Old 02-05-2013, 07:59 PM   #1
natapoc OP
natapoc's Avatar
Oddometer: 17
Question topo 24k in mapsource
had my laptop repaired. had to reload mapsource city nav old topo and new topo 24k. cant view all maps in mapsource like was able to before what am I missing? all my route files were saved but cannot view in mapsource because it doesnt see the 24k maps.
please help I have been searching but cannot find any info.
mapsource ver 6.13.7
natapoc is offline   Reply With Quote
Old 02-06-2013, 03:03 AM   #2
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,203
Does 24K require an unlock code?
dunno.....
Old 02-06-2013, 06:27 AM   #3
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 662
6.13.7 can't render the newer Garmin products unless they're reverse converted. Is 24K one of them? I don't think any current Garmin maps are useable without an unlock code.
SW
The Weather in my Backyard
Steve W is offline   Reply With Quote
Old 02-06-2013, 06:41 AM   #4
RxZ
Legal Drug Dealer
RxZ's Avatar
Oddometer: 1,887
Is the saved map data in the correct file location? I ask since it sounds like you backed it up prior to the repair, did you move the files back to the folder where Mapsource is looking?
2002 Yamaha FZ1
RxZ is offline   Reply With Quote
Old 02-06-2013, 06:25 PM   #5
natapoc OP
natapoc's Avatar
Oddometer: 17
the 24k topo maps do not show up in the drop down menu were you select which map to display in mapsource. I was able to use the 24k topo maps before as I have lots of routes that made using mapsource and 24k maps.
Old 02-06-2013, 06:37 PM   #6
Cannonshot
Having a Nice Time
Cannonshot's Avatar
Oddometer: 20,278
I just installed Garmin Topo 2013 (100K - copyright 2012). It unlocks to one unit. It showed up fine in MapSource and in BaseCamp. Standard install from the DVD.
By the way they tuned up the roads and POIs a bit. More accurate.
Cannonshot.net
Cannonshot is offline   Reply With Quote
Old 02-06-2013, 07:14 PM   #7
97wing
Wimpy Adventurer
97wing's Avatar
Oddometer: 64
Did you run the install from the Topo DVD or just move the files? I would reinstall from the DVD.
In Mapsource, click Utilities, Manage Map Products. If it is not listed there, it needs to be reinstalled.
You might have to use MapSetToolKit to correct the problem.
Steve in Miss-sippy
97wing is offline   Reply With Quote
Old 02-06-2013, 07:53 PM   #8
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 662
But what version of MapSource? After 6.13.7, which the PO is using, things changed.
SW
Old 02-06-2013, 08:12 PM   #9
Cannonshot
Having a Nice Time
Cannonshot's Avatar
Oddometer: 20,278
Just double checked. Mine is 6.16.3 and works fine.
Cannonshot.net
Old 02-06-2013, 08:13 PM   #10
natapoc OP
natapoc's Avatar
Oddometer: 17
thanks for all the input i installed the 24k maps from the dvd. what is mapsettoolkit?
Old 02-07-2013, 05:40 PM   #11
natapoc OP
natapoc's Avatar
Oddometer: 17
updated mapsource to 6.16.3 now can view all my maps thanks again for all the help!
Times are GMT -7.   It's 03:38 AM.
