Old 07-25-2013, 01:33 PM   #121
pilot3
Oddometer: 421
Outstanding help!
Just hung up with Jim regarding an Ohlins shock for a Tiger 800 Roadie. Outstanding service from him!
Thanks again Jim, we will talk again soon.
pilot3 is online now   Reply With Quote
Old 07-25-2013, 04:55 PM   #122
koma
Oddometer: 29
any ohlins with or without remote preload adjustor for a 2012 honda nc700x?
koma screwed with this post 07-26-2013 at 12:04 AM
koma is offline   Reply With Quote
Old 07-25-2013, 09:11 PM   #123
XLifeRider
Oddometer: 13
2007 BMW F800s front and rear...anything?
Tia
XLifeRider is offline   Reply With Quote
Old 07-26-2013, 07:07 AM   #124
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Location: Near Six Flags Great Adventure in "God's country"
Oddometer: 388
Hi KOMA ! 2012 Honda NC 700 x OHLINS Shock
Hi Mr Koma-
Attched pic of both below,
1) The Top one is Ohlins HO 070 is a S46DR1 /
and is currently in stock
2) The bottom one is When we make it with "Integrated Preloader" version ,
NOTE: on the bottom one,
the "Intergreted preloader " can be slightly rotate by customer as needed for better access.
Hope this info Helps!!
thanks!
www.Ohlinspro.com 732-928-7800
Ohlinspro screwed with this post 03-28-2015 at 07:14 AM
Ohlinspro is offline   Reply With Quote
Old 07-26-2013, 07:15 AM   #125
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 388
Hi Mr. X-Liferider 2007 BMW F 800S OHLINS Shocks
Hi Mr, X
BMW F 800 S
2007- on..........
Two popular Options
Top Pic above is simalar to base model without remote preloader
The BAse shock is BM060 S46DR1
The Second One(SHOWN BELOW) (has PRELOADER) BM706 S46DR1S
Many Thanks!
Old 07-26-2013, 05:10 PM   #126
koma
Oddometer: 29
Ok thanks for the prompt reply Jim let me work it out
and i get back to you. Btw is there any version with a
Hose mounted hydraulic spring preload adjuster??
Old 07-26-2013, 06:18 PM   #127
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,451
I have used ProPilot for years and they have always done a fantastic job. Completely transformed my 1150 GS and my F650 Dakar.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 07-28-2013, 08:55 PM   #128
cug
Oddometer: 4,971
Quick question: my wife complains about the harsh ride on her 2013 R1200R and it seems (!) that the degraded comfort is mainly on the too harsh front end which might also be slightly wrong for her weight.
What would you recommend for the R given these rider specs:
- 58kg rider weight before any gear, probably about 10kg of gear including helmet
- mainly used for touring (medium distance, 200 to 500 miles per day)
- riding is often with side cases, estimate is about 50% of all miles covered are with side cases and other luggage
- no passenger, ever
cug is offline   Reply With Quote
Old 07-29-2013, 07:20 AM   #129
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 388
Mr Koma (UPDATEd PIC) Bm 706
Hi Mr Koma-
This is the PIC for the BM706 you asked about WITh REMOTE Prealoader-
(I Loaded Incorrect Image Before)
(If Does'nt Load /try right click Refresh Browser) I can Email You Direct also
Old 07-29-2013, 08:20 AM   #130
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 388
Hi CUG -BMW 2013 R 1200 R
Hi Cug-
Super -cool bike (Non ESA Version I Presume?)
I'll PM you some more "Rider Sag" Base Measurements to take as a "Field-Check"
UPDATE ALERT WE DO HAVE 2011-2013 BMW R 1200R OHLINS!!!!!
The Previous years we used Front Sprgs of 57n/m and 190n/m rear Standard,
That way to Stiff springs for thw Wife at 128lbs and 22 lbs gear
Front and Rear "rider Sag" Should be checked at between 30-40mm ,
I'll PM if you Dont know how
Old 07-29-2013, 08:31 AM   #131
cug
Oddometer: 4,971
Excellent, we'll check these.
And no, the bike does not have ESA.
We Don't have Ohlins Frt And Rear for the 2013 -
What we had measured as rider sag was with my wife on the bike the front did around 35mm and the rear around 40mm (if I recall correctly, we did a setup when she first got it). The pre-load is nearly completely backed out at the rear, no adjustment at the front. I also softened the rear rebound half a turn from standard.
She still feels like being bumped around a lot.
Old 07-29-2013, 09:49 AM   #132
OaklandStrom
Oddometer: 1,612
PM sent with Wee Strom questions...
OaklandStrom is offline   Reply With Quote
Old 07-30-2013, 08:23 AM   #133
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 388
Yes Mr Cug-
Thanks For the "Intell"/"measurements"
Most likely 22%+- (Average Guess ) too much Spring Rate- for the Mrs.
Ohlinspro screwed with this post 03-28-2015 at 07:15 AM
Old 07-30-2013, 08:32 AM   #134
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 388
Hi Mr Oaklandstrom Suz DL650 Ohlins
Hi Mr Strom-
Ohlins has a S46DR1S shown below
called a SU823
They are IN Stock -and-Ready-to-Rock!
They Offer "Same But No Preloader "
THIS one Above PICTURED is Better WITh PRELOADER its sorta Nicer to have 22-23 turns Spring preload on the Fly.
www.Ohlinspro.com
732-928-7800
Old 07-31-2013, 08:24 PM   #135
cug
Oddometer: 4,971
Ah, darn. I feared that as the bikes are normally set up for a ~75kg person.
Okay. That leaves me now wondering what can be done for her. I guess a suspension shop could re-spring the shocks. Or is Öhlins planning on anything for the 2011+ R1200R models?
Times are GMT -7.   It's 08:59 AM.
