Old 02-05-2013, 01:51 PM   #1
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,783
950A/990A adjustable wider & taller windshield: $66.00
I made 2 six inch brackets w/1" L bends to mount a Slip-Streamer Spitfire tinted wind shield (4" wider & 3" taller than the OEM shield). My goal was to allow 1.5" - 2" air gap at the bottom to achieve an angle similar to the forks . . . Which should reduce buffeting etc. I wanted to keep it chin high to allow full view over the top etc.
I used neoprene/rubber gaskets between my bracket spacers . . . using the upper fairing mount hole . . . which will help hold the shield in place. I used neoprene gaskets on the shield mounts too. I had to drill new holes 3" from the bottom of the Spitfire shield.
For my 5' 11" height I moved the shield 2 3/4" above the stock shield (using a split rubber hose as an edge on the stock screen) to protect the new shield. The bottom of the shield is above the light with a 2" air gap to counter buffeting.
It works great at any speed. It can be adjusted up or down as needed.
http://www.motorcycle-superstore.com...indshield.aspx
Motorcycles . . . my Happy medicine.
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
2014 Wee2,Vee2, NC7X: http://s836.photobucket.com/user/Twm...21297.jpg.html
mcmann is online now   Reply With Quote
Old 02-05-2013, 02:01 PM   #2
kdscoates
kdscoates's Avatar
Oddometer: 3,514
that looks ok and if it works that is even better.
now if you would just make me the brackets and all the spacers etc and drop them off at the house that would be awsome!!!!
Quote from Pj "if loud pipes save lives imagine what learning to ride that thing would do!!!"
quote from 4runner "but,if you really need a 80/20 , which most of us do and won't admit it,"
kdscoates is offline   Reply With Quote
Old 02-05-2013, 02:05 PM   #3
KHVol
Oddometer: 2,430
Interesting...
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol is offline   Reply With Quote
Old 02-07-2013, 04:26 PM   #4
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,783
I swapped my OEM screen with a 5" shorter Mose Racing shield and darkened the lower part of the add-on screen.
Looks better and allows more tilt to even further reduce buffeting:
Old 02-07-2013, 04:36 PM   #5
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,799
My version cost about the same, and can be adjusted with no tools. I used two screens, trimmed accordingly, and some hardware from McMaster-Carr.
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Old 02-08-2013, 02:52 PM   #6
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,783
The ange on the dangle is the important part . . . Need it anged back more. I open my face shield a couple inches too . . . It directs the clean air over my helmet much better than when the face shied is closed. This taller shield keeps the air off my chin too. I no longer need a balacalava on cold mornings.
I wrapped my 1" X 1/4" aluminum support bars in the same material as my shield.
I
Old 02-08-2013, 03:07 PM   #7
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 512
mcmann,
That looks very good! Nice job. Can you post a pic showing the detail of your mounting brackets? Are the two brackets bolts holding the entire shield and on top is it not attached, just resting against the back shield?
And thanks for posting. Going to the KTM rally in Steamboat this Sept?
KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe screwed with this post 02-08-2013 at 03:16 PM Reason: baad speler
knobbyjoe is offline   Reply With Quote
Old 02-08-2013, 07:13 PM   #8
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,783
Here is a pic of my try I brackets:
I re-did them with 1" wide 1/4" thick aluminum flat bar. Here is a mounted picture . . . Before I wrapped them in black.
I have double-stick foam-backed tape folded in a "V" at the top of my Moose screen to support the top (velcro adhesive-backed tape would work too).
The neoprene rubber spacers help hold the screen in place.
No plans for a KTM rally . . . But will ride Colorado late summer.
Wrapped. The try II are straight with a 45 degree bend for the shield:
If you decide to leave this screen on your bike indefinitely . . . You can support the top via 3M molding mount tape (folded in a V to match the ange of the two shields):
mcmann screwed with this post 02-09-2013 at 08:42 AM
Old 02-09-2013, 08:33 AM   #9
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,783
I decided to velcro the top of the screen . . . Better support than rubber fuel line hose:
I may have to use 3m double-stick tape on the lower half of the velcro to match the angle of the two screens.
This is the hardware incuded with the Slipstreamer shield:
You can not handle-bar mount on a bike with a fairing.
Another website for less $ & free freight:
http://www.powersportjunkie.com/SLIP...ps-56-6524.htm
I had to order another one for my SM (which I robbed for ths project):
mcmann screwed with this post 02-21-2013 at 02:24 PM
Times are GMT -7.   It's 04:05 AM.
