Old 01-25-2013, 11:53 AM   #1
dsy OP
dsy's Avatar
Oddometer: 55
Headlight bulb retainer fix
Thought this might help others. If you have had to change a headlight bulb and were able to do it with out breaking those little plastic nubs off that keep the wire bulb retainer aligned, you were lucky. They break off very easy and then do not hold the bulb properly. the dealers solution is to charge you $500. for a new headlamp assembly so there is a chance it will break again. The easy fix is cheap and permanent. Go to your local hardware store and buy a piece of aluminum step flashing which should cost about 25 cents or just cut a piece out of your local favorite brew can after appropriate draining. Cut a piece out about an inch long and just wide enough to fit in between the bulb retainer clip. Bend it in half and then punch or drill a hole through it for the screw.
Here is a pic of what your looking for
And a pic of it installed. Makes hooking and unhooking those clips an easy one handed operation.
Doug
2012 1200GSA
2007 JK Wrangler with diy hemi install
GS GSA Oil Cooler guards http://www.advrider.com/forums/showthread.php?t=860275
dsy screwed with this post 01-25-2013 at 12:20 PM Reason: included def's suggestion
dsy is offline   Reply With Quote
Old 01-25-2013, 12:10 PM   #2
def
I have little to say
def's Avatar
Oddometer: 6,312
Send a message via Skype™ to def
Could we use a beer can (an empty one, of course) instead?
def is offline   Reply With Quote
Old 01-25-2013, 12:11 PM   #3
dsy OP
dsy's Avatar
Oddometer: 55
Even better A green solution.
2012 1200GSA
Old 01-25-2013, 12:47 PM   #4
def
def's Avatar
Oddometer: 6,312
Hmmmmm......I don't recall any green beer cans only ginger ale.......anybody?
Old 01-25-2013, 01:10 PM   #5
jachard
Oddometer: 397
There's one in every crowd......
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
www.racersandranchers.com
jachard is online now   Reply With Quote
Old 01-25-2013, 01:22 PM   #6
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 600
Rolling Rock, duh.
Current: 93 R100GS, 04 XR650L
Prior: 73 CB350, 77 R100/7, 83 R100RT
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 01-25-2013, 02:14 PM   #7
LaurelPerryOnLand
Oddometer: 2,416
If you're short on beer cans...(oh dread) ...these are 65 cents for 6!
Should be able to get something similar at HD and Lowe's!
Just get rid of the triangle steel wire and insert the clip!
They're called picture hangers!
I found 'em here: http://www.govart.com
LaurelPerryOnLand is offline   Reply With Quote
Old 01-25-2013, 04:40 PM   #8
WindSailor
WindSailor's Avatar
Oddometer: 329
Thanks 'dsy' and Robert.
Next time my headlight assembly comes off - this will be the next addition. Yep already broke those tabs off and have a washer on it, but I like this idea a whole lot better.
A buddy of mine had a headlight go out on his bike - pulled over - had the side stand down - and was *really getting into it concentration and all and *&^$#!&^* - and the biked tipped over. Luckily he got his hand out before it hit the ground. This will help in those moments.
Green cans? Isn't that the 2% meant for the 'Geriatric' crowd like def? Nope - sorry - that was Ginger Ale... my bad. He had it right.
WindSailor is offline   Reply With Quote
Old 01-25-2013, 06:12 PM   #9
rdwalker
Oddometer: 2,439
Originally Posted by dsy View Post
... Go to your local hardware store and buy a piece of aluminum step flashing which should cost about 25 cents or just cut a piece out of your local favorite brew can after appropriate draining. Cut a piece out about an inch long and just wide enough to fit in between the bulb retainer clip. Bend it in half and then punch or drill a hole through it for the screw... Doug
Doug: a very nice solution. Of course, any solution that requires draining a can of your favorite adult beverage is NICE!
About the screw that holds down the clip: it's now a very long time since I opened and looked at the assembly and I do not recall if it is an existing item.
Is it? Or, did you have to drill a seat for it in the housing?
Tnx. Robert.
rdwalker is offline   Reply With Quote
Old 01-25-2013, 06:53 PM   #10
def
def's Avatar
Oddometer: 6,312
My beer (Yuengling) comes in a brown bottle. Sorry.
Old 01-25-2013, 06:54 PM   #11
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,393
Nice solution...I just grabbed a washer for the screw and it has worked, but I must say yours is more elegant.
EJ_92606 is online now   Reply With Quote
Old 01-25-2013, 08:07 PM   #12
dsy OP
dsy's Avatar
Oddometer: 55
Tnx. Robert.
Yep the screw shown in the 2nd pic is the stock screw. All you need to add is the tab with a hole for the screw. It should have come from BMW like that.
Doug
2012 1200GSA
Old 01-25-2013, 08:47 PM   #13
guitarin
guitarin's Avatar
Oddometer: 150
Exactly what I did!
Spokes
guitarin is offline   Reply With Quote
Old 01-26-2013, 02:48 AM   #14
everycredit
everycredit's Avatar
Oddometer: 267
Originally Posted by ignatz72 View Post
Rolling Rock, duh.
That's not beer, silly. That's water!
everycredit is offline   Reply With Quote
Old 01-26-2013, 06:02 AM   #15
TomDac
TomDac's Avatar
Oddometer: 263
Beer in a can???? Fail
Hayward, CA
2006 R1200GSA - aka "Gretel"
http://www.flyv65.com
TomDac is offline   Reply With Quote
Times are GMT -7.   It's 12:40 PM.
