Old 02-03-2013, 04:12 PM   #1
KDeline OP
Oddometer: 38
Changing tires with TPMS
Were do you start to demount on the rim equipped with a pressure sensor? Where to you start to mount? What to watch for? Also I use two ways to do this depending on the location I am changing the tire. On the ground with tire irons or with a cheap Harbor Freight tire changer. Any different method between the two?
KDeline is offline   Reply With Quote
Old 02-03-2013, 08:30 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
Start 6" away from the TPMS sensor, and work your way away from it. Make sure as you work you do not put any pressure on the sensor. It is easier than you think.
Jim
Old 02-04-2013, 01:10 AM   #3
kc0stp
Lurker
Oddometer: 23
Also keep in mind some sensors are in the valve stem while others are 180 in the center of the rim.
Help stop world hunger
Protected by Amsoil
kc0stp is offline   Reply With Quote
Old 02-04-2013, 07:45 AM   #4
KDeline OP
Oddometer: 38
Thanks guys, mine are labled and near/part of the valve stem. BTW there is a youtube video of how to change the battery out so you don't have to spend $150 plus on a new sensor.
Old 02-07-2013, 12:10 AM   #5
EVLED
EVLED's Avatar
Oddometer: 593
I'm lazy. Can you please post the link?
Cheers!
EVLED is offline   Reply With Quote
Old 02-07-2013, 06:12 PM   #6
KDeline OP
Oddometer: 38
Cheers!
http://www.youtube.com/watch?v=Mpjz0cDjnK4
Old 02-07-2013, 10:08 PM   #7
EVLED
EVLED's Avatar
Oddometer: 593
Thanks - hoping the Connie's ones are similar. Originals still going after 5 and a half years and 88,000km...
Old 02-07-2013, 10:16 PM   #8
Multiplicity
Oddometer: 172
Always start 90 from the valve stem
Multiplicity is offline   Reply With Quote
Times are GMT -7.   It's 08:12 AM.
