Old 02-03-2013, 03:39 PM   #1
zoltan OP
zoltan's Avatar
Oddometer: 138
quick steel and screws
The bracket that supports/guides the front brake line has come loose from the shock tube. The holes that the guide screws to are stripped. I am pretty sure that the stripped holes are plastic and they are not that deep. I was planning on filling the holes with quick steel and then twist in the screws while its still pliable. The screws have a fairly fine thread.
Anybody have a better way to get this done?
zoltan is offline   Reply With Quote
Old 02-03-2013, 09:16 PM   #2
P B G
Oddometer: 9,781
I've never had a ton of luck with those methods, you need to remove the screw later, and there's just not enough "meat" to hold a thread.
Usually I would rather insert a small length of threaded rod with some form of adhesive to keep it in place, then use a lock nut to hold the bracket.
Old 02-04-2013, 08:33 AM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,164
How about a threaded insert for plastic?
http://www.mcmaster.com/#standard-th...nserts/=lc08cr
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
