Old 02-13-2013, 05:39 PM   #1
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
Reading a dial indicator
OK my dad (A machinist) passed before he was able to teach me a lot of stuff. So can someone adopt me and help me out?
If the dial made 1 complete rotation and then went 3 big lines and 1/2 way to the smaller line would that be 0.3325" ?
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 02-13-2013, 05:53 PM   #2
adventuro
Oddometer: 16
.03325
adventuro is offline   Reply With Quote
Old 02-13-2013, 05:56 PM   #3
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,549
I can't adopt you without proper papers. However, I can tell you that the instrument you see is a dial test indicator that has a 0.030" range and is not intended to go one (1) complete revolution. If you want an instrument to do that, get a dial indicator with a span of 1". The instrument in the photo is used for higher precision work with each mark measuring 0.0005".
To answer your question: no, one complete revolution then three big lines and 1/2 way to the smaller line is 0.03325" - which again- is outside of the range of measurement for that instrument. The test indicator is probably not broken, but stop doing that or you will break it.
Stan_R80/7 is offline   Reply With Quote
Old 02-13-2013, 06:01 PM   #4
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
I moved the . over behind the 0 when posting. .03325 was what I wrote down. Good to know I retained some info from him. Didn't know about the more than once around, was thinking dial caliper. Thanks on both
Old 02-13-2013, 06:03 PM   #5
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
My dads friends called him Stan
Old 02-13-2013, 06:16 PM   #6
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
My dad was a tool and die maker from 1948-1990. Unfortunately he retired and sold off a lot of his measuring devices while I was in Desert Storm. He didn't see the need to keep them as without the lathes , mills, EDM's etc there was no need for them. But he did stop selling stuff once I told him I wanted them. I did get a lot of custom holders and other types of tools and tooling. 1/2 the stuff have no idea what its for..ok probably 7/8ths I have no idea
Old 02-13-2013, 09:39 PM   #7
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,662
They say that diamond mirror in the toolbox was for digging chips out of your eye.
Nice lathe!
AviatorTroy is offline   Reply With Quote
Old 02-14-2013, 01:35 AM   #8
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,278
the largest measurement you can make on that 0-15-0 is 0.030" - it's really not meant to measure more than 1 full revolution in either direction... you can measure more, but it gets to be a lot of counting and gets expensive because you'll need to recalibrate the indicator you keep breaking
current bikes
stainlesscycle is offline   Reply With Quote
Old 02-14-2013, 04:09 AM   #9
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,622
Great stories you guys.
I grew up in the early to mid 1960's, my Dad a tool and die maker as well, from before my time till mid 2000's.
Lost him to a stroke 4 years ago. He had his own shop, most of the gear is gone, sadly.
Priceless the things he learned me, but I did not have the math to follow in his trade I did serve many hours in the shop after he set up lathes, Bridgeports and surface grinders.
Fun to see or read about some others with similar fathers. Funny how I appreciate the little things now, and wish I had full shop access again to work on bike stuff.
"No place is boring, if you've had a good night's sleep & have a pocket full of film." ~Robert Adams
Unstable Rider is offline   Reply With Quote
Old 02-14-2013, 05:52 AM   #10
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,386
That kind of test indicator is best used for tapping things level or parallel with some axis of movement, sweeping around pins or holes to find the center, tapping things concentric on a lathe, or inspection work comparing a finished part to a known "stack height." There are many uses; just remember it's a tool for fine, small adjustment or comparison not big linear changes -- for that you want a travel dial indicator with a 1" range. Instead of using the little lever arm like that one uses, it's a probe that slides (travels) in and out of the indicator body.
Nice collection of old tools -- those wooden Gerstner toolboxes are beautiful.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 02-14-2013, 06:38 AM   #11
timdog
a.k.a. Josh
timdog's Avatar
Oddometer: 626
Originally Posted by kenny61 View Post
My dad was a tool and die maker from 1948-1990. Unfortunately he retired and sold off a lot of his measuring devices while I was in Desert Storm. He didn't see the need to keep them as without the lathes , mills, EDM's etc there was no need for them. But he did stop selling stuff once I told him I wanted them. I did get a lot of custom holders and other types of tools and tooling. .500 the stuff have no idea what its for..ok probably .875 I have no idea
Fixed if for you
timdog is offline   Reply With Quote
Old 02-14-2013, 07:12 AM   #12
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
Old 02-14-2013, 07:33 AM   #13
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
You are lucky for having had a machinist father and for having kept the tools.
You are now adopted.
Check this site:
http://www.homemachinist.org/
lnewqban screwed with this post 02-14-2013 at 07:47 AM
lnewqban is offline   Reply With Quote
Old 02-14-2013, 07:44 AM   #14
kenny61 OP
Crazy Idiot
kenny61's Avatar
Oddometer: 24,743
Old 02-14-2013, 11:27 AM   #15
Beezer
Oddometer: 5,874
nice stuff..... I drool heavily. I'm sure you have figured it out by now, but to be clear, exceeding the normal movement of the plunger can cause damage to the little gears inside... then it's screwed.
Beezer is offline   Reply With Quote
Times are GMT -7.   It's 06:54 AM.
