Old 02-04-2013, 12:39 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 395
Carry an extra battery?
So my 990 left me stranded... Again ! Due to a dead battery. I'm considering carrying an extra battery now when I head out solo into not so traveled areas. I'm wondering if I could get by with a small Ballistic 4 cell to act as a jump start battery, just because it's so small is my reason for that choice. Has anyone done this?
skidxr screwed with this post 02-04-2013 at 01:22 AM
skidxr is offline   Reply With Quote
Old 02-04-2013, 01:34 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,142
The small battery (you haven't mentioned its Ah and CCA capacity) won't be able to start the LC8 engine on its own so you will have to parallel it with the stock battery. With the stock one being weakened due to repeated starting attempts, it will damage your other smaller battery very quickly. I had a 6Ah battery in parallel to my stock Yuasa and it (the small one) got killed pretty quick say, within 1-2months.
I run a dual battery setup (having a non-ABS S version helps) using two 10Ah batteries in parallel, no isolator. Proved its worth when a riding buddy had his battery die on a ride and i loaned him my 2nd battery for the rest of the ride. So yes, i'd say you will have to carry atleast a 9-10Ah battery for jump starting in the worst case that your stocker is dead. If you have a 950 then an 8Ah battery will be fine IMO as it has lesser current draw (no FI pump, injectors, sensors etc). Edit - just sawq you have a 990.So you need the larger Ah capacity.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 02-04-2013, 03:15 AM   #3
Balsta
Oddometer: 400
I carry an extra Shorai with me and I charge both the Shorai in the bike and the spare one on regular basis with Shorai's special charger. The extra battery is less than one kg (about 2 pounds) and the charger weight is about nothing. This is a safe setup in my mind. I know some may disagree.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 02-04-2013, 08:43 AM   #4
Johnf3
Oddometer: 1,050
Any of the LiPo 8 cell batteries will start an LC8. I used a 8 cell TurnTech for two years as my primary battery in my 950 until I upgraded to an Earth X 18 cell.
An 8 cell carried as a back up would be less than 2 pounds.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 02-04-2013, 08:59 AM   #5
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,639
what about using a RC battery like a Turnigy? They are much cheaper, you can easily make up some jumper cables to jump the bike or your buddies bike.
Something like this? I have no idea if it would work but these RC batteries put out an astonishing amount of power. I don't think the amp hour really matters since the starting cycle is so short.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 02-04-2013, 09:20 AM   #6
zeegman
zeegman's Avatar
Oddometer: 381
Why is battery dying
Just as important question is:
why is your battery dying?
When the bike is running low RPMs and you are in slow technical terrain the rad fan will be running most of the time. This puts a lot more load on the charging/battery system when the lights are on as well. Some riders install a light switch (or you can pull the light fuse) to turn off the lights when in this situation to save the battery. Maybe try that when you are out next time.
MZ
zeegman is offline   Reply With Quote
Old 02-04-2013, 09:30 AM   #7
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,142
RC batteries lack the CCA to reliably turn a bike engine over repeatedly.
This thread is quite informative on different battery technologies and their pros-cons.
Old 02-04-2013, 09:48 AM   #8
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 395
I have a fairly new battery but the cold just kills it. I left it outside last night as an experiment.. It was on a charger all night the night before and then sat all day and night and it's dead right now. It's a big worry laying in the tent at night and wondering if it will start. I have taken the battery out and stuffed it in the bottom of my sleeping bag for the night and had success, but that is a pain in the ass.
I'm blaming some of this on the cheap Bikemaster battery I installed. I just don't think it's as powerful as the Yuasa I replaced. I'm going to install a stock Yuasa and try an 8 cell as a backup and see what happens.
Old 02-04-2013, 11:06 AM   #9
Pops of the desert
Oddometer: 82
cold weather
You either have a bad battery or a leak. Somthing drawing juice when in the off position. That battery should start the bike after a couple weeks of below zero temps. Check accesories and see what is powered when the key is off. I.e. GPS, phone charger, grip heaters, etc. My 990 will start at -9 F, did it last week after sitting for a month.
Pops of the desert is offline   Reply With Quote
Old 02-04-2013, 11:45 AM   #10
sonoran
Ich mag Schildkröten
sonoran's Avatar
Oddometer: 23,914
I've been thinking this thru after suffering a dead battery in the middle of nowhere too. Luckily I was able to get a jump for my bike.
First step was to get the Euro headlight switch so to save juice when offroad. Second is to pick up a LiFePo battery.. the smaller Shorai's seem compact and light enough solution.
sonoran is online now   Reply With Quote
Old 02-04-2013, 11:49 AM   #11
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,792
But they do not like cold weather....
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-04-2013, 11:54 AM   #12
_cy_
Oddometer: 6,168
sounds like you've isolated problem to a battery not holding charge.
recommendations is replace with a quality AGM like Odyssey. if saving weight over $$$ makes more sense, then go with Earth-X ETX36 or Shorai LFX36 for adventure duties.
currently those are the only two batteries I can recommend for an adventure bike that will be far from home, especially doing cold campouts.
to make sure there's no parasitic drain and your charging system is working properly.
you will need a known to be correct meter. a $3 harbor freight meter will do just fine, once it's been checked against a reliable meter like Fluke 87V.
take any primary lithium battery to a store that sells Fluke meters (HVAC) then measure cell with both meters.
1. after charging your lead acid battery overnight with preferably a conventional charger. some battery tender charge so slow it could take days.
2. after allowing battery to rest overnight to bleed off surface charge. lead acid battery should read about 12.85V for flooded PB, 13v for AGM if holding full charge.
3. a basic charging system check is to measure voltage at battery, while revving engine to medium rpm. 13.8v to 14.2v is the normal range. note intermittent charge issue are the worst.
4. to check for parasitic drain, set your meter to measure amp in series. then hook in series with disconnected ground with everything off. ck with bike mfg to find out normal drain rate if any.
for more info ... visit my LiFePO4 testing thread .. link in sig
_cy_ screwed with this post 02-10-2013 at 04:57 PM
_cy_ is online now   Reply With Quote
Old 02-04-2013, 11:59 AM   #13
sonoran
sonoran's Avatar
Oddometer: 23,914
I live in Arizona
Old 02-04-2013, 12:05 PM   #14
FakeName
FakeName's Avatar
Oddometer: 1,792
I live in Arizona
I've been cold in Arizona.
But for me it's cold below 55. Below 40, I'm curled in a corner, covered in blankets crying like a baby. I've heard it gets colder, and frozen water falls out of the sky in great drifts. But that's crazy talk.
2014 500EXC Black
Old 02-04-2013, 12:09 PM   #15
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 395
It's warmed up a bit.. Now it's 26 but battery is still dead.
Maybe I should move to AZ or San Diego and be done with it...
Times are GMT -7.   It's 06:23 PM.
