Old 08-16-2011, 08:24 PM   #1
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
XR250 hack build
Idea !
Build a light adv hack for hunting / camping gear / guns
Has to be easly removeable "3 bolts"
No altarations to the bike other than a sub frame.
Bike has to beable to still lean...
So start with the sub frame.. prob the hardest
part of the whole build as yer have design constraints
from the bike.. So I ended up with a sub frame I can live with..
started on a slideing limiting strut to stop the bike falling over
when parked but still let the bike lean..
Pete-NZ screwed with this post 08-17-2011 at 02:56 AM
Pete-NZ is online now   Reply With Quote
Old 08-16-2011, 08:26 PM   #2
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
On the bike
Old 08-17-2011, 06:17 AM   #3
AceRph
Stossel for POTUS
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 23,770
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
AceRph is offline   Reply With Quote
Old 08-17-2011, 12:15 PM   #4
sidecarstar
Oddometer: 17
cool I'm going to do one with a lawn sweeper for my TTR110 pit bike. Why not make the task fun?
sidecarstar is offline   Reply With Quote
Old 08-29-2011, 10:24 PM   #5
SETHZILLA!
Oddometer: 5
Looking good so far Pete, can't wait to see more pics. I am getting ready to build the same style of setup on my XR650!
SETHZILLA! is offline   Reply With Quote
Old 08-31-2011, 04:41 AM   #6
halflive
halflive's Avatar
Oddometer: 266
Looks like you can do some pretty welding. But please, for my sake. Weld some gussets on either side of the mounting struts. The weld would cope with a static force, but the length of the strut gives some mean force sideways, pulling and pushing from left to right.
halflive is offline   Reply With Quote
Old 09-02-2011, 11:25 PM   #7
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
Yes there will be gussets welded in...
Hope to get the frame tacked togeather 2morrow at long last....
keep getting side tracked...
Old 09-02-2011, 11:34 PM   #8
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
Keep getting side tracked...
Old 09-03-2011, 05:39 PM   #9
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
Basic frame tack welded togeather...
steel is 25x25x3 RHS..
The swing arm mount has to be shortened
yet...
Old 09-09-2011, 05:57 PM   #10
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
A bit more progress...
Old 09-09-2011, 05:58 PM   #11
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
and this one..
Old 09-09-2011, 07:13 PM   #12
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 370
Thumb
Looks to be well thought out Pete, and well constructed.
I'm just trying to grasp the concept of a leaner in an off road situation or even an on road situation.
Is it like having a folding tagalong dolly attached to the side of your bike?
I want to see video of you getting light on some whoopy terrain ...
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 09-09-2011, 08:03 PM   #13
Pete-NZ OP
Pete-NZ's Avatar
Oddometer: 510
Don in Nipomo
A leanning car on a dirt bike is really a unknown..
I have not seen another unit.. So I thought I would
give it a go...If it proves to be no good I can relpace
the slideing limiting struts & soilidly mount it...
Pete
Old 09-09-2011, 08:17 PM   #14
D.Bachtel
D.Bachtel's Avatar
Oddometer: 370
Thumb
OK, you go first.. I'll watch.
Don in Nipomo
Old 09-09-2011, 08:18 PM   #15
Kai Ju
Kai Ju's Avatar
Oddometer: 1,025
XR Leaner
Owning an XR650R and having had the pleasure of riding a 'normal' hack, I'm really curious about this build and will be following it closely.
I won't have to worry about catching air, much, since it's set up for the street, but I wonder if a damper of sorts would keep the chair from extending too quickly should you catch air in an off road situation. It should keep the chair from just dropping away but not prevent leaning and if you can find one that is adjustable you can fine tune it for a given situation.
Kai Ju is offline   Reply With Quote
Times are GMT -7.   It's 01:09 AM.
