02-04-2013, 04:26 PM
#1 |
Oddometer: 235
Question about advmonster lights
Hi all - I recently removed a set of denali d2 lights from my KLR650 and installed them on my ninja 250. This left me sorely lacking adequate lighting on the KLR. I was thinking about ordering a few model 30 spots to install up on the D2 fairing mounts. The model 30 because it's a spot and I felt, less likely to blind other drivers. Another option is to install some model 60's, or a model 30 and a model 60. Either up on the fairing or down on the forks (using the screw holes for the reflectors by the brake caliper). I use the klr for 70% commuting to work (dark both ways, usually) and don't want to blind anyone, but I want to be seen, and I want to see. The model 60 is probably *way* too bright for my use, right? I like the idea of 3600 lumens, but without actually having one to test it's really hard to determine just how bright that really is. Any input would be great; I was even thinking about mixing a model 30 spot on the left side and a model 44 on the right side, to get fill and distance, without blinding oncoming drivers (on the left).
I buy all my stuff at motorcyclegear.com, formerly newenough. |
02-04-2013, 08:39 PM
#2 |
Disgruntled Student
Oddometer: 1,575
I have two model 30s mounted on my forks. I run them at all times. They are bright and bother other drivers a bit (I've been flashed at a couple times, but not too often). From the position of oncoming drivers, the lights are substantially brighter than the low beams. However, they're not as blinding as the high beams.
02-04-2013, 09:40 PM
#3 |
Westside Trash
Oddometer: 723
Easy Fix
Buy two of the model 60's and a dimmer from: http://www.lights.skenedesign.com/IQ_175.shtml I know blackdog cycle works sell these for about 55 bucks. Well worth it and super simple to install and program.
I run this set up with my model 60's set at 40% while on low beam. When I hit the high beam... they fully light up at 100%, which will amaze you when comparing to your stock lights ![]() I have never been flashed in the low beam setting ![]() You definitely wont regret the purchase ![]() Just do it !!! P.S. ( no connection to advmonster, other than my purchase ) |
02-04-2013, 11:04 PM
#4 |
Oddometer: 120
Will they work well as a replacement for the low beam? I've been eyeing the fairing that uses the model 30 or 60.
02-05-2013, 10:33 AM
#5 | |
Westside Trash
Oddometer: 723
Way more light, which translates into WAY more visability for you, as well as in the other folks on the road noticing you. As I mentioned, with the dimmer from skene designs, you are able to program the level of brightness to whatever intensity you want. The settings available start at 10% of the maximum capability of the light, and you choose in 10% increments just how bright you want it. Programming it is VERY simple. |
02-05-2013, 10:37 AM
#6 | |
Oddometer: 235
I'm worried bright + high mounted mike be more irritating than bright + low mounted. thanks for the input!
02-05-2013, 02:00 PM
#7 |
Westside Trash
Oddometer: 723
They are on a Super Enduro KTM. I have mounted them on a fender/tripletree mount (blackdog cycleworks), and a bit higher up with my custom set-up.
To be clear..... DO NOT worry about them being too bright. Using the dimmer, you can make them as dim as you want.... |
02-05-2013, 02:09 PM
#8 | |
Oddometer: 235
I'll program a PWM LED controller and order some model 60's - thanks!
02-05-2013, 02:14 PM
#9 |
Oddometer: 120
Good to hear. Sounds like they can also be aimed so that they work as low beams and don't annoy other drivers.
02-05-2013, 02:17 PM
#10 |
Oddometer: 235
yeah - being noticed is one thing, but irritating drivers doesn't do anything to help me, or motorcyclists in general.
02-05-2013, 07:51 PM
#11 |
Oddometer: 447
I'm also considering the Model 60 / 3600 Lumen leds. At night if you adjust the dimmer to a setting that doesn't blind oncoming drivers, do they project far enough down the road to give you good visibility at 60-65mph compared to spots (which have lower output)? I'm not sure whether to go with these or the spots.
Tiger 955i / DRZ400S < FJR1300 < DL1000 < BMW R1100RS < Ducati ST4 < DL650 *** 30+ years *** 125 Honda Elsinore < Suzuki TM250 < Yamaha 90 Enduro < Taco |
02-06-2013, 06:32 AM
#12 | |
Westside Trash
Oddometer: 723
They project plenty far on the lower settings, way better than your current low beams. Remember, you can position the light beam in a manner that is unobtrusive to oncoming traffic. I have never been flashed by oncoming traffic with my 40% setting. That setting is wayyyy better than my stock low beam. Dont overthink this one fellas...you won't believe what you have been missing. There are other manufacturers out there as well, I am not a schill for advmonster, follow your instincts. I am just pleased with my purchase, they are just great lights for the cost, IMHO |
02-06-2013, 09:27 AM
#13 |
Oddometer: 447
many thanks pdfskipper... that's what i needed to know to make my decision...
