Old 02-11-2013, 08:33 AM   #31
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,144
Originally Posted by Laconic View Post
If you have a Machinery's Handbook, there's a good discussion of how o-rings are supposed to work.
Gland/groove depth should be 80% of o-ring cross section and 50% wider. You probably knew that, but I like reading the handbook.
I obviously did NOT know that so thanks!! I'll measure the o ring and have at it.
+1 on McMaster. I order from those guys all the time. The website is way better than Grainger so I usually order from them. Plus they are next day delivery being in Cleveland and shipping is always very reasonable.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 02-11-2013, 10:08 AM   #32
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,144
Didn't want to get any closer to the threads. O ring fits in there perfect and I did make it 80% depth of O ring
Nessmuk
Old 02-11-2013, 10:30 AM   #33
Laconic
QuestionableBanterer
Laconic's Avatar
Oddometer: 10,529
Sweet! That will never leak.
Laconic is offline   Reply With Quote
Old 02-11-2013, 11:08 AM   #34
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,144
Have you seen my welding?
Thanks for the tip
Nessmuk
Old 02-13-2013, 08:29 PM   #35
xcflyn OP
xcflyn's Avatar
Oddometer: 1,093
new project- one for me. This will be hard to believe but my water jet has no jet on timer. The solenoid is a 24V so I decided to mount a timer on the unit and first task is to make a mount, simple : well nothing I do is simple and it seems when ever I take time to do something for myself I hurry and shortcut. This time will be no different.
Down to business -
Start on my piece of scratch paper and then set up to cut-
fast forward to check fit
little bit of brake work
Well the last two hits are going to require a heavy off set (gooseneck) punch to reach in and give clearance for those ears - not those ears - the ones on the ends
Of course I dont have a punch that is that narrow with that much offset - so a new project is started - make a punch
starts with this -
A few heavy hits and a tool is born - almost - needs more work to fit the holder but it looks like it steps over far enough.
I think it will do the job, I will finish up on it tomorrow or on the weekend.
xcflyn is offline   Reply With Quote
Old 02-14-2013, 07:20 PM   #36
xcflyn OP
xcflyn's Avatar
Oddometer: 1,093
Then the tool needed a holder
Now it can bend
weld the edges
And you have this- just needs a back piece made
I had hoped there would be more contributions to this thread. I am interested in what others are making
Old 02-14-2013, 09:18 PM   #37
MikeinEugene
MikeinEugene's Avatar
Oddometer: 1,845
While I'd like to see others posting up their projects too, please don't abandon what you're posting now. I'm really enjoying it
MikeinEugene is offline   Reply With Quote
Old 02-15-2013, 03:55 AM   #38
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,637
You guys are doing some excellent work! Thanks for posting up your pics! I've been learning a lot by just following along.
kirkster70 is offline   Reply With Quote
Old 02-15-2013, 04:32 AM   #39
Benesesso
Benesesso's Avatar
Oddometer: 8,501
Viton?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-15-2013, 04:50 AM   #40
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,144
It's the stock one from the ninja, no idea sorry
Nessmuk
Old 02-15-2013, 04:54 AM   #41
phreakingeek
phreakingeek's Avatar
Oddometer: 70
awesome
You guys are doing some very cool stuff! Thanks for posting the step-by-step pics.
btw, did anyone identify the vent looking part?
phreakingeek is offline   Reply With Quote
Old 02-15-2013, 06:02 AM   #42
jar944
jar944's Avatar
Oddometer: 344
Tent stove out of scrap laying around the shop, has an adjustable bypass damper built in.
Cable operated decomp for a cr500, really needs a proper bracket and attachment method.
jar944 screwed with this post 02-15-2013 at 06:10 AM
jar944 is offline   Reply With Quote
Old 02-15-2013, 10:02 AM   #43
jar944
jar944's Avatar
Oddometer: 344
Machining a swingarm for a engine swap
Tool to bore and face the swingarm
Old 02-15-2013, 11:18 AM   #44
xcflyn OP
xcflyn's Avatar
Oddometer: 1,093
That d-comp is a work of art ! The bracket should be the easy part.
I looked at that stove and thought " man you could heat a house with that", I bet you get a tent mighty cozy
Thanks for the post !
Old 02-16-2013, 12:42 PM   #45
jar944
jar944's Avatar
Oddometer: 344
went to start on a set of cr500 swingarm extensions this morning, started to move my bandsaw and promptly broke off the lower guide:
briefly contemplated buying a much larger saw, but decided against that. i figured i could machine up a new guide, but how to cut the stock with out a saw..
Being lazy I just cleaned up what was left of the guide in the mill
stock cut to length, top of the guide machined, and the other half of the broken guide
new lower section being machined
marked and center drilled
drilled
tapped, and bolted together
Times are GMT -7.   It's 03:47 AM.
