Old 02-05-2013, 06:47 PM   #1
Ratski OP
Ratski's Avatar
Oddometer: 748
Need advice on half wall at top of stairs.
I'm building a half wall at the top of my second story stairs. I put up the first of two tonight and need some advice as to how to make them stronger. The end at the top of the stairs wobbles back and forth with little effort. How do I make this better?
Some pics to see what I'm working with...
Ratski is offline   Reply With Quote
Old 02-05-2013, 06:57 PM   #2
toothy
Grin
toothy's Avatar
Oddometer: 14,188
Can you cut some of the green color wallboard and run a sheet of 3/4 plywood up the stairwell face of the wall, bonding the lower wall with your pony wall?
"Great minds discuss ideas; average minds discuss events; small minds discuss people.
(Eleanor Roosevelt)
toothy is offline   Reply With Quote
Old 02-05-2013, 07:04 PM   #3
Joetool
Oddometer: 152
First, you need to double up the end 2x's and have them go down into the floor. Also, you can skin one side with 1/2 inch plywood an cut it into the full height wall some. Screww it every 6 inches and you wil create sort of a box beam. Also; stagger some 3.5 inch screws in the bottom plate.And, you need WAY more screws in your drywall; 6" on the edges and 12" in the field...
Joetool is offline   Reply With Quote
Old 02-05-2013, 07:49 PM   #4
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,569
4x4 post or doubled 2x4 needs to go through the floor and tie into the framing below floor level using carriage bolts through a king stud made for the half wall instead of screws. Then sheet both sides of the half wall with luan to create a "web frame" before sheeting with the drywall.
Flashmo is offline   Reply With Quote
Old 02-05-2013, 08:28 PM   #5
advNZer?
advNZer?'s Avatar
Oddometer: 2,836
easiest way would prolly to have a post going to the roof.other ways could be a steel L bracket or two bolted/screwed to the floor(rebated in)
Its not exactly a high traffic area behind it though,looks barely high enough to walk in there
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-06-2013, 12:40 AM   #6
muddywater
muddywater's Avatar
Oddometer: 654
what he said with the steel bracket.
needs to be heavy enough to not flex much and screwed to a floor joist, not just the subfloor.
rebate=mortise ??....you can hide the bracket once flush under the floor covering. BTDT
08 KLR, 02 620Monster
muddywater is offline   Reply With Quote
Old 02-06-2013, 10:19 AM   #7
TheOtherBart
TheOtherBart's Avatar
Oddometer: 1,912
This would work, although 3/4" would be way overkill for the purpose. The ply would essentially be in tension/compression as that wall got pushed on, so 1/4" would be plenty. In fact I'd bet that re-running your drywall so it was continuous over that joint would stiffen things up significantly.
Depending on what's going to happen in that little space behind the half wall, you could add a little 6-12" L at the free end pointing away from the stairs.
And hopefully you're screwing that bottom plate down, nails won't offer much resistance to pullout as that hall gets pushed in or out at the top.
TheOtherBart is online now   Reply With Quote
Old 02-06-2013, 11:00 AM   #8
Wkendwrench
Wkendwrench's Avatar
Oddometer: 4
In addition to above recommendations, if code will allow, consider making wall shorter by the width of the top step (12"?).
Some Assembly Required
Wkendwrench is offline   Reply With Quote
Old 02-06-2013, 12:40 PM   #9
this is a RV
Oddometer: 370
Turn that wall into a bookcase or cabinet 12 or 20 inches deep.
this is a RV is online now   Reply With Quote
Old 02-06-2013, 01:37 PM   #10
r1200gs_chris
r1200gs_chris's Avatar
Oddometer: 132
1st, skin the backside of the wall with plywood, 1/2" should do. Glue and screw (NO NAILS) the plywood to the studs. Go buy some construction adhesive. Don't be cheap with the screws, every 8-10 inches in each stud, run glue down all studs. 2nd, drill a few pilot holes and strew some 3"x1/2" lag bolts into the floor. The plywood will make the wall rigid, and the lag bolts will hold it to the floor. Most of the wiggle is coming from the fact that the nails are not keeping your joints tight. When you build the second wall fell free to put the construction adhesive between each joint for added strength.
Good luck!
r1200gs_chris screwed with this post 02-06-2013 at 01:41 PM Reason: Big fingers
r1200gs_chris is offline   Reply With Quote
Old 02-06-2013, 02:45 PM   #11
GH41
Oddometer: 822
I am betting this isn't a permitted job. The space behind the wall doesn't look like it could used for anything but storage. I would build the wall floor to ceiling. Any attempt to steady the wall with brackets to the floor is a waste of time. GH
GH41 is offline   Reply With Quote
Old 02-06-2013, 04:32 PM   #12
Ratski OP
Ratski's Avatar
Oddometer: 748
I like the plywood to tie it in to the lower wall. you guys are right, storage behind this wall, but there is gonna be a matching (but longer) wall on the other side of the stairs that will see a teenager boys traffic to his room and all of his friends, etc.. so any techniques will be applied to that side too. Keep the ideas coming.
Old 02-06-2013, 06:56 PM   #13
toothy
Grin
toothy's Avatar
Oddometer: 14,188
Gluing it with construction adhesive is an excellent move, but skip the screws unless they are the GRK structural kind. Screws snap over time. Nails are the best bet in wood construction.
(Eleanor Roosevelt)
Old 02-06-2013, 11:33 PM   #14
heirhead
Oddometer: 527
Hello,
Get rid of the drywall shims you put on the studs then cut the drywall down 2ft or so. Put up plywood, 1/2", or whatever thickness of drywall is to match. Adhesive is great, then screw the plywood to studs and screw both 2x4 plates off every 6 inches. Closer the better. You can put plywood, 48", to the top of plate and cut green drywall down to match but at least 1 ft. 2 ft is better. When you hang finish d/w, screw both plates all the way across and studs. Your kids couldn't tear this wall down if they tried. Also do not have the drywall joint and plywood joint be the same, stagger them by at least a ft. as to not have a d/w joint crack.
USE GOOD SCREWS!!!
Angle pieces on floor or from stud to plate not needed at all.
Still worried, run some lags and big washers through both plates and the floor like R1200gs_chris said.
Just looked close at your first pic. Where you ran d/w up on ceiling next to wall, that is called railroading or running same way as studs. Do NOT do this on wall. Run plywood and d/w horizontal. Also the piece that you ran up and down right next to the first stud, cut off at the height of wall and run d/w the whole length of the wall all the way to wall on left. What you have is called a cold joint and WILL crack out.Get a 12 ft piece of d/w, important to have the new wall, lower wall and side wall all one if possible.
The big one will hit and this section of your house will still be together.
What we said in Ca. when something is overbuilt!!
Nomenclature is from SoCal.
Retired from this kind of back breaking work,
good luck,
We don't need no stinking codes!!!!!!
Heirhead
Worlds worst mechanic
Worlds worst sheet rocker
heirhead screwed with this post 02-07-2013 at 12:02 AM
heirhead is offline   Reply With Quote
Old 02-14-2013, 06:06 AM   #15
r1200gs_chris
Oddometer: 132
Well, we'll all given our 2 cents. Let's see what you came up with. Pics please.
Times are GMT -7.   It's 03:12 PM.
