Old 02-04-2013, 06:55 AM   #1
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,044
Manual airpump
Can you people suggest good manual (or foot) air pump for inflating tires?
Thanks,
Andrew
motogon is offline   Reply With Quote
Old 02-04-2013, 08:04 AM   #2
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
Here is a comparison of various pumps. http://www.twistedthrottle.com/origi...pump#pumpsizes
I carry one of those foot pumps, I have the two cylinder version. You have to be a little careful using them but they are small and work fine. I have had mine for many years.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 02-04-2013, 11:16 AM   #3
motorat
TBD
motorat's Avatar
Oddometer: 929
i have the same one.
it works pretty good and is compact enough to keep in a tank bag.
to ignore the facts does not change the facts
motorat is offline   Reply With Quote
Old 02-04-2013, 11:56 AM   #4
1P8RIOT
1P8RIOT's Avatar
Oddometer: 394
I got a small bicycle pump at wally world but I've seen them at Target too. It's labeled Bell brand like the helmets. The neat thing about it is that it pumps on both strokes. It works surprisingly well and was only $10
A ship in a port is safe but that is not what ships are built for. - Mom
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 02-04-2013, 12:21 PM   #5
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,556
I got a similar pump and found the hose end was unacceptable. The pump seemed fine, but that does little good when the valve stem connection does not seal. I have seen less expensive hand pumps with better hose ends than what mine came with. Maybe I just got a bad hose, but the design seems inferior to other air pump hoses. Granted, this is a $12.00 pump so I got what was paid. Someday I will try to replace the hose. Caveat emptor.
I think the Topeak Road Morph is a better pump (and costs more than twice as much): http://www.amazon.com/Topeak-Road-Mo.../dp/B000FI6YOS
Stan_R80/7 is offline   Reply With Quote
Old 02-04-2013, 12:43 PM   #6
avgas
amateur
avgas's Avatar
Oddometer: 83
I'll second the topeak morph. I've got the mini morph, but only because I wanted something smaller for cycling as well. It's small, light and has given me no problems for the four or so years I've had it. The flexible hose is awesome, it makes pumping up the tires so much easier than the hand pumps without them.
If you only want a pump for fixing flats, then it probably doesn't matter much. I often add some air for the road section home after a dual sport ride though, and I love the mini morph for how easy it makes it.
2012 Yamaha WR250R
avgas is offline   Reply With Quote
Old 02-04-2013, 02:32 PM   #7
P B G
Oddometer: 10,001
Thanks,
Matters what PSI you're aiming for, lots of bicycle hand pumps will do dirt bike tires, but they may not do higher PSI for road bikes.
Keep an eye on that.
Old 02-04-2013, 02:45 PM   #8
machinebuilder
Oddometer: 1,136
Road bicycles run MUCH higher pressures than any motorcycle i've heard of
I add a +1 on the twisted throttle foot pump, I've never had a problem with it sealing to the stem, and can take my 150-70/17 from 20psi to 35psi in about 3 min (if I'm slow)
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Old 02-04-2013, 03:44 PM   #9
P B G
Oddometer: 10,001
That they do, some of the hand pumps for bicycles are just rubbish and will not work for road bicycles or road motorcycle pressures, for instance I have a hand pump that starts to bypass at around 27 psi, very annoying after you spend 10 minutes trying to get up to pressure and it doesn't budge.
If you buy quality, no issue.
Old 02-04-2013, 03:46 PM   #10
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,044
Is that "twisted throttle" foot pump are stable when you pumping or required special balancing skills to use it on uneven surface?
Andrew
Old 02-04-2013, 04:24 PM   #11
motorat
TBD
motorat's Avatar
Oddometer: 929
i use it with my hand .
you could use the fold down part to stand on then step on the plunger, but i found just pushing down worked ok.
Old 02-06-2013, 08:54 AM   #12
twinjet
Oddometer: 306
I've been using a Zefal HP bicycle hand pump for years. The wife finally took pity and gave me a electric compressor for Christmas.
But the Zefal was doing the job.
twinjet is offline   Reply With Quote
Old 02-07-2013, 08:05 AM   #13
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
It would be very tricky to use on an uneven surface. If you step on it off axis it will tip over and twist up the little wire loop that you stand on with your other foot. Once you realize this limitation it works fine.
Also the fitting on the end of the hose is different than any other air chuck that I have seen, but once again, it is OK after you get used to it.
Old 02-07-2013, 08:23 AM   #14
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,550
I have a 12 volt pump but I also have a bicycle hand pump in my hydration pack. Never had to use it but I bought quality for my bicycles and have no concerns about its ability to go mc tires.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Times are GMT -7.   It's 11:48 PM.
