Old 02-03-2013, 05:10 PM   #1
petzi-baer OP
Oddometer: 184
Fixing a piece of plastic
So, I had a broken piece plastic - a smaller part of the fairing on my BMW F800GS. It's part of the Toura-tech tank setup.
I bought a new pieces, but broke that one when I tried to install it. It's actually pretty flimsy.
Rather than buying another part which would set me off another 110 bucks, I would like to fix and wonder what my options are.
I would try strengthen the backside of the plastic.
thanks
petzi-baer
petzi-baer is offline   Reply With Quote
Old 02-03-2013, 08:19 PM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Maybe this.
http://www.amazon.com/Bond-Repair-Sm.../dp/B003YI421I
Someone gave me one last week, haven't tried it yet. They were being sold at a BMW motorcycle rally.
Have tools, will travel!
Old 02-04-2013, 03:42 AM   #3
Bounder
ExternallyDisplaced
Oddometer: 922
Some fine stainless steel mesh and JB weld.
Cut and form the mesh to fit the area ,apply the JB weld to the area around the crack and then push the mesh into the weld then apply the rest of the JB weld onto the mesh making sure it goes right in and saturates the mesh.
You may need to clamp the mesh down if you haven't shaped it correctly.
Bounder is offline   Reply With Quote
Old 02-04-2013, 08:04 AM   #4
jbhawley
WTF- Gus?
jbhawley's Avatar
Oddometer: 426
is the plastic you want to repair ABS plastic? If so you can solvent weld it back together with ABS Cement...sort of like PVC glue. Its about 4$ a can and works wonders. I just repaired a broken ABS fairing. The problem with JB weld and the like is that it doesn't "bite"into the plastic and will eventually just peel off, same with bondo type fiberglass repair. You can also use the ABS cement to beef-up the back side of a weak piece. I did.
Here is a good how-to if your interested:
http://faq.ninja250.org/wiki/Plastic...ith_ABS_cement
---John
Lemmings non sumus
"All the inconvenience and sweat and discomfort of body armor suddenly pales when you're sliding comfortably down the highway on all fours." -ghostdncr
jbhawley is offline   Reply With Quote
Old 02-08-2013, 06:56 AM   #5
kantuckid
Oddometer: 3,104
Look for the symbol cast into the back of a plastic part stating what type it might be. Then research the best way to repair that type plastic. Sometimes its solvent other times heat welding or epoxies,etc.. Some of the box store plastic repair epoxy these days is good stuff. You can also use fiberglass cloth if an epoxy is the right way to repair. Why not call the seller 1st and ask about the "flimsy part"? They need to hear problems & might have that part?
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-08-2013, 07:25 AM   #6
Irish John
Oddometer: 234
I have had good luck with a inexpensive plastic welder I bought at Harbor Freight. It is basically a soldering iron with flat tips and sticks of various types of plastic. I have used it to repair the fairing on my club racing bike, the radiator shrouds on my KLR, fairing on my VFR and numerable other items. Pretty easy to use, I found best results by pre-heating the repair by cutting in a groove following the crack which fuses the two parts back together. Then go back over it and back fill with the plastic rod.
Cosmetically this works best if you can do it on the back side of the part. Generally the repair draws the pieces together close enough that the crack is barely noticeable. I have also used this technique on the visible side of a part. If you take your time and are going to repaint the part, it can look really nice.
Irish John is offline   Reply With Quote
Old 02-08-2013, 10:42 AM   #7
The PacRat
I'm that other guy
The PacRat's Avatar
Oddometer: 2,703
If it IS ABS then you can grind up some scrap ABS and add it to a jar with some acetone. It will melt into a goo that will essentially weld the plastic back together and bond directly to it. Add metal screen as previously suggested for strength.
If a hammer don't fix it, then it's an electrical problem.
The PacRat is offline   Reply With Quote
Old 02-08-2013, 11:19 AM   #8
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 736
Check out plastifix.com
A friend who specializes in Honda CX twins claims the site has an adhesive or plastic welding option for all the plastics common to motorcycles.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 02-09-2013, 05:00 AM   #9
kantuckid
Oddometer: 3,104
On heat weldable plastics I use a cheap elec soldering gun with the spade tip and a spray bottle of water at hand to solidify the previously welded sections as you work. I had a HF air welder that I tried once & sold, preferring this method. When I was doing wrecks I would save broken plastics of various kinds as "welding sticks" to add to missing areas or build up the back side of repair area. The plastic rods that HF provides don't seem to cover many of the common plastics I ran into on autos. Some plastics prove to be easy , others hard to repair. I just used some clear & cheap epoxy to do a minor repair on an Asian vintage signal lens this week.
Times are GMT -7.   It's 10:35 AM.
