03-06-2013, 04:21 PM
#136 |
Oddometer: 533
Anyone flying these commercially, or know anyone that is?
I got interested in these a couple of years ago with the intention of commercial applications. I decided to take a step back for a while as the development is moving so fast its difficult to keep up. In the meantime I bought a little quad called a Jump Jet, made in the UK. Its very crash-able, which is good as its a little bitch to learn to fly as it has no automated fly control. Master one of those and you can fly anything. I'm in Sydney, Australia and our governing aviation body, CASA, jumped on these things very early. There have been some commercial operators working with the regulator, but theres a bunch of regulations that look like they won't budge from: No flying over built up areas of any kind. Ceiling height 400'AGL Pilot must maintain line of sight at all times. Thats before we get to a bunch of stuff about privacy issues, etc. The biggest worry is lack of redundancy when something goes wrong. This is also why these things will never be scaled up to carry real people. Also the complexity for such an aircraft makes it cost prohibitive. |
03-08-2013, 08:25 AM
#137 | |
Swabee
Oddometer: 5,607
The HT-FPV quad is running a 1258/1280mhz Tx and the pico Tx on the mQX quad is a 1258mhz. The Rx is also 1258/1280mhz.
06 KTM 950 Adventure S 08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn |
03-08-2013, 08:41 AM
#138 |
De Oppresso Liber
Oddometer: 30,760
What is the cheapest one of these I can get that will carry my GoPro?
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. Straight Out Da Trailah! |
03-08-2013, 09:09 AM
#139 | |
Swabee
Oddometer: 5,607
$20 in wood and hardware $30 for flight controller $15 receiver $80-100 motors (quad) or $60-80 motors (tri) $60 ESCs $20 battery $20 for wiring harnesses, tape, velcro, etc. $20 yaw servo (tri) That is what I have found but you could buy used or use lower-end running gear. Here is an RCgroups.com link that talks about a cheap kit tri that could easily be made into a quad. http://www.rcgroups.com/forums/showthread.php?t=1792533 I'm going to build one of these next. I think if I upgrade my quad I'll slap its motors onto a cheap tri-frame and use that for fast, aerobatic flying and keep the quad as a heavy-lifter camera platform.
03-08-2013, 09:11 AM
#140 | |
Funk Soul Bruvah
Oddometer: 5,851
Keep us posted on your results. I'm sorely tempted to order that Pico stuff to run on my MQX and Crack Yak... :)
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own." - Otto von Bismarck <>< |
03-08-2013, 09:46 AM
#141 | |
Kilted Terror
Location: I've narrowed it down to 'earth'. Or 'Baltimore'.
Oddometer: 1,812
![]() Please post pics of your build as you go! |
03-08-2013, 11:50 AM
#142 | |
Ridin Dirty
Oddometer: 356
I am doing the same! I've found the aerobatic limits of the DJI Naza.. I am going to keep that as the FPV ship and build myself a little hot rod tri-rotor. Either that or a V-tail design - those look sick too. Either way it will be aerobatic and fast.
2000 KTM 200 EXC |
03-08-2013, 12:42 PM
#143 |
Swabee
Oddometer: 5,607
03-08-2013, 12:50 PM
#144 | |
Swabee
Oddometer: 5,607
The V-tails are pretty neat! I think I'll try a T-copter with standard servo-driven yaw control. FYI, non-multirotor guys, a tricopter is a y-shaped multi. A T-copter looks like a T. It's more suited for camera work because it the two front arms are straight, not forward-swept. I will be at work for snow removal most of tomorrow as we're expecting a blizzard. So, I may as well put the scrap wood in the carpentry shop to use
03-08-2013, 04:43 PM
#145 |
Not quite a full house
Oddometer: 394
![]() Any of you guys tried one of these yet? Looks pretty interesting. It's not cheap at $229 with GPS, but that's quite a bit less than the NAZA-M controller. It offers GPS waypoints, position loiter, auto takeoff & land, telemetry, data logging, camera control, etc etc. http://store.diydrones.com/APM_2_5_N...-apmpwrkt2.htm
_______________________________ http://gbergimages.smugmug.com Saget's Rides: 2008 Kaw Connie14 2005 Kaw KLR650 2003 Hon CRF450R |
03-09-2013, 07:14 AM
#146 | |
Funk Soul Bruvah
Oddometer: 5,851
http://www.rcgroups.com/forums/showp...35&postcount=2
Crius Pro still gets a lot of love as the best bang for buck out there.... Quote:
03-09-2013, 11:58 AM
#147 |
Swabee
Oddometer: 5,607
Well, Chisenhallw asked for progress photos of my build. Like I said, I'm stuck at work plowing. So, between plow rounds I hung out in the carpentry shop at work and built this with scrap wood.
Front arms are 13.5" and each go 3" into the 6" wide body. Rear arm is 15" long and also goes 3" into body. I made a U-shaped slot for the rear to slide into. Body is two pieces of 1/2" Gatorfoam or Gatorboard and is 6" wide by 14" long. Ends are tapered. It was scrap. Good thing, too, that stuff is over $3.00 a square foot. Entire body was Gatorfoam but I cut the front ends off and glued on a strip of wood for more strength. I copied an RCgroups.com design, the one I linked to in response to Sniper X's cost question. Uploading pics in a minute... It started with a drawing on the white board ![]() Then off to the shop for scrap. This is what it started looking like. ![]() ![]() ![]() And here is where I am now.
06 KTM 950 Adventure S 08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn DakarNick screwed with this post 03-13-2013 at 07:13 AM |
03-12-2013, 07:42 AM
#148 |
Swabee
Oddometer: 5,607
Ok, so that last one I built looked pretty good for what I had into it, which was $0 and a few hours work. But it was heavy. 371g (13.08 oz) just for the frame as it sits in the photos. Pretty heavy considering I still need to add three motors, three props, three ESCs, a distro block, battery, FC, servo, yaw mechanism, etc.
I'm going to start over! This isn't just about being lightweight, but super simple to repair and replace. I bought some 6"x1/4" balsa sheet and 24"x3/8"x3/8" basswood square stock. I'll take some pics as I build.
03-13-2013, 07:39 AM
#149 |
Swabee
Oddometer: 5,607
I feel like I'm just talking to myself, lately
But here are some progress pics. Well, all the pics, really. I didn't stop to take any pics during the build because I am bad at it and usually forget. It is simple and the pics will show this. The front arms fold back for ease of transport. ![]() ![]() Tri-copters have three propellers, so that means they will have extra torque in one direction, depending which props you put where. I will be putting two clockwise props on, one on the left front and one on the rear. The right front will be counterclockwise. The front of the T-copter will want to yaw to the right. So, some right cant (angle) will need to be built into the rear prop to bring the tail to the right, the front to the left. Yaw mechanism. Servo rotates it on one end. The other end is a 4mm bolt going through a bearing. ![]() More pics as I upload them, stay tuned.
06 KTM 950 Adventure S 08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn DakarNick screwed with this post 03-13-2013 at 07:58 AM |
03-13-2013, 07:47 AM
#150 |
Kilted Terror
Oddometer: 1,812
| Thread Tools | |
