View Results: What is the horrible noise?
Cam chain tensioner 2 5.13%
Camshaft rockers / bearings 10 25.64%
Big end 10 25.64%
Gearbox main shaft bearing 3 7.69%
Crankshaft bearings 8 20.51%
Other? 6 15.38%
Voters: 39. You may not vote on this poll
Old 02-27-2013, 12:43 PM   #46
Broooce
Oddometer: 5
You might want to check out this thread...lots of similar talk to your problems...
Go to:
http://www.advrider.com/forums/showt...=118095&page=3
and on to page 3...
Hope this helps, as my friend left his bike to me with similar issues this week.
Broooce is offline   Reply With Quote
Old 02-27-2013, 06:55 PM   #47
Rocket Scientist
Oddometer: 24
My money is on a spun crank bearing.
Rocket Scientist is offline   Reply With Quote
Old 03-02-2013, 05:26 AM   #48
moto_psycho OP
Nob.
moto_psycho's Avatar
Oddometer: 122
Not enjoying orange as much as the next guy.
moto_psycho is offline   Reply With Quote
Old 03-02-2013, 05:27 AM   #49
moto_psycho OP
Nob.
Oddometer: 122
Old 03-02-2013, 07:43 AM   #50
moto_psycho OP
Nob.
Oddometer: 122
Looks like bad scoring, but you can't even feel it!
Old 03-02-2013, 07:46 AM   #51
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,600
Originally Posted by moto_psycho View Post
Do those roller bearings on the rockers have any play in them?
Old 03-02-2013, 08:20 AM   #52
moto_psycho OP
Nob.
Oddometer: 122
Sideways play in the rollers, no up/down or twist.
Guessing the stator cover doesn't seal very well!
Old 03-02-2013, 08:46 AM   #53
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,600
You been losing coolant?
Old 03-02-2013, 08:55 AM   #54
moto_psycho OP
Nob.
Oddometer: 122
Nah, but I will be rebuilding the pump.
Old 03-02-2013, 10:15 AM   #55
moto_psycho OP
Nob.
Oddometer: 122
Stuck now, need flywheel puller, spanners for the base bolts, and a large flathead screwdriver for the chain guide...
Old 03-02-2013, 07:27 PM   #56
bmwktmbill
Traveler
Oddometer: 5,143
Your cylinder looks better than mine.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 03-02-2013, 11:07 PM   #57
moto_psycho OP
Nob.
Oddometer: 122
If it's the same further down I won't get it plated. Maybe a new piston? If all I'm changing is the big end bearing then I may splash out on either a nice piston or the rally cam...
Old 03-03-2013, 12:37 AM   #58
moto_psycho OP
Nob.
Oddometer: 122
Looks like I got there just in time, plating measures well, and can't feel any damage. Piston is starting to wear so will replace that. Just gotta wait for my flywheel puller to turn up (****ing Sundays!!).
Definitely what I would call 'too much play' on the big end.
Any advice on splitting the cases?
So, the bill so far,
65 - Electric Impact Wrench
18 - Electric Screwdriver (so fed up with twist,ratchet,twist,ratchet,twist)
80 - Athena Gasket Set
22 - Flywheel Puller
And will be purchasing
136 - Pro-X Conrod Kit
140 - Wossner Piston Kit
60-80 - Crank Rebuild
So far is 448, will be rebuilding the water pump too... sigh.
Old 03-03-2013, 01:05 AM   #59
achile
achile's Avatar
Oddometer: 289
Originally Posted by Kawidad View Post
Is this a new noise or has it been loud?
The LC4 engines make a lot of weird noises without being defective.
yup...all of them sound like a can of bolts rattling around. And they do a funny thing while idleing on the stand...they move!
Moto_psycho, how are the valves?
achile is offline   Reply With Quote
Old 03-03-2013, 02:21 AM   #60
moto_psycho OP
Nob.
Oddometer: 122
How do you mean? I am yet to remove, lap and change the seals, need to borrow the spring compressor off of my Dad tonight.
How might I go about measuring the bore for piston size? Wossner have 3 sizes 0.01mm different, I know that is fuck all, but what clearance am I measuring here?
Times are GMT -7.   It's 12:39 PM.
