Old 02-05-2013, 05:26 AM   #1
cat OP
cat's Avatar
Oddometer: 1,291
How to make neat holes in airbox?
Can i use a hole punch or would it crack the plastic?
A sheet metal punch, the kind that you drill a pilot hole and then tighten the tool and...?
cat is offline   Reply With Quote
Old 02-05-2013, 05:27 AM   #2
eddie bolted
Oddometer: 1,756
Hole saw.!
If it stops raining now, i,ll be pissed!(BEANTOP)
eddie bolted is offline   Reply With Quote
Old 02-05-2013, 05:34 AM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,504
Why are you putting holes in the airbox?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 02-05-2013, 06:19 AM   #4
It'sNotTheBike
Oddometer: 704
Probably because the OP imagines the trained engineers who designed the air intake
botched the job, though those engineers had access to a dyno and more than likely spent
many hours making sure the airflow was optimized for the resonant cavity of the air box,
( think of Helmholtz and you will be on the right track).
How likely is it that the engineers did a bad job and someone who needs to ask how
best to cut holes in the air box will do a better job ? Sort of like leaving an orangutang
in front of a typewriter and waiting for the sonnets of Shakespeare to be produced
( don't hold your breath waiting for anything intelligible to come out of that typewriter ).
It'sNotTheBike screwed with this post 02-05-2013 at 06:26 AM
It'sNotTheBike is offline   Reply With Quote
Old 02-05-2013, 06:25 AM   #5
Wlfman
Wlfman's Avatar
Oddometer: 869
1in putty knife. Heat the blade and it melts right thru the plastic making nice straight lines.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 02-05-2013, 06:28 AM   #6
It'sNotTheBike
Oddometer: 704
You shade tree wannabe "tuners" will have that air box working "right" in no time ... LOL !!!
Old 02-05-2013, 06:39 AM   #7
groundrules
groundrules's Avatar
Oddometer: 874
you don't sound as smart as you think you sound.
groundrules is offline   Reply With Quote
Old 02-05-2013, 06:58 AM   #8
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,753
Your right,it seems like a great idea to swiss cheese your airbox,till that first real dusty ride and the filter plugs or passes dirt. Or you just cant quite get the jetting right no matter how much you mess with it,or the new noise produced makes you crazy.
Its fun to second guess engineers though.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is offline   Reply With Quote
Old 02-05-2013, 07:41 AM   #9
groundrules
Oddometer: 874
you guys really think every bike shipped from the factory is tuned for maximum performance, or do you think the engineers in question might have had to consider factors like fuel economy or emissions standards or rider-friendly power delivery, or a hundred other factors? I've owned two bikes where airbox mods were a well-documented and much-utilized improvement. It happens.
now, back to the original question: step drill for small holes.
Old 02-05-2013, 07:59 AM   #10
kubiak
Oddometer: 4,136
i havent tried it yet but try a piece of metal pipe the diameter you need and heat the end and push it through the plastic. maybe try it on a extra part first though.
Old 02-05-2013, 08:10 AM   #11
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,080
CORRECT!
It's easy to be a smart ass, it's hard to actually use your brain before just being a dick.
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
Skinner is offline   Reply With Quote
Old 02-05-2013, 08:15 AM   #12
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 2,491
Hole saw or step drill, either one . . . . but back up the plastic with something (soft wood, perhaps) or you may create a hole that is larger than you intended . . . . . (depending on the plastic)
Searching for the immaculate contraption
Old 02-05-2013, 08:18 AM   #13
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,897
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
Originally Posted by cat
Q: How to make neat holes in airbox?
A: A sheet metal punch, the kind that you drill a pilot hole and then tighten the tool.
I have used this method to good effect.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 02-05-2013, 08:39 AM   #14
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,858
Step drill....they are cheap at harbor freight. I think mine will go to an inch. Anything bigger and out comes the hole saws. But you need backing for the last otherwise you'll tear the plastic.
You can countersink the holes....may help with airflow.
Smaller holes with side access, out comes dad's old airplane tools, namely the sheet metal punch. I think HF has cheap replicas of that tool.
Have tools, will travel!
Old 02-05-2013, 09:17 AM   #15
kruzuki
kruzuki's Avatar
Oddometer: 673
And remember to keep the drill speed low so the friction doesn't melt the plastic and ruin your nice, clean edge.
I'm allergic to asphalt, whenever I touch it I get a rash.
kruzuki is offline   Reply With Quote
Times are GMT -7.   It's 01:04 AM.
