Old 02-05-2013, 02:52 AM   #1
DuctTape OP
Oddometer: 351
My 990 suspension Adventure
I know that many owners of the KTM 990 send out their suspension to places like The Best KTM Motorcycle Suspension Possible: Super Plush Suspension Slavens Racing and others and they do a very good job of improving the stock suspension.
The only problem that I see with doing this is your suspension will be a compromise. A well setup suspension for the desert will be terrible on a slow one track and the same goes for rocky terrain. I want the ability to tune my suspension for the terrain I'm going to be riding in and since work precludes any traveling this year the journey begins.
These are the parts and special tools I'm using for the Job and I'm sure the first question most people will have is the cost.
So here's a price list.
Race Tech Suspension Bible: $23 Amazon
Race tech Gold Valve Fork Kit G2-R Gold FMGV 2820G: $128.41 Amazon
Super Plush Fork Springs spsf43-465--65: $144,95 KTM Twins
G2 remote fork bleeder system: otf-ktm $69.95 KTM Twins
Simrestacker software: $63 http://www.shimrestackor.com/index.htm
Digital Micrometer
Digital Caliper
Ktm Hard equipment Fork cap removal tool: $24.99 KTM Twins
Race tech Fork seal tool 48MM $63.28 Amazon
Race Tech Fork Oil Level Tool $111.29 Amazon
SKF Fork Seals:
$67.50 Slaven racing
Fork Bushings: $48 Slaven racing
Fork oil as needed. Red Line 5w $9.95 a pint
The forks haven't changed since 2003 so the manual you'll need for disassembly and assembly will be a 4860 MX multi Adjuster 2003. This is the manual that came on the CD for my 2011.
The manual says to count the number of turns to the right of both the Rebound on the top of the fork and the compression adjuster at the bottom. What it doesn't tell you is you'll need to turn all four of the adjusters back to the left all the way to take the tension off of them.
When it comes to disassembly of the compression holder at the bottom of the fork an impact wrench is the way to go. The other thing I found was that when it comes to disassembly my Rockwell vice worked great since it has rubber jaws! I did have to borrow the Queens little rubber cap remover from the kitchen to keep the cartridge tube from turning while unscrewing the sleeve. (Hope she doesn't miss it too much, LOL)
Anyway if all you want to do is change out the seals and bushing you don't even have to mess with the cartridge.
I'm ready to remove and measure all the stock shims so I can get a baseline from the restacker software and input all the data for the new valve and springs and see what it suggest.
For those of you into dyno tuning www.valvinglogic.com provides an easy way to obtain accurate dyno data for the customized shim stack configuration the restacker software comes up with. Email your stack configuration to www.valvinglogic.com , they will install the stack in their suspension hardware and for about $60/stroke dyno test the stack and email the results back to you. No hardware shipping, no down time, no missed rides. Valving logic provides an easy method to obtain accurate dyno data for your suspension setup and something I may just do to prove to my pee brain just how well the restacker software really works.
Well guys and girls that's where I am as of today and like I said in the beginning I'll be playing with this all year so if anyone is interested I'll update this thread as I go.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape screwed with this post 02-05-2013 at 03:24 AM
DuctTape is offline   Reply With Quote
Old 02-05-2013, 02:52 AM   #2
DuctTape OP
Oddometer: 351
Just taken up space for future info.
2010 Ducati 1198S
Old 02-05-2013, 05:07 AM   #3
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,874
Subbed.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-05-2013, 09:23 AM   #4
Azmontana
Oddometer: 31
Very interesting, keep up the good work.
Azmontana is offline   Reply With Quote
Old 02-05-2013, 12:48 PM   #5
Hipster
Hipster's Avatar
Oddometer: 1,815
Duct Tape,
How did the Shim Stacker software like Race Tech's standard shim stack?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 02-05-2013, 04:33 PM   #6
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,057
In.
Just had the SPS treatment and very happy with it, but will obviously be looking to record optimum peronalized settings for the various types of rides I intend to make and loads I expect to carry. So this is all good stuff.
I also dig the tidiness of your prep work and the [perhaps contradictory] way you didn't even feel the need to take your Kriega pack off the back of the bike to do the work!
Thanks for taking the time to post.
Michael
P.S. Enjoyed your Flexx bars install piece too. I'll be doing mine in the next week or so.
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 02-05-2013, 05:23 PM   #7
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,168
I'll be watching this with interest. I did a little of my own experimentation, and I was/am quite happy with it (Link Here). If you're using the shim restacker software, I'd be interested to see how the shim stack I ended up with compares with what you end up with, and how it compares to stock and some other stacks I have records of. I keep the fork valving up to date on the google document I linked in that thread.
What sort of fork feel/usage are you going for? I like a pretty stiff fork, with plenty of compression damping, and not much plushness, I like to feel what the terrain, and preserve suspension travel for the big hits, without the front end moving around too much on little bumps. Figuring out what you're looking for will help immensely, and it sounds like that's something you've already thought about.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 02-05-2013, 09:25 PM   #8
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
how do you think he has the front of the bike up without a front wheel ?
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 02-06-2013, 09:49 AM   #9
amanlikemike
Oddometer: 1,057
Ooooohhh yeah...
Just kinda assumed tie-downs were involved. Now that you mention it, I guess that explains the sack of fertilizer or wherever on there too.
'Ave it.
BritKit LLC
Old 02-06-2013, 04:09 PM   #10
pvmoto
Instagram @ pvmoto
pvmoto's Avatar
Oddometer: 330
Ductape. How did you mount your rigids with the high front guard?
Instagram@pvmoto
Instagram@ pvmoto
pvmoto is offline   Reply With Quote
Old 02-07-2013, 07:44 AM   #11
Chinookmark
Oddometer: 302
Subscribed
Chinookmark is offline   Reply With Quote
Old 02-07-2013, 05:13 PM   #12
DuctTape OP
Oddometer: 351
Cool, like I wrote work is going to take up this year so my suspension work/testing will be done on the weekends so please bare with me.
I'm 6'2" and with all my gear on including my hydro pac filled weigh 200LBS. I run a tank bag that weighed in at 17LBS not including my Snake Slayer, ammo and Binochulars so lets round it up to 220 LBS. I'm going to be adding the Safari Tanks so I'll be testing and setting sag with the stock tanks full.
The only time I ride on the street is to get fuel so I'm not going to concern myself with street behavior but rather the very rocky terrain with gulleys hidden by tall grass that I spend most of my time riding at. This environment produces very high velocities so this is where I'm going to start. Today I started making a little test coarse with some old 4X4 and 6X6 scrap post that I'm going use for the square edge bumps and as long as the drought continues I have a dry creek bed that has enough gulleys to test for bottoming.
I've had your thread bookmarked for a few months now and it was one of the main deciding factors when I decided to do this myself, so thanks for that!
The thing that sold me on the restacker software is that it's advertised by them (The bottom of every page) that posting/sharing of all their information online is legal and encouraged as long as they are given credit. So anyone that has a shim stack that they would like to see ran by the software just give me a shout and I'll need to know if you're using the stock valve or not (Spring would be nice too) since part of the equation are the area of the ports and one of the things I'm going to be measuring Saturday.
Once again I'm no expert so I encourage everyone to not hesitate to chime in.
Instagram@pvmoto
The mount is Black Dog Cycle Works mount. You have to grind down the front of the mount in order for it to fit in the groove on the high fender and then you need longer bolts to make up for the mount thickness. If you don't have a grinder you could take the mount and fender down to your local mechanic or body shop and I' sure they could fit it for you. (the mount is hidden by the fender so neatness doesn't matter).
In.
Michael
Glad to help and man those bars really make a difference but I have had to relearn how to get the bike up on the centerstand, LOL.
As for my Kriega tail bag that thing never comes off the bike. I have all my emergency gear in it and love the ease in which I can get stuff in and out of it. I bought some shaving kits (minus the shaving stuff) at Walmart and used them to create a first aid, electrical and flat tire kits with. Throw in the slime compressor, tire Irons, a couple of tubes and extra base layer clothing in another dry bag and I'm well prepared.
2010 Ducati 1198S
Old 07-26-2013, 04:56 AM   #13
1coolbanana
1coolbanana's Avatar
Oddometer: 1,459
Been waiting waiting waiting patiently............hows it going ??
Cowabunga dudes................Wuuuuka Wuka
2012 990 R
2004 950 A..........sadly missed
1coolbanana is offline   Reply With Quote
Old 07-26-2013, 06:22 PM   #14
990west
Oddometer: 28
Can i ask, what size kriega is that? I am thinking of going this way myself.
990west is offline   Reply With Quote
Old 09-20-2013, 06:24 PM   #15
GrenDesb
Oddometer: 331
Any update?
GrenDesb is offline   Reply With Quote
Times are GMT -7.   It's 10:33 PM.
