02-06-2013, 08:19 AM
#1 |
I wish I was cool
Oddometer: 214
Help with an oil change.
I am borrowing my brothers 2007 HD Dyna Wide Glide and I need to change the fluids. Does anyone have a pdf of the owners manual or step by step instructions on how to do the engine oil, primary, and transmission fluid? What about recommendations for fluids, HD brand or go to the auto parts store?
Die Living. My brother stole my XR to go the South America so I stole his HD to piss off hippies in Corvallis. His ride report http://advrider.com/forums/showthrea...2#post19932112 |
02-06-2013, 08:27 AM
#2 |
Oddometer: 17,983
You can find what you need on Youtube. Use a HD filter.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
02-06-2013, 01:41 PM
#3 |
Bead Buddy
Oddometer: 3,287
Use H-D fluids and filters, it just makes life easier. Also get the gasket kit that goes along with the service, will include the quad ring for the derby cover and o-rings for the drain plugs. The primary drain is right under the derby cover, the engine oil drain is on the left of the oil pan, pointing horizontal and the transmission plug is on the right of the oil pan pointing down. Engine takes approx. 2.5 qts, primary and trans each take a quart. I'd recommend Syn-3 in all of 'em. You'll need their special cut-out oil filter wrench to avoid destroying the CKP, or just take it out before attemping to remove the oil filter.
No big deal really.
Your $5 ticket to the buttery goodness that is Smugmug - t7Ut8i5M4CRzY |
02-08-2013, 08:34 AM
#4 |
motorcycle addict
Oddometer: 625
pm sent.
Dan
I would rather live my life as if there is a God, And die to find out there isn't, than live my life As if there isn't, and die to find out there is. panhead_dan screwed with this post 02-08-2013 at 08:41 AM |
02-09-2013, 05:50 AM
#5 |
Oddometer: 4,309
If you need to change all the fluids there are surely a few other items that need to be done. How many miles?
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
02-16-2013, 10:29 PM
#6 |
I wish I was cool
Oddometer: 214
I went to the nearest Harley dealer and picked up 3 quarts of engine oil, two quarts of trans/primary oil, an oil filter, and an o-ring kit. I just found these YouTube vids. What do you guys think, are these good to go? They are for different year and model bikes but the process can't be that much different.
Engine Oil Change http://www.youtube.com/watch?v=kfj3L3yhrdk Primary http://www.youtube.com/watch?v=jiVJfUaOPTo Transmission http://www.youtube.com/watch?v=0P50CPUmRuQ
02-17-2013, 03:38 AM
#7 |
ZEPHYR
Oddometer: 52
Double Check The Drain Plug
Make sure you are removing the drain plug and not one of the tapered tooling hole plugs. A buddy of mine made this mistake and ended up cracking the engine when over tightening the plug.
ZEPHYR |
02-17-2013, 09:42 AM
#8 | |
I wish I was cool
Oddometer: 214
What do you think of the videos I posted?
02-17-2013, 02:39 PM
#9 | |
Oddometer: 128
You'll need a small funnel for the transmission fluid, and I find a turkey baster is great for the primary. As the amount needed is less than an even quart, I suck the non-needed amount out of the quart bottle, and then put the rest in the primary. The turkey baster helps here too, as by removing the bulb off the end, you have a funnel to add the primary fluid to the primary. Another tip, get a 4x4, 6x6, 2x4, or some combination to slip under the right side of your frame. You'll have to figure out how much. Push the motorcycle over on the boards, and it will lean that way as if there was a kick stand on the right side. makes adding fluid to the primary very easy. Getting the oil filter off and on can be a bear. Go ahead and get a proper wrench for that. |
