Old 02-06-2013, 02:13 PM   #1
Rocket Scientist OP
Oddometer: 24
DR 350 dualsport wiring
Got a '90 DR 350s. Has a Tusk (like) dualsport wiring kit on it with an add on battery pack. Im in the process of cleaning up the previous owners wiring (wire nuts & chit). My question is, does anybody know how this system is supposed to be wired properly? Im looking at a 9 pin harness coming off the multiswitch (headlight on-off-HI, turn & horn) & wondered if anybody knows what color runs which switch & common ground & power to it? Im working with that, & a factory 2 wire plug which I believe ran the headlight off the stator (powers up when running-dead when off). How does the battery pack wire in? Stator feed to positive to charge it? Im lost here.
Rocket Scientist is offline   Reply With Quote
Old 02-06-2013, 02:17 PM   #2
MrPulldown
MrPulldown's Avatar
Oddometer: 3,253
Go to Greg Benders this old tractor web site. Poke around and you will find some manuals with wiring charts. Wiring is not something you can explain in words. Good luck.
MrPulldown is offline   Reply With Quote
Old 02-06-2013, 02:45 PM   #3
groundrules
groundrules's Avatar
Oddometer: 1,764
http://thisoldtractor.com/gtbender/dr350.htm
"Featured Sections", upper right side.
groundrules is offline   Reply With Quote
Old 02-17-2013, 06:01 PM   #4
Rocket Scientist OP
Oddometer: 24
I figured out the handlebar switch 9 wire connector. As follows.
yellow......12v feed to headlight switch
white........headlight low beam
dark blue..headlight high beam (also lights high beam indicator)
gray.........12v feed to turn signal switch
orange......left turn signal
light blue...right turn signal
dark green...common ground
light green...12v to horn switch
black..........12v out from horn switch
I am not completely sure if this color code follows all models of motorcycles or not. The switch I verified is similar & very possibly a Tusk Motorsports switch supplied in their dualsport wiring kit.
Old 02-18-2013, 05:21 PM   #5
Rocket Scientist OP
Oddometer: 24
Also figured out a standard 4-5 pole switched relay diagram.
pole #30....constant 12v
pole #86....switched 12v feed
pole #85....ground
pole #87....to accessory to be powered (light-horn-fan-etc)
pole # 87a...typically not used (5th pole)
This is a standard wiring diagram for a switched relay.
Times are GMT -7.   It's 06:45 PM.
