02-08-2013, 08:34 AM
#1 |
Nobody Home
Chemical Engineers: How to Soften Rubber?
I recently read, on another forum site, that a 50:1 mixture of water to wintergreen oil, heated to just below boiling, will 'restore' old rubber (carburetor boots, etc.) to "like new". Another inmate there opined that a mixture wintergreen oil and toluene will accomplish the same thing.
Is this really the way to "restore" rubber or are the chemicals basically breaking down the rubber and the interim state is simply close to the way the rubber was when new? I'm more curious that anything. TIA.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
02-08-2013, 09:04 AM
#2 |
A proud pragmatist.
Oddometer: 2,859
I really looked at that last year. They were getting good results and maybe too good, leave it in too long and too much softening/expansion then they had to wait until it dried out and shrunk back to normal.
![]() But you should know that there are special rubber greases that will do almost the same. May not work for badly damaged and dried rubber but sure good for slightly dried out stuff. Very good at preventing the drying and cracking, I have been using that for many years. Big tube was empty after 20-30 years and I found out how difficult it is finding that in Canada/US nowadays, had to order another 20 years supply from the UK. Cheap, less than $20.00 to my door for 500gr. Google Miller Red Grease....Castrol Red Grease or PBR Rubber Grease.Great stuff to rebuilt brake systems, fully compatible with brake fluids and best of all no silicones. The last is very important if your bike(s) has an O2 sensor and you want to lube any rubber in and around the fuel/air delivery systems.
Have tools, will travel!
02-08-2013, 10:01 AM
#3 | |
Location: 40 Square Miles Surrounded By Reality (Madison Wi)
Oddometer: 1,462
EDIT: here is the thread I was thinking of. http://forums.sohc4.net/index.php?topic=29707.0
Dave in WI 2002 ZRX1200R 1975 XL100 1988 DT50 "Daddy, it's five o'clock sometime!" Dave in Wi screwed with this post 02-08-2013 at 10:07 AM |
02-08-2013, 02:44 PM
#4 |
Oddometer: 759
It sounds like you don't really want to soften rubber. You want to return it to original durometer and elasticity.
You can't, in general. As it ages, rubber loses the plasticizers that are incorporated into the chemical mix. Continued cross-linking sometimes also makes the rubber harder as it ages. This is the reverse of men BTW. You can soften rubber with different chemicals though. Naptha also works for some others, MEK. But, they're being partially dissolved if uncured.
R1200RT (R1100RT gone) KLR650 Don't be the guy who needs to pee on the fence to figure out that it's electrified. |
02-08-2013, 05:06 PM
#5 | |
Semi-reformed Tsotsi
Oddometer: 778
02-09-2013, 05:27 AM
#6 |
Oddometer: 1,654
Seems I read that glycerin was good to wipe down things like door seals on autos .
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85 |
02-10-2013, 05:25 AM
#7 | |||||
Nobody Home
02-10-2013, 08:35 AM
#8 |
A proud pragmatist.
Oddometer: 2,859
I used that again yesterday on some older rubber.
http://www.millersoils.co.uk/scripts...dsegmentID=267 Different products....more specs, even a website on rubber greases. Just found that: ![]() http://www.redrubbergrease.com/red-r...l-girling.html And for some reason, not well known in North America them rubber greases. Been through that somewhere else, sure was glad for some continentals that came on that thread and supported my views on such products. ![]() Not perfect but certainly helps to bring back some of the elasticity. I use it mostly "preventively", never had to replace too many,if any, rubber pieces where I used it. BTW, gave some of my stash to a friend, he really likes it. As a motorcycle restorer, he is quite familiar with dried out old rubbers. ![]() GM used to sell what we called "Latex" back in the days. Mostly used to maintain weatherstrips when they were still made with real rubber. Whitish liquid that somehow penetrated the rubber. But....that was back then, haven't seen that around for a very long time.
