Old 02-05-2013, 09:20 AM   #16
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,912
Step drill makes a nice round hole.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 02-05-2013, 10:19 AM   #17
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 7,529
Send a message via MSN to rapidoxidationman
Pic a size and aim well:
Gotta say I'm in the camp of "the engineers knew what they were doing" though.
I know I'm feeling badly when I have no interest in speeding
Patrick
rapidoxidationman is offline   Reply With Quote
Old 02-05-2013, 10:29 AM   #18
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,497
Hole saw.
As for the legitimacy of doing it, it just depends. The engineers, as mentioned, design an airbox for a wide variety of factors. Noise is a big one.
On my Triumph Scrambler, the airbox mod really helped with an open exhaust.
Jim
Old 02-05-2013, 10:34 AM   #19
yankeeone
Oddometer: 52
I would try a new
forsner bit , cuts a nice clean hole.
yankeeone is online now   Reply With Quote
Old 02-05-2013, 10:43 AM   #20
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 2,493
Originally Posted by yankeeone View Post
I would try a new
Forstner bits work great, but are happiest in a drill press . . . ..
Searching for the immaculate contraption
Old 02-05-2013, 10:44 AM   #21
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,859
The noise thing....that can be very annoying depending on exactly what kind of noises you create. Could be good noises but sure wasn't so on my snowmobile back then. Seemed to come up at high pitch and into my helmet.
I replugged them holes. And I am getting old and hearing going down. May have something to do with all them moving air noises at work.
Have tools, will travel!
Old 02-05-2013, 10:58 AM   #22
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,146
Pick up a deburring tool, cleans the fuzz from the drill bit like magic
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 02-05-2013, 11:26 AM   #23
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 987
+1 you just gotta have one in your toolbox- they work wonders on metal & plastic. A simple self-aligning tool that a file can't quite replicate. And inexpensive.
You can start with a small hole and easily increase it with the tool (once you cut a hole you no longer have a center for the bigger hole saw to align on) and can make custom-shaped holes to match the contours of the box, frame position, etc
I use the General Tool No 482 deburring tool, can be found at Home Depot, Lowes, etc as well as good hardware/hobby shops:
intake noise & weatherproofness are the deciding factors.
The engineers design on noise, filtering, ease of maintenance, rain-proofing. But now, mostly intake noise.
If someone modifies their engines (carb, cams, exhaust) they could certainly increase performance/power, I'm one of many who have done it- often at the sake of rain-proofness.
To each his own...
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..."
geometrician is offline   Reply With Quote
Old 02-07-2013, 03:55 PM   #24
anonny
What could go wrong?
anonny's Avatar
Oddometer: 4,960
My vote is with the step bit too. Forestner wood bit will made a nice clen hole as well if you have one.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 02-07-2013, 04:02 PM   #25
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,582
Send a message via Yahoo to Ricardo Kuhn
Regardless of been a good idea or not, like making holes on a piece of plastic just for fun..
You can use stainless steel mesh like this and some pop rivets to add effect.
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Old 02-07-2013, 04:24 PM   #26
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 2,689
Depending on the number and size of said holes, perhaps a re-jet as well.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 02-07-2013, 06:17 PM   #27
Range Motorsport
Junk collector
Range Motorsport's Avatar
Oddometer: 1,588
Originally Posted by It'sNotTheBike View Post
Probably because the OP imagines the trained engineers who designed the air intake
botched the job, though those engineers had access to a dyno and more than likely spent
many hours making sure the airflow was optimized for the resonant cavity of the air box,
( think of Helmholtz and you will be on the right track).
How likely is it that the engineers did a bad job and someone who needs to ask how
best to cut holes in the air box will do a better job ? Sort of like leaving an orangutang
in front of a typewriter and waiting for the sonnets of Shakespeare to be produced
( don't hold your breath waiting for anything intelligible to come out of that typewriter ).
You are right no one has ever removed or modified or redesigned an airbox and made more power...
Just like exhausts, fuel maps, and head porting do nothing for performance. You can also take any bike off the showroom and race it because they engineered it to be the fastest most efficient bike from the factory.
2007 KTM Superduke
SNL Will Ferrell Yoga, google it.
www.adventuremine.com
www.upoverland.org
Range Motorsport is offline   Reply With Quote
Old 02-07-2013, 06:39 PM   #28
troidus
Oddometer: 6,915
Bigger isn't always better. Some older heads respond well to filling the floor of the intake port to reduce volume and increase velocity and increasing the radius of the turn into the valve bowl to reduce fuel separation. On the Concours, there is an airbox mod that involves reducing the area of the intake for a boost in performance, but there needs to be a corresponding jet change or it goes rich.
You have to decide, when making mods, if you want every last bit of power wrung out above 9,000 at the expense of having an otherwise unrideable bike, or if you want to increase usable power in the middle of the rpm band where you spend most of your time. Are most of your trips a quarter-mile, 14 miles, or 1400 miles?
troidus is offline   Reply With Quote
Old 02-07-2013, 06:40 PM   #29
t6pilot
Oddometer: 433
Unibit/step drill
Use a marker on the bit at the diameter you want
t6pilot is online now   Reply With Quote
Old 02-07-2013, 06:42 PM   #30
1P8RIOT
1P8RIOT's Avatar
Oddometer: 317
Can't hurt to try
On my F800 I used a hole saw to put 3 holes on the part of the air box that's above the filter. I think the holes are 1" maybe 1 1/4" Before I did this I thought about what would happen if i wasn't happy with it. The plastic part I drilled into cost lass than $10. A BMW part that's only $10??? I figured it was worth 10 bucks to see if the mod that had worked on everything else I'd ever owned would work on this. I noticed better bottom end/low speed response and no negative results(same top end, mileage etc.) I do hear a little more engine noise but it's nothing.
A ship in a port is safe but that is not what ships are built for. - Mom
I DIDN'T BUILD IT TO DECORATE THE GARAGE. - me
'84 Harley FXR 250,000 miles and counting.
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Times are GMT -7.   It's 08:39 PM.
