| View Results: What is the horrible noise? | |||
| Cam chain tensioner |
2 | 5.13% |
| Camshaft rockers / bearings |
10 | 25.64% |
| Big end |
10 | 25.64% |
| Gearbox main shaft bearing |
3 | 7.69% |
| Crankshaft bearings |
8 | 20.51% |
| Other? |
6 | 15.38% |
| Voters: 39. You may not vote on this poll | |||
02-09-2013, 04:02 PM
#16 |
I.Hopp.
Oddometer: 3,078
What year is your bike?
640 A x 2 |
02-09-2013, 06:38 PM
#17 |
boss of the box
Oddometer: 463
Ha ha, Hold it up to the phone again! wait, it sound like opportunity knocking.
If motor was quiet, then got loud and you have oil in the motor, then its tear down time. Taking a pole and getting advise is kinda silly. Sorry my friend, shit happens. Cheers
Laws of the motorcycle universe. 1. Ya don't need a faster bike, just ride faster. 2. The natural state of a motorcycle is on its side. 3. My bike and its owner are faster than yours. http://www.advrider.com/forums/showt...hlight=klxmack |
02-10-2013, 06:49 AM
#18 |
I.Hopp.
Oddometer: 3,078
[quote
Refer to that thread now, so far no end float in either side of crank, clutch seems fine. Counter balance outer case bearing is fine, but without removing there seems to be a lot of play on the inner bearing. Waiting for tools to arrive to remove. I have a sneaking suspicion it is the counter balance and the cam rockers.quote] There doesn't have to be end float on either end of the crank for the bearing to be bad, the running surface of the races only need to be galled... If you have the head/cylinder off you can spin the crank rapidly around in the case and listen for the grinding noise to indicate a rough bearing... As for the balancer being shot, I have a sneaking suspicion that you won't get away that easy, but one can only hope...
640 A x 2 gunnerbuck screwed with this post 02-10-2013 at 06:55 AM |
02-10-2013, 07:10 AM
#19 |
Nob.
Oddometer: 122
Turning it over by hand with the spark plug out doesnt give me any noise, atm I am suspecting counter balance and possibly cam... just waiting for strap wrench to arrive to get clutch off
AR50,TS125X,DTR125,MTX125,KDX200,KL250,DR400S,DRZ4 00S,XJ400N,XR400R,CBR600F,DR650,XS650,GSX750F all helped me whittle myself down to a KTM640E perfect bike!
02-10-2013, 07:17 AM
#20 |
Red Clay Halo
Oddometer: 11,162
So, what's the oil look like?
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
02-10-2013, 08:43 AM
#21 |
Nob.
Oddometer: 122
Fair amount of pulverised steel on the plug,
corrr
02-10-2013, 12:23 PM
#22 |
Oddometer: 3,807
Well that ain't good.................
"Deeply flawed people make deeply flawed decisions." |
02-10-2013, 01:38 PM
#23 |
BITD/Rallye
Oddometer: 5,306
my money is on a bad big end .. scored cylinder
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
02-10-2013, 09:52 PM
#24 | |
Traveler
Oddometer: 4,002
To loosen the nut I'd heat it with propane first in case someone used red loctite on it, then put it in gear and have someone stand on the rear brake and knock it loose with the air or a hammer. Think that should work if the chain is on...or does the basket just spin? bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
02-10-2013, 09:54 PM
#25 |
Nob.
Oddometer: 122
If that is the case, am I better off getting just a new bearing, or buying a whole crank assembly?
The noise was definately loudest at the front left of the engine. It actually seemed quite quiet when you got your head right up to the right side.... but we will see....
02-11-2013, 05:05 AM
#26 |
Oddometer: 253
Not sure how relivent it is to you but I posted I had similar knocking noise to your bike in mine. Thought it was clutch related as it sounded noisiest there. Dropped the oil and found metal on the sump same as yourself, no obvious sign of wear anywhere. He pulled the starter cover and the ring gear on the motor had shredded. So for me easy fix. Replace gear and ring bearing on the starter.
2008 KTM 640 adventure. Africa Twin XRV750 RD04 IBA membership no.35934 "In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar - |
02-11-2013, 07:50 AM
#27 |
Nob.
Oddometer: 122
Was the bike still starting fine on the button?
02-11-2013, 08:40 AM
#28 |
Nob.
Oddometer: 122
Also, has anyone ridden their 640 long term without a balance shaft? Generally I don't care about vibrations, and just imagine... 0.0001 extra hp at the rear wheel!
02-11-2013, 09:19 AM
#29 |
Oddometer: 253
Yes started first time every time.
2008 KTM 640 adventure. Africa Twin XRV750 RD04 IBA membership no.35934 "In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar - ericGSsti screwed with this post 02-11-2013 at 10:14 AM |
02-11-2013, 09:44 AM
#30 |
Oddometer: 199
SOUNDS ok to me.
