02-08-2013, 04:40 PM
#61 | |
Running Free
Oddometer: 7,136
Every ride is an adventure ![]() http://www.youtube.com/watch?v=OuKeu...feature=relmfu http://www.youtube.com/watch?v=rYqF_BtIwAU "Can we get a party to finally represent us?" - Cenk Uygur |
02-08-2013, 04:42 PM
#62 |
Not afraid
Oddometer: 11,419
I looked into getting the elastic cord, and buckles and such from strap works, and some other places, it really didnt seem much cheaper than just buying Rok straps.
I still havent bought any though, I use cheap bungees 99% of the time.
"A little inaccuracy sometimes saves a ton of explanation." - H. H. Munro (Saki) (1870-1916) |
02-08-2013, 07:05 PM
#63 |
Oddometer: 1,039
I like bungee cords. The thick ones, 1/2 inch diameter. They are inexpensive, readily available at most good hardware stores, and easy to use. They work well when used right.
![]() ![]() ![]() ![]() Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
02-08-2013, 07:16 PM
#64 |
El Adventurero Solitario
Oddometer: 3,047
I use piggyback straps
http://http://piggybackstraps.com/ Here is a write uphttp://www.mklsportster.com/Articles/mcnpiggyback.pdf
eap '01 R1150GS, Chesapeake Bay Watershed, Surf Your Watershed Save the Bewbies "Over the Mountains Of the Moon, Down the Valley of the Shadow, Ride, boldly ride," -From 'Eldorado', Edgar Allen Poe (1849) http://www.eapoe.org/works/poems/eldrdoa.htm |
02-08-2013, 09:13 PM
#65 | |
"Cool" Aid!
Oddometer: 41,915
![]() Jim
02-09-2013, 05:26 AM
#66 | |
Lampin' it
Oddometer: 4,231
Here's the difference. You are carrying a 100lb toolbox with the straps just to keep the load from shifting right? I use NRS straps to hold my cataraft together. And when that raft tips over and the hydraulics of a hole strong enough to flip an experienced rafter take over, the forces are severe. I can tell you I have had my specialized guide jacket ripped off because the zipper failed and my shorts ripped off because, well my waist failed in one really bad hole. I was underwater for at least 30-45 seconds getting the crap beat out of me. By the time it was done I felt like I had done 9 rounds with Holyfield and never landed a punch. here's a typical cat setup (not my pics) ![]() and what happens when you "hiside" ![]() ![]() Cat was bouncing happily downsteam no drama. The drybags probably weighed 50lbs each and I had 2 or 3 secured with one strap. Here's how much I trust NRS straps. I had to do a waterfall rescue years ago, and it was a split decision type of thing where 3 of us guides had to get to someone sorta drowning very quickly. I needed to rappel down about 30' of rock. The only equipment we had was a few NRS straps, 5 carabiners, a pulley and a 75' rafting throw bag of 1/2' line. We used the strap to hook around the tree, carabiner to the pulley and I made a swiss seat from the other strap and used the line to rappel down the rock face. I have 2 NRS straps I am trusting my life to. Still have both and use both 10 years later. I'm sure the Roc Straps are great, but I use what I know. In response to gear flying off peoples bike, that doesn't happen to me. And it doesn't happen for a good reason. Anything that won't fit in my panniers, doesn't come. I'm constantly amazed at the luxo barges that roll into ADV rallys for a WEEKEND campout with gear lashed on all over the place. I've done two weeks of remote camping in Maine with nothing other than what I can fit in my bags. The only thing I strap on is a flyrod or something. I've refined my camp setup to include things that don't take up space because I don't like the liability of duffels hanging out for the safety reasons mentioned. Anyways it sounds like there are a lot of Rok Straps fans so they must be excellent. I have not tried them because I have had a system that has worked for me over multiple applications over the years. I think people need to learn how to pack efficiently that way they wouldn't need so much reliance on straps of any kind or maybe a small duffel etc. JMHO
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
02-09-2013, 05:43 AM
#67 |
Oddometer: 21,708
I use a Bison strap, pretty much the same thing as the NRS strap, but the cam has a large carabiner integrated into it and the webbing ends are sewn into loops.
One end gets a girth hitch around a frame rail, the carabiner gets clipped to another frame rail, the strap is tensioned and bitter end secured. I use the compression of the load (or in the case of a hard object, compression of the pillion seat its sitting on) to keep everything from wiggling. ![]() ![]() ![]() Also handy for holding the GS in stinkbug while doing transmission/clutch work.
02-09-2013, 05:48 AM
#68 |
Lampin' it
Oddometer: 4,231
I love all the proper nautical terms
02-09-2013, 06:02 AM
#69 |
Oddometer: 21,708
02-09-2013, 06:56 AM
#70 |
Lampin' it
Oddometer: 4,231
Hear ya. I routinely refer to the back of my bike as the aft end
02-09-2013, 08:24 AM
#71 |
Oddometer: 21,708
02-12-2013, 09:13 PM
#72 |
Giddy up
Oddometer: 608
http://www.andystrapz.com/products.p...yId=17&Level=1 Have a look at these, made by a one-man operation called Andy Strapz here in Australia. The 2" wide velcro holds very well. The hand loops enable you to get good tension. The webbing is nowhere near as stretchy as bungee rubber so it holds very firmly without having to stretch the living crap out of it. Here is an extreme application (my first time on a 2-up long distance adventure) ...I didn't know any better. That's his and hers bedrolls on the top of the panniers. ![]() And here is more more usual arrangement ![]() I have no commercial connection with Andy, but have always found him a top bloke to deal with, and his stuff works. Cheers Tim
I have come to accept that my role in life is simply to serve as a warning to others. |
02-12-2013, 11:58 PM
#73 |
de-composer
Oddometer: 382
Full size rok straps for the large duffel but I just got a set of the smaller skinnier rok straps that are perfect for holding a 30 liter dry bag that I keep on the bike for tools, rain gear and layers.
02-13-2013, 12:47 AM
#74 | |
Oddometer: 2,713
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
02-13-2013, 05:53 PM
#75 |
de-composer
Oddometer: 382
yeah I wouldn't use the skinny Rok Straps to repel from the passenger pegs to the ground, but they seem to hold my drybag on.
