Old 02-05-2013, 08:41 AM   #1
Shooby OP
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
Mo-Door.com - Stand alone Garage door opener (No wiring!)
Mo-door.com
Here's their site intro:
"The smallest independent garage door remotes available for Motorcycles. Because our product is a standalone unit there is no hard wiring to the motorcycle and installation is done in less than 10 minutes! No more getting off your bike or fumbling with bulky devices that were created for your car. Simply just pull in!"
$80 - Small Wallet sized unit with Military spec switch. Paired it up to my garage opener, installed the unit under the seat, Adhered the switch in super stealth locale behind a frame rail. Total install time - About a 1/2 a beer. Range is about 100ft (max). Runs on standard 2032 battery, claims 5 year +/- operation before battery needs replacement. Had it for a month, works great. I'll update as to battery life in a few years.
Shooby screwed with this post 02-05-2013 at 08:41 AM Reason: typo
Shooby is online now   Reply With Quote
Old 02-05-2013, 09:31 AM   #2
KingOfFleece
SplitWeight(tm)
Oddometer: 837
Just what I need. I'm out rain riding doing product tests all the time. The only part I don't like is taking the gloves off to open the door.
I'll let you know who it works-but not now. There's 25" of snow right now.
www.kingoffleece.com
rated 5 out of 5 Stars in June 2012 MCN
KingOfFleece is offline   Reply With Quote
Old 02-05-2013, 10:10 AM   #3
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,441
Seriously?! $80 for a garage door opener? This $39 opener works fine for me. And you can use the same double-sided tape as that $80 opener to mount it somewhere "hidden" on your bike.
http://www.amazon.com/LiftMaster-Gar.../dp/B000FQ0T3C
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 02-05-2013, 10:31 AM   #4
SgtDuster
SgtDuster's Avatar
Oddometer: 3,369
So they take a 15$ garage door opener, a piece of wire and a button...relocate the button outside and then call it a "motorcycle stealth garage door opener" and ask 80$ for it?
Brilliant!
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is offline   Reply With Quote
Old 02-05-2013, 10:38 AM   #5
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,018
Why the heck not? I bet they sell a ton of em :)
It solves a problem that people with disposable income would rather have solved for them... not really much different than "flash2pass"
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 02-05-2013, 10:42 AM   #6
ParaMud
ParaMud's Avatar
Oddometer: 628
I just put mine in my jacket pocket and I can press the opener through the jacket with my gloves on.
08 wr250r
04 xt225
ParaMud is offline   Reply With Quote
Old 02-05-2013, 10:43 AM   #7
KingOfFleece
SplitWeight(tm)
Oddometer: 837
Flash to pass or whatever it is needs to be spliced in. I'll never do that. Seen too many splices fail. Yes, I'm well aware that nobody else EVER had a splice fail and all that. Good enough. Many years as a pro SCUBA diver have proven to me another way. As for the lift-master somehow I've lost two of them. Gonna try another way.
Old 02-05-2013, 10:46 AM   #8
SgtDuster
SgtDuster's Avatar
Oddometer: 3,369
3$
12$
A solder iron, a pair of cutter and 10 minutes of job and it's done.
2010 Buell Ulysses
Old 02-05-2013, 10:49 AM   #9
SgtDuster
SgtDuster's Avatar
Oddometer: 3,369
What the hell splicing a wire or two on a bike and scuba diving have in common?!
2010 Buell Ulysses
Old 02-05-2013, 10:52 AM   #10
MrHix
MrHix's Avatar
Oddometer: 384
I just took one of the handheld remotes, wired a Radio Shack switch to the contacts, mounted the unit with velcro, and put the button here (the button by the key):
Fairly cheap.
Cheers,
MrHix
MrHix is offline   Reply With Quote
Old 02-05-2013, 11:03 AM   #11
Shooby OP
Anti-Cager
Shooby's Avatar
Oddometer: 1,008
All good stuff. "Disposable" income is relative.
Old 02-05-2013, 11:14 AM   #12
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,424
The best part about threads like these is learning all the other ways to skin a cat
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 02-05-2013, 06:29 PM   #13
tlwood99
Oddometer: 165
+1!
tlwood99 is offline   Reply With Quote
Old 02-05-2013, 06:30 PM   #14
tlwood99
Oddometer: 165
Fairly cheap.
Cheers,
MrHix
Can you post a larger pic so that we can see what you did?
Old 02-05-2013, 07:53 PM   #15
MrHix
MrHix's Avatar
Oddometer: 384
I'll try and post a better pic tomorrow.
Cheers,
MrHix
Times are GMT -7.   It's 01:38 PM.
