump's gotta be tuned right or it'll bog and stall, lotta voodoo in the jetting and needle too.... changing to an OCEMP needle is pretty standard, stock ones are way lean low/mid.... get into the RFS section at KTMTalk and you can learn alot, there's some stickys about carb tuning that you can learn alot from..... the motors ain't all that, but you gotta be smarter than it.....
davesupreme is offline   Reply With Quote
Old 02-02-2013, 04:29 AM   #10
400psi
Cropdusting
400psi's Avatar
Oddometer: 513
If it were mine, I wuold get a jd jet kit, new fuel screw that can actually be turned, new air filter and start from there. While I'm sure it could be set right to run without spending on the above items, the installation of these will give you piece of mind, have it set up correctly and allow you to eliminate these items, as problems, if issues continue to persist. Good luck great bike
I'm so far behind I think I'm in first
400psi is online now   Reply With Quote
Times are GMT -7.   It's 01:33 PM.
