Old 02-07-2013, 06:34 PM   #1
Yellow Iron OP
Yellow Iron's Avatar
Oddometer: 3,073
Things I should know about doing a clutch on a mitisibushi
Mitisibushi eclipse
Bigger Better Faster More----4 non blondes
Feel the Power of the Wheel
Yellow Iron is online now   Reply With Quote
Old 02-07-2013, 06:48 PM   #2
Eye of the Tiger
Eye of the Tiger's Avatar
Oddometer: 78
Pretty standard stuff. The flywheel I think is integrated into the clutch kit, so don't have to worry about that. Clutch replacement is generally a good time to replace motor mounts, shift linkage bushings, rear main seal, axle seals, slave cylinder, transmission oil. And don't forget the blue loctite on all the bolts
06 wees trom
Eye of the Tiger is offline   Reply With Quote
Old 02-09-2013, 11:00 AM   #3
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,699
Spend a few $$$ on an alldata.com/diy subscription for your specific car.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-09-2013, 12:32 PM   #4
jar944
jar944's Avatar
Oddometer: 695
What generation eclipse? 4 or 6 cyl?
I did a 3rd gen 6 cyl w/o pulling either the trans or engine out. Just shifting the trans enough to get access
jar944 is offline   Reply With Quote
Old 02-09-2013, 03:33 PM   #5
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,413
+1 Best $20 you can spend
Old 02-11-2013, 05:47 PM   #6
Yellow Iron OP
Oddometer: 3,073
Not too bad. Had some trouble juggling the trans back in..
I built a plate to use the engine lift to lift it in from the top.
Thanks for your help
Times are GMT -7.   It's 05:46 PM.
