Old 02-07-2013, 06:37 PM   #1
brandonmccann OP
brandonmccann's Avatar
Oddometer: 39
adhesive for turn signals?
Alright,
So when I had first dropped my bike it broke off a turn signal. The problem is that the turn signal is fine, but it broke where it bolts into the headlight housing. To better explain: There is a small part of my headlight housing broke off and I need a glue that will properly put it back together to ensure my turn signal doesn't slip out.
I tried an epoxy as instructed by a hardware store here....but it never bonded. Ideas?
brandonmccann is offline   Reply With Quote
Old 02-07-2013, 08:05 PM   #2
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,442
Just use some silicone.
tbarstow is offline   Reply With Quote
Old 02-07-2013, 08:11 PM   #3
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,654
Contact cement works rather well.
henrymartin is offline   Reply With Quote
Old 02-07-2013, 08:24 PM   #4
brandonmccann OP
Oddometer: 39
What kind? I'm not familiar with any adhesive besides epoxies, silicone, jb weld, normal glue, and gorilla glue..
Old 02-07-2013, 09:04 PM   #5
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,649
Does it have to look good? One of the expanding polyurethane glues like gorilla glue stick to anything and fill gaps, but they are unsightly indeed.
A picture would help, but for a repair such as you are describing, I would rough up the inside of the headlight and the cracked area, and dip a piece of fiberglass cloth in epoxy and stick it on there, use masking tape to hold every thing in position until it sets up.
Just trying to visualize what you are working with.
AviatorTroy is offline   Reply With Quote
Old 02-08-2013, 06:46 AM   #6
kantuckid
Oddometer: 3,084
send a pic then you'll get information based on the situ at hand- thisguessing is pointless!
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-08-2013, 09:49 AM   #7
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Epoxies maybe but sure not the 5 minutes type, they'll set before they bond with the plastics. There are some epoxies just for plastics,mostly are of the slow cure type. I have to buy some of the Permatex for another job, also plastics.Need another few minutes digging up the specs/cure times.
My bike came with a turn signal fixed with them expanding poly, sure failed and sure messy and hard to clean later to redo that job.
I have some industrial strenght CA here, the better Krazy glue I may go try it later if just to satisfy myself that it does or doesn't work as advertised on the package. Should work, sold for them applications at motorcycle rallies.
If all else fails, I may just go to my big tube of Polyurethane construction adhesive for decks and subfloors, that stuff sticks to just about anything. Always some of that around here.
Have tools, will travel!
Old 02-08-2013, 10:38 AM   #8
The PacRat
I'm that other guy
The PacRat's Avatar
Oddometer: 2,693
This is a handy website
http://www.thistothat.com/
If a hammer don't fix it, then it's an electrical problem.
The PacRat is offline   Reply With Quote
Old 02-08-2013, 01:18 PM   #9
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,052
without knowing the material out of which the headlight shell is made, anything psoted is a shot in the dark.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 02-10-2013, 08:03 AM   #10
nbsdave
Oddometer: 306
good site!
nbsdave is offline   Reply With Quote
Old 02-13-2013, 08:36 PM   #11
brandonmccann OP
Oddometer: 39
I used a 5 minute epoxy in the end and it held pretty well. The signal stays in by itself, it's just I don't want to rely on the rubber insert to keep it connected to the headlight.
Anyways, the housing is constructed of ABS plastic and I still don't know of a really good method of getting it back on..permanently. I'd add a picture but apparently I don't have the permissions to do so. I'll upload one to tinypic in a bit I suppose...
Times are GMT -7.   It's 05:47 PM.
