Old 03-11-2013, 12:50 PM   #1
FredRydr OP
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,459
JB Weld
Does JB Weld go bad? I keep it in a ditty bag in my topcase, and eventually the outer plastic tube falls apart. If I've never cut or squeezed the contents, is it still good?
Fred
FredRydr is offline   Reply With Quote
Old 03-11-2013, 01:49 PM   #2
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,684
Not from my experience... as long as it's soft enough to actually mix the two together, it'll work.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is online now   Reply With Quote
Old 03-11-2013, 02:06 PM   #3
preppypyro
preppypyro's Avatar
Oddometer: 578
I havent had it go bad at all, and ive had some that sat around for a few years. Seems like I use it up within a year ish of opening it usually.
preppypyro is offline   Reply With Quote
Old 03-11-2013, 04:11 PM   #4
showkey
Oddometer: 1,974
The putty stick version of epoxy seems to travel better in the on bike tool kit.
Also sticks where you put during the emergency road/trail repair.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 03-11-2013, 04:34 PM   #5
Speedo66
Transient
Oddometer: 6,863
Does JB Weld go bad? Only if it's running around with the wrong crowd.
I think as long as the tubes are tightly capped it stays in good shape.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 03-11-2013, 09:08 PM   #6
SantaFeTrailer
Stromtrooper
SantaFeTrailer's Avatar
Oddometer: 326
WARNING: I was going through my kit wondering this just this past week. I started bending the tube to see if it was still flexible. It was, but the tube itself was not and a little piece broke off and flew right into my eye. Damn did that hurt - and still can't see quite right. I tossed it because I was pissed, but probably should have just put it in a few ziplocs.
SantaFeTrailer is offline   Reply With Quote
Old 03-11-2013, 09:28 PM   #7
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,632
I would say if the intended "use" is fairly important, just buy a new kit of the JB.
Never do anything you would be uncomfortable explaining to the paramedics...
Unstable Rider is offline   Reply With Quote
Old 03-11-2013, 09:38 PM   #8
ParaMud
ParaMud's Avatar
Oddometer: 628
I just used some JB quik 2 weeks ago.
Saved us from having to tow the bike 100 miles. Had to go buy 4 quarts of oil though.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Times are GMT -7.   It's 01:49 PM.
