Old 02-22-2013, 11:01 AM   #76
Süsser Tod
Süsser Tod's Avatar
Oddometer: 1,039
That doesn't sound like a top end problem, sounds like piston slap.
Süsser Tod is offline   Reply With Quote
Old 02-22-2013, 12:06 PM   #77
06ltd
06ltd's Avatar
Oddometer: 148
Try enriching your mixture and see if that does anything?
'08 KLR 705
'14 Panigale S
06ltd is offline   Reply With Quote
Old 02-22-2013, 02:48 PM   #78
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,373
Sorry to hear the trouble
I wouldn't have ridden it home sounding that way.
I would pull the oil filter now and look for metal and what kind.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 02-23-2013, 10:09 AM   #79
planemanx15 OP
planemanx15's Avatar
Oddometer: 1,009
Not good.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 screwed with this post 02-27-2013 at 06:37 PM
planemanx15 is offline   Reply With Quote
Old 02-23-2013, 11:02 AM   #80
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
Oh man... that sucks! I'm so sorry.
Wow whoever said piston slap had it pretty close.
So I wonder... was that due to the ring gap or something else? I can't help but wonder if it was getting any oil. Gonna have to wait and see what Jeff says.
The piston is toast... but the jug may be salvageable with a good hone. Heck even if it gets bored out ever so slightly it may still be usable. Again, I'd run it all past Jeff.
FWIW, I appreciate you posting all of this... it will likely help many of us avoid a similar fate.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-23-2013, 11:34 AM   #81
desmodab
Oversized Canuck
desmodab's Avatar
Oddometer: 359
Sorry man...
So sorry to hear this planemanx... there is nothing else to say really but that totally sucks - wish you all the best.
+1 on posting this and keep your chin up.
Desmodab
desmodab is offline   Reply With Quote
Old 02-23-2013, 11:35 AM   #82
planemanx15 OP
Oddometer: 1,009
Rob
I'm pretty sure it was due to the ring gap. As I've posted here and in the big thread, I skipped the gaping process and ended up with these results... You live and learn I guess... Now to see what its going to cost to fix..
The piston is shot, no doubt about that. The cylinder is just scratched. If you run a finger over it, you feel it, but its not bad (compared to the piston) I have to see what procycle offers me to have it corrected.
Old 02-23-2013, 11:55 AM   #83
Fallacy
Oddometer: 136
Nearly shed a tear seeing that piston, I wish you the best.
Thanks for posting the build.
Fallacy is offline   Reply With Quote
Old 02-23-2013, 11:55 AM   #84
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,802
It seized momentarily. Did you run it low on oil? Maybe too lean. I think you said you jetted it lean to try and get better MPG. Not ideal for breakin or a bigbore.
Hate gets you nowhere.
Old 02-23-2013, 12:01 PM   #85
planemanx15 OP
Oddometer: 1,009
I reset the jetting to a richer mixture prior to running it. I was good on oil. I assume the loud noise I heard was the first score (seize) from the rings expanding.
Do you guys think that there is another issue that was causing the noise in the video? I would have to assume that this was it. When I got home yesterday and drained the oil, It did eat some oil and was blowing blue smoke. This is expected though, if that is whats going on inside the engine. Nothing was sealed properly.
Old 02-23-2013, 12:08 PM   #86
Reposado1800
Juicy J fan!
Oddometer: 5,802
Take it to a shop and let them hone out the scoring. Put in a new top end. The tolerance was probably too tight. A couple thousandths more will prevent this from happening again. This is why Wiseco had the nickname Seizcoback in the day. Forged pistons need more tolerance and longer warmup time.
Old 02-23-2013, 01:03 PM   #87
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,819
Sorry to see that. Can you measure the ring gaps now and post some photos of the rings? They are probably broken if they were too big. Lots of guys make the mistake of not checking the ring end gaps the first time they rebuild an engine, so don't be too hard on yourself.
I also am wondering about lubrication. You said that the oil temp was good. Is there lots if oil in the top end?
Send from my Droid using Tapatalk
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 02-23-2013, 01:48 PM   #88
planemanx15 OP
Oddometer: 1,009
Plenty of oil in the top end. Ill take some pics of the rings. they looks alright and if I fit them into the cylinder they still fit tight with no gap.
Old 02-23-2013, 02:10 PM   #89
Bell driver
Bell driver's Avatar
Oddometer: 371
Originally Posted by planemanx15 View Post
... if I fit them into the cylinder they still fit tight with no gap.
There seems to be your problem, no ring gap.
What did the instructions say about minimum gap?
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 02-23-2013, 02:12 PM   #90
Mr. Canoehead
Taste Gunnels!
Oddometer: 1,819
When you first put the piston in with no rings, did it move freely in the bore? Just wondering what the piston clearance was.
Times are GMT -7.   It's 08:09 AM.
