Old 02-06-2013, 03:23 PM   #1
grandpa T-bone OP
Vet - old Laconia RR
Location: Healdsburg, CA, heart of windy, twisty m/c heaven!
Oddometer: 2
grandpa T-bone's M/C Oil Changing Tips
1) start early Sunday morning, so you don't feel pressured and will
be sure to finish in time for the ride with friends
2) search for Owner's Manual; make a note to buy one later
3) warm engine (not hot) and park bike over a big piece of cardboard
(newspaper can substitute, you won't have time to read it anyway)
4) position oil pan beneath crankcase of motorcycle
5) remove oil filler cap and place on floor under the bike, where
it can't fall off and roll under a cabinet
6) try to loosen oil drain plug with your wrench which is closest to
the correct size
7) if your last service was done at a shop with a young, strong,
apprentice mechanic, get a piece of pipe to put over the wrench
handle for more leverage to break the plug loose
8) borrow large vice-grips (locking pliers), apply to the now
stripped oil drain plug and loosen until it can be turned by hand
9) turn plug out slowly by hand until oil starts to seep out,...
then turn it out as fast as you can to remove it before the hot oil
becomes unbearable
10) as quickly as possible, re-position oil pan under crankcase so
the oil is no longer pouring out onto the floor
11) try not to drip too much oil on floor walking to corner of garage
to get rags and newspapers, wipe oil off hands
12).... if necessary find some of your wife's old towels (more on
this later) to mop up excess oil from garage floor
13) Using an ordinary hammer and the minimum force necessary, pound
your longest screwdriver through the oil filter to obtain the
leverage required to break loose the overtightened filter threads
(see reference to young technician, Step 7).
14) remove oil filter, which will then remind you to re-position pan
to receive the remainder of the oil; - IMPORTANT - check to make sure
you didn't drive the screwdriver through the crankcase
15) crank starter to scavenge the the last little bit of oil, trying
not to knock over the bike in your haste to shut the engine off
before permanent damage occurs
16) remove, clean, and install the cap on your oil drain pan,... and
clean up the mess on the floor
17) go to buy replacement oil and filter, dumping your drain pan at a
recycle facility on the way
18) returning home, place a little oil on the filter gasket and
install filter
19) place funnel in oil filler hole and pour oil carefully into
funnel, this will remind you that you haven't re-installed the oil
drain plug.
20) clean up mess with wife's old towels (more on this later), recall
that you dropped drain plug into the drain pan due to the 'WARM' oil
21) look in oil drain pan and shake vigorously until assured it does
not contain drain plug
22) go to recycle center to be assured the plug is not retrievable
23) buy another quart of oil while you're out
24) call friends and inform them of child's illness which prevents
you from riding with them today
25) after work on Monday (Tuesday if your bike dealer is closed on
Monday) go to your bike dealer and buy new oil drain plug,... they
always have an adequate supply stocked for just this reason
26) while there, surreptitiously practice with a torque wrench to see
what 18 Ft.Lbs. (24 Nautical Miles) feels like
27) arriving home, install oil drain plug and tighten to
approximately the feeling you remember from 26) above
28) put in the specified quantity of oil, plus a little left-over in the can you
tried to put in Sunday
29) take short ride to warm engine and check for leaks and oil level
30) at first stop sign, your foot slips off brake lever because your
shoe and the side of the bike are covered with oil, you have forgotten
to re-install the oil filler cap; go home slowly and clean everything up.
31) look for oil filler cap; after carefully searching the garage, go
out to trash can to search through oily papers and wife's old towels
(more on this later), remember that trash was picked up this morning
32) rush back to the dealer's shop hoping someone will still be there
33) Tuesday (or Wednesday, as the case may be), go to bike shop after
work again and buy your new oil filler cap,... they always have an
adequate variety stocked for just this reason
34) go home, install oil filler cap and start engine; ride bike for
short distance
35) pull into garage and check under bike for leaks, tighten oil
filter and oil drain plug until seepage stops; DO NOT OVERTIGHTEN
36) call friends and explain you can't go riding Sunday because you
will be taking a cruise with your wife,... to appease her for ruining
her family's heirloom towels
Performance improves with practice, after 60 years experience I
can now perform this work in as little as a dozen steps. Good luck!
Family motto: Blessed are the meek... for they shall provide traction!
grandpa T-bone screwed with this post 02-06-2013 at 04:02 PM
grandpa T-bone is offline   Reply With Quote
Old 02-06-2013, 04:23 PM   #2
FatBob
The name says it all
FatBob's Avatar
Oddometer: 514
Funny first post Gramps.
The older I get, the faster I was!
Ride Safe, Ride Often
FatBob is offline   Reply With Quote
Old 02-06-2013, 08:55 PM   #3
ADVMindset
Americana Adventurer
ADVMindset's Avatar
Oddometer: 1,163
+1
That was great !
ADVMindset is offline   Reply With Quote
Old 02-06-2013, 09:11 PM   #4
Jaynnus
Jaynnus's Avatar
Oddometer: 38
Jaynnus is offline   Reply With Quote
Old 02-07-2013, 08:32 AM   #5
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,233
and herre I thought I was the onlyiest one . . . .thanks, T-bone!
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
bomber60015 is online now   Reply With Quote
Old 02-07-2013, 09:42 AM   #6
paulom
Oddometer: 29
Seems like SOP
paulom is offline   Reply With Quote
Old 02-07-2013, 12:29 PM   #7
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,501
Laconic is offline   Reply With Quote
Old 02-07-2013, 12:45 PM   #8
Navin
Navin's Avatar
Oddometer: 7,828
How do you manage to not walk across new carpeting with oil soaked shoes leaving big blotchy stains?
Well done!
Navin is offline   Reply With Quote
Old 02-07-2013, 08:56 PM   #9
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,579
Flashmo is offline   Reply With Quote
Old 02-08-2013, 06:48 AM   #10
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,223
That doesn't sound at all like what happened the first time I did a valve adjustment on my Ninja. Nope. No similarities AT ALL.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 02-08-2013, 09:20 AM   #11
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,623
I see you go to the shop for parts. BMW Airhead?? If so and if your bike did not come OEM with a gasket on the oil filter cover, DO NOT listen to the young(er) parts guy/mechanic saying IT HAS to have a gasket.
If you do listen, against your better judgement and install such a gasket, your bike may just puke all its oil on the shop floor as soon as you start it. Then like me you may have to drive 80 Kms (43.1965 Nautical Miles) to go get more oil at the local inflated prices.
Old smelly carpets under the bike and lots of cheap kitty litter handy.
Have tools, will travel!
H96669 is online now   Reply With Quote
Old 02-08-2013, 03:35 PM   #12
grandpa T-bone OP
Oddometer: 2
Originally Posted by tirebiter View Post
Hey Donny!
Long time no see, how ya been??
We need to talk Tony into having another BBQ soon, catch up on some important BS..
Hope to see ya soon,
Dan
Yeah, it has been, Danny! Hope you and the Missus are happy, healthy and looking forward to DST on Mar 10th. Between time going faster and me being slower I don't seem to get much done before I forget what I was going to do anymore,... although I still manage to finish breakfast by noon. I'll see Tony soon to check-out Colleen's BMW 650 and I'll forward your suggestion. Cheers,... and don't get lost; donny
Times are GMT -7.   It's 08:29 AM.
