02-08-2013, 09:08 PM
#31 | |
new orange flavor
Oddometer: 1,058
I have had a few ring seat issues with some trucks in my fleet. The trucks run propane and since the reformulation of oil here in the US we have had issues with new rebuilds. I had to start using a high zinc oil in combination with a rough hone and higher tension oil rings to solve our problem. I am a believer in the break in oil now. Regular oil would be a lot easier to try than tearing it down and starting over. -John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
02-10-2013, 02:30 PM
#32 | |
Oddometer: 107
I am not saying that it have to be Motorex, now (20,000+ kms later) I run private label 10W-50 and it is using around 0.1-0.3 l/1000 kms subject to riding style. Bike has now done around 66,000 kms. Mostly touring. /OT
--- '03 KTM 950 Adventure |
02-10-2013, 10:34 PM
#33 |
Oddometer: 15
Not to avoid troubleshooting your rings. But.
I presume the LC8 has smooth rod & crank bearings. If they are loose enough, the big end of the rod bearing can spray oil onto the cylinder walls, overwhelming the oil ring. No suggestions on how to determine that w/o a tear down. Does this engine design have a cooling jet of oil that sprays the under side of the piston? If so, how is this regulated? Good luck. |
02-11-2013, 05:08 AM
#34 | |
Brit in the Soviet Union
Yes, I'm going to try using straight 30W oil as you and Dave have suggested, in order to seat the oil rings. Please can you give me some advice on: a) The best oil and how to find/identify it - API standard S? b) The best way to seat the rings, and what to avoid doing. Thanks for your help, Rupert
KTM 950 Adventure (2004) Honda 650 Dominator (1988) Kawasaki KLR 650 (1988) Yamaha RD 350 LC (1984) |
02-11-2013, 05:33 AM
#35 | |
Thanks for your advice. I was reluctant to accept it at first, partly because I was annoyed with myself - I did know that synthetic oils are no good for running-in (I've read about the problems Yamaha had a few years ago). I made a half-hearted effort to find a suitable oil, but ended out settling for semi-synthetic. There is too much soot in the exhaust pipes. The oil is being burnt. The valve-guides and the pistons were in very, very good condition. Also, as I've said, I led the engine vent pipe into a catch-bottle - rather than into the top of the air-box. Since doing this, the pre-filter has been very black, and so was the front of the OE paper air-filter before the pre-filter was fitted - almost as if there's too much oil in the air around the air-box intake. I'm going to try using straight 30W oil as you and John have suggested, in order to seat the oil rings. Please can you give me some advice on: a) The best oil and how to find/identify it - API standard S? (what suffix if any to go for?) b) The best way to seat the rings, and what to avoid doing. Thanks again, Rupert Re the leak-down: I ran the engine 'till the fan cut-in before conducting the test, but was surprised to see that the readings were very close to the ones I'd taken while the engine was cold. I should try it again.
02-11-2013, 05:48 AM
#36 |
Oddometer: 4,997
Rupert, I spoke to Bob Presslee ex KTM machanic. He said try 10-40 mineral bike oil for a couple of thousand miles, he added they had a SD that kept burning a lot of oil, the guy sold the bike and the new owner took it on a few track days and that cured it.
02-11-2013, 06:21 AM
#37 | |
Thanks for the info. I'll use some mineral oil, but it'll be a while before I know the results, as we'll have snow and ice on the ground until the end of April! How should I ride it with the mineral oil inside - plenty of acceleration and engine breaking, or thrash it? I do thrash hell out of my bike - it's only used abroad while on holiday. Never any commuting, touring or pootling, I promise.
02-11-2013, 07:55 PM
#38 |
new orange flavor
Oddometer: 1,058
Rupert,
In the US, the EPA made the oil companies reformulate the gas and diesel oils, they took out the zinc and some other stuff. I imagine since you do not have the EPA to deal with your dino oil should have higher zinc and other good things for engines. A good 30 wt, or similar diesel oil should work in a pinch. I use Maxima break in oil and have had good luck so far with it. As far as what not to do I would wait for the engine to warm up to give the pistons time to grow. I would then flog the piss out of it and hope for the best. If that does not fix the high oil consumption I would just live with adding oil until the next rebuild. ( Which is what I am doing with my ducati at the moment Let us know how it goes and good luck. -John
02-11-2013, 11:37 PM
#39 |
W. F. O.
Oddometer: 556
The love of the road is not something you can explain to someone who does not understand it.
2008 KTM 990 ADVENTURE ![]() |
02-12-2013, 04:30 AM
#40 | |
They call me......Ronski
Oddometer: 556
![]() However, the picture of your cylinder shows the angle of the cross-hatching is way too shallow. I am a professional auto technician, and have found honing properly takes a while to get the hang of. It appears the you had the hone rpm too high for the frequency of your up and down movement. The ideal angle is 60 degrees between the up and down lines, while yours appears to be about 10 degrees. Hopefully some break-in oil will help seat those rings without another tear-down.
Ronski Enduro Racer & Google Earth Adventurer |
02-12-2013, 04:54 AM
#41 | |
I agree about the angle of the hone marks - my speed was low - should have been around 600 RPM (I used a battery drill) but I accept that I didn't plunge fast enough. However, I hope too shallow is better than too steep - logically it would seem so. Flex-Hone stated 'around 45 degrees' but I would not have known how to get to 45 without more practice, as you've pointed out. What oil did you use while running-in (break-in)? Thanks, Rupert
KTM 950 Adventure (2004) Honda 650 Dominator (1988) Kawasaki KLR 650 (1988) Yamaha RD 350 LC (1984) RedRupert screwed with this post 02-12-2013 at 05:10 AM |
02-12-2013, 06:48 AM
#42 |
Oddometer: 268
break-in oil
Here is some info I have gathered from Amsoil's website http://www.amsoil.com/shop/by-produc...-%28sae-30%29/
AMSOIL Break-In Oil is an SAE 30 viscosity grade oil formulated without friction modifiers to allow for quick and efficient piston ring seating in new and rebuilt high-performance and racing engines. It contains zinc and phosphorus anti-wear additives to protect cam lobes, lifters and rockers during the critical break-in period when wear rates are highest, while its increased film strength protects rod and main bearings from damage. AMSOIL Break-In Oil is designed to increase compression, horsepower and torque for maximum engine performance. Quickly Seats Rings The primary goal during engine break-in is to seat the rings against the cylinder wall. Properly seated rings increase compression, resulting in maximum horsepower; they reduce oil consumption and prevent hot combustion gases from entering the crankcase. To achieve this, however, the oil must allow the correct level of controlled wear to occur between the cylinder wall/ring interface while maintaining wear protection on other critical engine parts. Insufficient break-in leaves behind peaks on the cylinder wall that prevent the rings from seating. The deeper valleys, meanwhile, allow excess oil to collect and burn during combustion, increasing oil consumption. Too much wear results in cylinder glazing due to peaks rolling over into the valleys and preventing oil from collecting and adequately lubricating the cylinder wall. AMSOIL Break-In Oil’s friction-modifier-free formula allows the sharp peaks on newly honed cylinder walls (fig. 1) to partially flatten. The result produces more surface area for rings to seat against, allowing formation of a dynamic seal that increases compression, horsepower and torque (fig. 2).
02-12-2013, 07:11 AM
#43 |
Oddometer: 556
That's rather encouraging. Perhaps the Amsoil break-in oil will seat those rings.
I just used a synth blend oil, and rode it like I normally do. Hard.
02-12-2013, 07:27 AM
#44 | |
Oddometer: 268
02-14-2013, 07:10 AM
#45 |
Millers Oils
The info from AMSOIL is useful, but they are not well represented in the UK. However, a well respected British company, Millers Oils www.millersoils.co.uk have recommended two of their products. They have representatives in US and around the world.
Classic Running In Oil http://www.millersoils.co.uk/scripts...dsegmentID=240 Liquid Glaze Bust http://www.millersoils.co.uk/scripts...dsegmentID=165 I'm going to try the Liquid Glaze Bust, as I've covered 12,000 km since the rebuild. The Classic Running In Oil sounds ideal for first fill after a rebuild. Millers have confirmed that both the above products are suitable for wet clutch engines.
