Old 02-07-2013, 06:21 AM   #16
alongat
alongat's Avatar
Oddometer: 1,255
I'm at Bathurst and Eglinton in Toronto and ive got a 950adv - happy to come help you with the settings anytime. Feel free to email me at alongat.gat@gmail.com or text me at 416-930-7405
Welcome to the experience of having the best bike you'll ever own :)
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 02-07-2013, 09:07 AM   #17
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,874
Originally Posted by Northyork View Post
Thank you all for your replies.
I would like to give the stock suspension a try, play with the settings described on the label, and then decide.
Look, I know you're Canadian and all, but this whole "voice of reason" and rational thinking is really a killjoy.
Get with the program, here. This is simply not the place for careful, measured responses.
Throw money, fer cryin out loud!
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-07-2013, 09:36 AM   #18
crofrog
Oddometer: 1,455
I think the cheapest help for the front forks is to raise the oil level allot. Then do springs and start turning up the rebound once you add springs. It's a band-aid but it helps.
crofrog is offline   Reply With Quote
Old 02-07-2013, 10:00 AM   #19
alongat
alongat's Avatar
Oddometer: 1,255
Originally Posted by fakename View Post
look, i know you're canadian and all, but this whole "voice of reason" and rational thinking is really a killjoy.
lol :)
Toronto, Canada
Old 02-07-2013, 12:20 PM   #20
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 870
Springs
Who manufactures springs for my 06 950A?
I only have 10kkm on it. My valving is fresh. I plan to leave them alone and increase my rebound damping.
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 02-07-2013, 12:21 PM   #21
crofrog
Oddometer: 1,455
The stock rebound valving is inadequate for stiffer springs for the most part.
Superplush and racetech both have springs for the 950 as well as others.
Old 02-07-2013, 12:47 PM   #22
Marko888
Oddometer: 31
Northyork,
Start with Standard settings, and ride the bike solo, with no luggage, and get used to your new bike.
Leave the suspension alone until at least until you get past the first 1000km service.
If you are over 90kg, step up to those settings, and ride it solo for another 1000km.
After that, change it to Sport settings, and put another 1000km on it.
By the time you get to 3000km, and provided you rode basically the same roads on each setup, you should have an idea of how the different settings change the feel of the bike, and what you prefer.
Keep in mind, there is no perfect setting for all around use. For example:
SPORT will feel best going fast on smooth roads, but awful when slowly putting along a bumpy two track gravel road.
COMFORT on the other hand, will probably feel good on that two track (until you hit a pot hole and bottom the forks) but will feel wallowy and vague when going fast on that smooth pavement.
Here is some good guidance. Although this article is centred on a sport bike, the principles are the same.
http://www.visordown.com/workshop/mo...etup/2487.html
There is no magic settings between solo and fully loaded, that will make the bike feel the same. The bike will feel differemt loaded from light, regardless of suspension setup.
Generally speaking, with my own 950, which has the forks reworked from standard as I've described above, but a stock rear shock, going from solo riding, to two up travelling, I will increase damping by about 2-4 clicks all around to better stabilize the extra weight going up and down. I may also add shock preload to the rear spring to keep rear ride height similar.
cheers
Marko888 is offline   Reply With Quote
Old 02-07-2013, 12:50 PM   #23
Marko888
Oddometer: 31
Canadians can get springs from Riders Edge Suspension in Vernon BC.
+1 "The stock rebound valving is inadequate for stiffer springs for the most part." Agreed
Old 02-07-2013, 05:01 PM   #24
Northyork OP
Oddometer: 271
Originally Posted by Marko888 View Post
Northyork,
cheers
Thanks for the advice
Northyork is offline   Reply With Quote
Old 02-07-2013, 05:05 PM   #25
Northyork OP
Oddometer: 271
Alon, Thank you. I will PM you.
Old 02-07-2013, 10:09 PM   #26
orange spy
diddly squat
Oddometer: 33
80% of the improvement can easily be obtained without spending a lot of money. Stiffer springs in front and a bit thicker fork oil.
20% will come from taking it apart and re-shimming / re-valving it which is the expensive part. the added value of which, is not that recognizable to common riders.
I agree with Marko however. you need to get an idea of how the hole thing works first.
orange spy is offline   Reply With Quote
Old 02-08-2013, 09:31 AM   #27
FlyingDutchman
Dirt Biker
Oddometer: 870
One Change at a Time...Springs are 1st
Great, thanks.
I'll find out after I've sprung it to my needs. I've been around bikes and bike shops to know that doing more than one mod at a time will limit your actual knowledge about the effect of the modification.
Old 02-08-2013, 12:18 PM   #28
James Siddall
suspension guy
James Siddall's Avatar
Oddometer: 176
More like 50% and 50% in my humble opinion. Maybe 60/40
Cheers
James
www.superplushsuspension.com
Never argue with stupid people, they will drag you down to their level and beat you with experience.
James Siddall is offline   Reply With Quote
Old 02-08-2013, 12:38 PM   #29
FakeName
FakeName's Avatar
Oddometer: 1,874
Cheers
James
What- you're some sort of expert or something?
2014 500EXC Black
Old 02-08-2013, 01:19 PM   #30
DuctTape
Oddometer: 351
If that's the same James Siddall that makes his living running Superplush SUSPENSIONS then I'd say YES!!!!!! LOL.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Times are GMT -7.   It's 09:00 PM.
