Old 02-07-2013, 08:01 AM   #1
RedRupert OP
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Please help - high oil consumption
I wonder if anyone can help diagnose my high(?) oil consumption.
My bike is a 2004 950 with 90,000 km (about 56,000 miles).
During it's early life, oil consumption was acceptable - I mean, it needed topping up with <1 litre between 6-7000 km oil changes. So about 2 litres per 14,000 km (8700 mile) season. (0.14 litres/1000 km).
Over time the oil consumption became worse: 4 litres over 12,000 km, so 1 litre/3000 km (0.34 litres/1000 km).
At 74,000 km, I had to strip the engine in order to replace the selector drum. While the engine was apart I replaced the (serviceable) piston rings and honed the bores lightly. After honing the ring end-gaps were all around <0.32 mm (limit 0.5 mm). I did not have the correct tools to measure the bore and piston accurately.
I also changed the oil seal in the ignition casing (the balancer shaft oil seal).
I ran-in on semi-synthetic oil for over 1500 km on twisty roads not being too gentle - using plenty of acceleration and engine breaking - but oil consumption remains high.
16,000 km after the rebuild, I measured compression and found 16.5 BAR (240 PSI). And carried out a leak-down test and found around 30% leakage, front and rear.
KTM state:
0.3 - 0.6 litres/1000 km: normal.
>1.0 litres/1000 km: there MUST be a serious technical defect!
My bike is ridden hard, but 0.34 litres/1000 km does seem a bit steep! Is it, despite what KTM say?
Looking at the leak-down and compression test results, could it be that the bore/piston/rings are at fault, or should I be look for another reason for the oil loss?
Any info will be gratefully received.
Thank you.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert screwed with this post 02-07-2013 at 08:15 AM
RedRupert is online now   Reply With Quote
Old 02-07-2013, 08:05 AM   #2
RedRupert OP
RedRupert's Avatar
Oddometer: 581
Leak-down readings
Yamaha WR 450 F
Old 02-07-2013, 09:15 AM   #3
Orangecicle
Orangecicle's Avatar
Oddometer: 2,460
Do you have oil in your front carb? The balance shaft seal on the left side if the bike is a known culprit.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 02-07-2013, 09:32 AM   #4
RedRupert OP
RedRupert's Avatar
Oddometer: 581
Yes, I did that - see 6th paragraph in my first post.
Yamaha WR 450 F
Old 02-07-2013, 10:07 AM   #5
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Compression seems ok. Maybe you need some more time with non syn oil to get the oil rings to take a set.
How are the valve seals, any smoke?
You are on the lower end of acceptable oil use. KTM might be using a light tension oil control ring???
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 02-07-2013, 10:54 AM   #6
RedRupert OP
RedRupert's Avatar
Oddometer: 581
-John
I've covered a further 12,000-odd km using fully synthetic oil since the post rebuild 1500 on semi synthetic. Maybe it's a bit late to go back to semi or non-synthetic?
I replaced the valve-stem oil seals when I rebuilt the engine.
Sometimes I'm told there's a puff of smoke on overrun. But could that be enough to burn so much oil?
Thanks.
Yamaha WR 450 F
Old 02-07-2013, 11:00 AM   #7
buzybraza
buzybraza's Avatar
Oddometer: 377
In my opinion (I am no expert) you should be looking at valve guides and seats.
buzybraza is offline   Reply With Quote
Old 02-07-2013, 11:17 AM   #8
RedRupert OP
RedRupert's Avatar
Oddometer: 581
I lapped the valves when I rebuilt the engine, also they were not leaking when I carried out the leak-down test.
The valve guides were checked and were OK when I rebuilt the engine.
Yamaha WR 450 F
Old 02-07-2013, 12:15 PM   #9
Orangecicle
Oddometer: 2,460
If you no longer have an oily front carb, you know the valves are good, and she is not leaving a puddle when stopped, you are kind of down to cylinder walls and ring seating in my mind. I know that Pyndon had a delamination of nicacil in a cylinder on his bike that he wrote about in his My KTM 950 Story thread. That's all I can think of. You might PM Pyndon to see if he has any other thoughts.
Old 02-07-2013, 12:28 PM   #10
RedRupert OP
RedRupert's Avatar
Oddometer: 581
When I rebuilt the engine, I checked the Nikasil surface of the cylinders, and found it to be in very good condition.
The breather pipe from the balancer shaft, I have lead into a catch-bottle so that I can monitor oil exhaled. There is nothing to speak of in the bottle.
Yamaha WR 450 F
Old 02-07-2013, 12:40 PM   #11
Orangecicle
Oddometer: 2,460
Well, no valve leak per your thoughts, and no balancer shaft seal issues, and nothing leaking on the ground. I'm assuming it's not pumping oil out of the radiator overflow.
Then you are down to ring seating, right? Maybe your symptoms relate to the honing. Dunno. Here's a related discussion: http://www.thumpertalk.com/topic/294800-honing-nikasil/
Old 02-07-2013, 12:54 PM   #12
RedRupert OP
RedRupert's Avatar
Oddometer: 581
The coolant is clean and there is no abnormal activity concerning the cooling system.
My symptoms were present before the new rings and honing - it's why I installed new rings and honed.
I can't say that my oil consumption is down to ring seating - it's why I'm posting. To me it looks not, as the leak-down test looks normal.
There may be a cause that is pretty unique to this engine - like the balancer shaft seal, for example.
Thanks for the link.
Yamaha WR 450 F
Old 02-07-2013, 02:30 PM   #13
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 730
MY humble opinion,, based on my background...
You can't hone Nicasil liners with any tools available to mere mortals.. Usually it ruins the cylinder...
Break in oil should be standard oil, no synthetics at all, preferably a high zinc sulfur break in oil if new cams are involved...
I did the same thing with a motor I built 2 years ago. Started on semi synthetic, and the rings would not seat. I ran straight 30 weight for about 3 days then put the semi back in and voila,, no more oil consumption. (Iron cylinder walls though.. ) But the old Nic barrels on porsches used to wear out two or three sets of pistons and rings before they needed any attention..
Check the vacuum level in the crank case.. It should be close to neutral,, very light suction.
You did valve seals, but how were the guides? Intake valve guides can allow a lot of oil even with a new seal if they are loose.
Just thoughts on it not necessarily answers.. :)
Dave
pdxmotorhead is offline   Reply With Quote
Old 02-07-2013, 03:30 PM   #14
Orange Toaster
Orange Toaster's Avatar
Oddometer: 113
No worries
A hard ridden bike with 90.000 km's on the clock that still only uses 0.3 l per 1000 kms is nothing to worry about at all. Good, actually.
Especially as KTM states that it is normal.
Are you using 10W-50 oil like the manual says? If you only use 40 oil, change to 50 which is thicker and will probably reduce oil consumption.
OT
'03 KTM 950 Adventure
Orange Toaster is offline   Reply With Quote
Old 02-07-2013, 03:41 PM   #15
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
If it were me I would try running some non syn. I have access to break in oil, you might be able to find some. The zinc and phos do help the rings seat(this is waht the guys at total seal rings have told me). It sounds like your top rings are seated maybe the dino oil will help the oil rings. Won't hurt to try.
-John
Times are GMT -7.   It's 07:24 AM.
