Old 02-04-2013, 08:20 AM   #1
winnrider OP
winnrider's Avatar
Oddometer: 47
Aerostitch boot strap help
While slogging through some deep Louisiana gumbo mud this Saturday, I slammed into a log with my Combat boots. They did their job protection-wise. But I cracked the plastic latch strap. I ordered a new set from Aerostitch but was told that they have been on back order for over six months and SIDI won't make anymore until they get a large enough order. He had no suggestions for a workaround.
Any suggestions on how to repair would be appreciated as I don't have the fundage to buy a new pair of boots at this time.
TIA
winnrider is offline   Reply With Quote
Old 02-04-2013, 08:25 AM   #2
acejones
acejones's Avatar
Oddometer: 3,309
If you are in central Louisiana as I suspect, you might need to go over to Alexandria and find a boot/shoe repair shop. Maybe they can help.
If I wasn't here, I'd be somewhere else
acejones is online now   Reply With Quote
Old 02-04-2013, 08:26 AM   #3
Wlfman
Wlfman's Avatar
Oddometer: 869
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-04-2013, 08:29 AM   #4
catalina38
Contrarian
Oddometer: 1,410
Pictures of the strap?
Born 10,000 years too late
Scientific Wild Ass Guesser:hmmmm
catalina38 is offline   Reply With Quote
Old 02-04-2013, 08:34 AM   #5
winnrider OP
winnrider's Avatar
Oddometer: 47
only have the metal latch. the plastic part is in a muddy grave. sorry no pics.
Old 02-04-2013, 10:51 AM   #6
BeachMoto
BeachMoto's Avatar
Oddometer: 588
Being where you are this might be tough to do but most ski boots use similar buckles and spare parts are widely available. You may want to check in to it.
1970 Honda SL100 (my 1st bike in 1972)
1972 Yamaha Enduro 360 (loved this bike)
1977 Yamaha RD 250
1978 Suzuki 250TS
1982 Kawasaki GPZ 550
2007 BMW F800ST
2009 BMW R1200GS (Current)
BeachMoto is offline   Reply With Quote
Old 02-04-2013, 11:28 AM   #7
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 282
I have this same set of boots. The strap is plastic with metal on the end. Depending on the type of plastic, it may be weldable (i.e. a thermoplastic), or can be solvent welded (such as ABS). The trick is figuring out the type of plastic and if using a solvent or heating is an option.
One approach is to take some acetone and see if it dissolves the strap plastic. Obviously this needs to be done on the back of the non-used end. If so, some black ABS pipe or Lego's building blocks can be dissolved in acetone to make a repair glue. If you have access to a hot air gun or a hot air soldering torch, the same location on the strap can be heated to see if it melts and can be welded. I think the strap is ABS, but am not certain.
It's unfortunate the Aerostich does not have the straps, buckles, or strings for these boots. Maybe they will again one day. Good luck!
p.s. I back ordered a set of straps and buckles, so that is one more set to their SIDI order. Granted they are good boots, but having spare parts is one of the reasons I ordered the boots. I think they should order some parts to keep in stock if they are advertising they have them. Either that, or make it clear the parts are only available through special order.
Stan_R80/7 screwed with this post 02-04-2013 at 11:35 AM
Stan_R80/7 is offline   Reply With Quote
Old 02-04-2013, 11:53 AM   #8
winnrider OP
winnrider's Avatar
Oddometer: 47
Thanks, Stan. I agree. When you pay the $$$ for these boots, which are designed for heavy duty use, you would think they would have some spare parts saved in reserve. Probably end up going the duct tape route. Not fashion conscious.
Old 02-04-2013, 12:22 PM   #9
catalina38
Contrarian
Oddometer: 1,410
The SIDI straps are available from other sources, try some of the big online dealers.
I have a few brand new spares that don't fit any of the boots I currently have, they are the one inch wide type. I'll see if I can find them. Call Motonation directly. http://www.motonation.com/
Old 02-04-2013, 12:35 PM   #10
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 282
I have yet to find a SIDI strap that works on the AS combat touring boot - but would sure like to see one. Here is the link to the Aerostich site that shows what they look like: http://www.aerostich.com/clothing/fo...ot-straps.html
The SIDI straps are different and it seems the CTB is custom made for Aerostitch.
Old 02-04-2013, 01:03 PM   #11
Wlfman
Wlfman's Avatar
Oddometer: 869
Try these from SIDI-- http://www.motorcycle-superstore.com...-TA-Strap.aspx
Old 02-04-2013, 01:12 PM   #12
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 282
Originally Posted by Wlfman View Post
Sure looks like them. I expect these will work. Thanks for the heads-up.
Old 02-04-2013, 01:14 PM   #13
catalina38
Contrarian
Oddometer: 1,410
I have a few that look identical from some other SIDI boots some are wide and some narrow. Since you tried the SIDI straps and they don't work with CTBs, I'll keep that in mind when finding a new owner for my spare straps.
http://www.motonation.com/store/pc/v...idcategory=102
Old 02-04-2013, 01:16 PM   #14
winnrider OP
winnrider's Avatar
Oddometer: 47
thanks what I'm looking for. Thanks to all.
Old 02-04-2013, 02:37 PM   #15
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 282
The link to motonation has the short version of the strap needed. Motorcycle superstore only has long. Thanks.
I was mistaken about the CBT boots not having regular SIDI straps (albeit not current ones). Details are important and SIDI makes quite a few straps.
It is fairly annoying that Aerostitch can't figure out how to get these straps when two other stores sell them. I guess this is not an important customer support item to them.
Stan_R80/7 screwed with this post 02-04-2013 at 02:46 PM
Times are GMT -7.   It's 02:59 PM.
