Old 02-05-2013, 11:27 AM   #1
Baja Designs OP
Baja Designs
Baja Designs's Avatar
Oddometer: 545
Finally a bright light you can run off a two stroke
“Bright, Tiny, and Rugged”, our SII motorcycle light is now the newest addition to the Baja Designs line of motorcycle LED lights. The SII proves big things do come in the smallest packages. The new Baja Designs SII motorcycle light offers an incredible 1800 lumens out of a tiny 3”x 2” housing; our SII is THE brightest LED light ounce for ounce on the market. The SII draws merely 22 watts, 1.8 amps; this means many more motorcycles have the power to run this set-up than ever before. The SII is designed specifically for comfortable night-time riding. Our “Scientists of Lighting” have combined the features of an amazing distance projection, wide peripheral spread and a smooth light pattern. The SII utilizes two CREE XML LEDs - the brightest, most efficient LEDs on the market giving you a brilliant 1800 lumens. Three patterns are available, a combo/driving pattern, a spot pattern, and a full driving light pattern. The SII is designed, engineered, manufactured, and built in California and backed by Baja Designs’ limited lifetime warranty. If you are looking for the smallest and brightest LED light on the market the SII motorcycle light is for you!
http://www.bajadesig...Number=6602054R
This is an excellent choice for guys with two strokes or other race bikes that can only get a 50w lighting coil.
We also offer 10% off for forum members
Mike
BD
www.BAJADESIGNS.com
bailey@bajadesigns.com
760 560 2252
Baja Designs is offline   Reply With Quote
Old 02-06-2013, 11:39 AM   #2
Pigford
British
Pigford's Avatar
Oddometer: 930
Interesting - and a nice unbiased write-up
Pigford is offline   Reply With Quote
Old 02-06-2013, 12:12 PM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,504
Personally I find this in your face advertising a pain in the arse on forums.
Rob Farmer is online now   Reply With Quote
Old 02-06-2013, 01:01 PM   #4
Kai Ju
Kai Ju's Avatar
Oddometer: 1,815
Isn't that what the vendors section is for ?
Kai Ju is offline   Reply With Quote
Old 02-07-2013, 11:37 AM   #5
CoyoteCowboy
Easily Distracted
CoyoteCowboy's Avatar
Oddometer: 308
It is, but given the nature of our older bikes generally less than stellar charging systems, mentioning this in the Old's Cool section might be just the ticket for someone looking for better lighting. I would have never thought to check with them to see what they have
"East were the Dead kings and the remembered sepulchres; West was the grass." Archibald MacLeish
CoyoteCowboy is offline   Reply With Quote
Old 02-07-2013, 04:27 PM   #6
DGW
Oddometer: 20
I need it so THANKS for posting here.
DGW is offline   Reply With Quote
Old 02-07-2013, 10:40 PM   #7
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,161
So how about for really old two strokes with lighting coil, 6V AC power...
Or bikes running 12 volt 15 watt bulbs on AC?
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 02-08-2013, 06:12 AM   #8
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,257
If this was 6v. maybe. but even then my old RT1 would just eat every other light in the system as I'd have too much excess voltage running amock. Damned old balanced charging system. Although I am considering putting a regulator in there to control it.
Now if they made this as a replacement light bulb for a 12v positivie ground system, my 2 old Triumphs and my Norton would be very happy.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360
lrutt is offline   Reply With Quote
Old 08-23-2014, 04:28 PM   #9
Rogue_Ryder
速 Flat Biller 速
Rogue_Ryder's Avatar
Oddometer: 7,549
Can a Stock XR600 power this light? Or does the XR need the stator rewound?
Thanks.
Braaaap!!!!
Rogue_Ryder is offline   Reply With Quote
Old 08-24-2014, 08:00 AM   #10
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,029
I was sold until I got to the "designed, engineered, manufactured, and built in Kalifornia" part. No thanks, I have choices. I'll spend my money else where.
fastdadio is offline   Reply With Quote
Old 08-24-2014, 08:12 AM   #11
Highside>Lowside
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 1,064
Chinese would be better?
Though I am not a fan of the spamming, and I don't know a single Old's Cool ring ding that I would put that monstrosity on.
00 M944,95 620RXC,82 FT500,85 V65 Sabre,01 1150GS,82 XJ650r,91 XV920r,82 V50 Monza,77 TT500, R75/6, etc...
Highside>Lowside is offline   Reply With Quote
Old 08-24-2014, 10:35 AM   #12
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,029
No, it's not. There are other US made choices. This really is a CS&M subject and I'm not going there.
Old 08-25-2014, 12:33 PM   #13
Baja Designs OP
Baja Designs
Oddometer: 545
Thanks.
You could use the stock stator, but you will need a Dc accessory kit (battery, harness and switch, and rectifier). Let me know if you need anything, thanks - Christian
www.BAJADESIGNS.com
760 560 2252
Times are GMT -7.   It's 10:21 AM.
