Old 09-22-2013, 01:45 PM   #466
mapa63
Bikerider
mapa63's Avatar
Oddometer: 31
Very satisfied so far!
Thx Erling!
I'll take U up on that, saving map-versions. Didn't for starters but as one develops them they become increasingly valuable!
About SAS, PAS soforth, I still have the circuitry connected, the only block is a wood plug in th #17 valve, so the bike can't get air that way. As the map evolved, popping on decel is all but gone.
Uploaded the FUEL map so far, and the target AFR I used from Dynojet! Any thoughts are most welcome. The idle-hop, strangely, is better?!?!
The nigt ended in cold weather, rain pouring down. Had an impact on idle when no load was on the Engine. A bit twitchy when just on the side stand. Worked great anyway when actually putting a gear in, riding the bike. I guess U have to ride under those conditions and trim for that aswell...
Initial FUEL, starting point:
FUEL as of now, with 6-7 trims accepted:
AFR
Riding a bike is living!
Memories: Kawa W650, BMW K100RS, BMW R100/7, Yamaha XJ600, Husqvarna 250 WR, Triumph TR6 Trophy, Suzuki Stinger 125
mapa63 screwed with this post 09-22-2013 at 02:39 PM Reason: Trying to add and adjust pics!
mapa63 is offline   Reply With Quote
Old 09-22-2013, 02:46 PM   #467
ebrabaek OP
Oddometer: 4,712
Fantaboulistic...... It would be interesting if you one day could return the SAS to stock, and ride it, as I would like to see if I am the only one that felt the bike runs worse with it capped.
Erling
Old 09-22-2013, 03:04 PM   #468
mapa63
Bikerider
mapa63's Avatar
Oddometer: 31
Maybe, maybe, it would take some trimming again and reworking the process. According to old answers from DJ, they only recommend blocking the hose. Nothing about the rest of th SAS, the solenoid, reed-valves and other components.
I wonder how this FUEL table can have an impact on the idle hop-off!?! It just seems to have made the mix leaner!?! Well, it seems to work anyway...
Time to bid you good night! A million thanks!
Old 09-22-2013, 04:23 PM   #469
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,669
Ebrabaek, any noticeable change in fuel economy?
Thank, David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 09-22-2013, 04:27 PM   #470
ebrabaek OP
Oddometer: 4,712
Yeppers....... Happy riding.
Erling
Old 09-22-2013, 04:34 PM   #471
ebrabaek OP
Oddometer: 4,712
Thank, David
The mpg, is about the same. When I do the tank vs miles I end up about in the mid to upper 50's. The computer will yield about the same results..... Perhaps a mile or two more, but overall nothing has changed since I did this. I wish there was a better chip, thyat worked with the BMSK, rather than against it. Dyno Jet have been ok, but not able to add anything that is not already in this thread. When you approached them on other issues, like coolant hook up, or other of the hook up the PC-5 is capable of, they they are worthless. Looking back at this, I would do it all over again, but their product is overpriced. The two should run about 300-350 us$. It does fix the fueling, but I wanna know more, and no body at DJ have been able to add to this. I will have a look this week, and change the mapping to 13.8, on the below 50% throttle, and see what happens.
Erling
Old 09-22-2013, 09:42 PM   #472
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,669
Thanks. More better power and same fuel economy is a win in my book. Good job.
David
Old 09-23-2013, 06:27 AM   #473
ebrabaek OP
Oddometer: 4,712
David
Thanks David....
Erling
Old 09-24-2013, 07:59 AM   #474
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,195
Hi Erling, the BMW-AF-XIED will be available at Beemerboneyard next week. Price with cables is about $200. One adjustment control but no computer needed. It works with the BMSK and leaves it fully functional.
Jscottyk has been beta testing it this summer. Same great results as on the 1100, 1150, and 1200.
RB
roger 04 rt is offline   Reply With Quote
Old 09-24-2013, 08:41 AM   #475
mapa63
Bikerider
mapa63's Avatar
Oddometer: 31
Originally Posted by roger 04 rt View Post
Hi Erling, the BMW-AF-XIED will be available at Beemerboneyard next week. Price with cables is about $200. One adjustment control but no computer needed. It works with the BMSK and leaves it fully functional. RB
Very curious, checked it out. It never enriches to more than 13.8? Is it overkill to use DJ:s maps, that vary between 13.2 and 13.8 or so?
Best regards,
Mats
Old 09-24-2013, 08:50 AM   #476
ebrabaek OP
Oddometer: 4,712
RB
I have been watching this, but before I decide, I would like to see, and know more about it, and would like someone to stick it on a dyno, for validation purposes. I was expecting more post from JS, during the beta testing.... But as a beta tester for Rekluse, I understand how you cannot comment much during testing...... I am interested, as more is published.
Erling
Old 09-24-2013, 12:18 PM   #477
roger 04 rt
Oddometer: 2,195
Best regards,
Mats
There are actually a couple settings that are richer than that.
You'll find this interesting: the maps that you're looking at with targets of 13.2:1 at full throttle are too lean. That's a problem with Autotune, you have to have the skill to pick the correct target.
For example, on my 1150, WOT produces an AFR of about 12.8:1. Your F800GS does too, in stock configuration no less.
Old 09-24-2013, 01:10 PM   #478
mapa63
Bikerider
mapa63's Avatar
Oddometer: 31
Really interesting, trying to learn this! Do you believe that the DJ target AFR:s, the ones I posted, could be improved upon? Does the AT work well enough to reach those AFR:s? I'm a complete beginner, bought the DJ stuff a year ago mainly to make the low speed, low gear manouvering better and lessen the idle hop-off effect.
Any thoughts are most welcome! The bike runs clearly better with the PCV+AT than without, but it seems as if even more can be achieved?
Best regards,
Mats
Old 09-24-2013, 02:11 PM   #479
terryckdbf
Oddometer: 1,001
Erling
I understand wanting to see a Dyno, I just don't understand the relevance. I am trying to understand how a Dyno run relates to idle hop, low rpm surging, or off throttle response. Is the product designed to increase horsepower or better throttle control? Dyno's are essential for building a motor to run on a track but I have yet to see anyone ride that way on the street.
With all of the data we have seen maybe a Dyno would validate it but I do not see how. There would still be quedtions regarding the accuracy of the Dyno and the skill of the operator and various other conditions.
Again, I totally understand wanting to know things, that is good, I question how a Dyno will relate to the things we are wanting to correct.
I'm interested in your thoughts.
Be well.
Terry
terryckdbf is offline   Reply With Quote
Old 09-24-2013, 02:22 PM   #480
ebrabaek OP
Oddometer: 4,712
Originally Posted by terryckdbf View Post
Erling
Be well.
Terry
Quite elementary My Doctor Watson....... Sorry I couldn't resist. It is quite simple though, as using a dyno takes the rider out of the equation. It is, and should be docced, with a dyno run before, and after install to see what has/is changing, as many like who puts on an open pipe, will swear it runs better, but are fooled by the larger perceptual noise output of said pipe. As we are all ( most I think) not just chasing a better running bike ( idle hop, and control) but more power in general. Then the only way to verify this is with a dyno. Off course we don't all have to do this, but as with new apps.....I do not trust DJ a bit with their dyno graphs, but had access to a great tuner, and validated the results of my install with the dyno. Your product is new, and in my humble oppinion should be dynoed as well, as it could proove usefull, not just for the general running of the bike, but as a performance tool with an open exhaust system.
Erling
Times are GMT -7.   It's 03:22 AM.
