Old 02-09-2013, 06:36 AM   #1
xcflyn OP
xcflyn's Avatar
Oddometer: 1,093
how do I network these computers ?
Here is my deal. I have a few computers in my shop and there is wireless throughout the building. What I need to do is send files from the one that is online to the one that is not. What happened is we have one computer (PC) that is in the cabinet of a machine along with all its motion control. That computer has thousands upon thousands of dollars in software in it for running the motion control along with Cad and other drawing and conversion software. That tower has no wireless has had a ethernet cable hooked into it. What we used to do was have that computer go online and pull up mail to grab files we drew at home or someone would send us, basically emailing it to myself so to speak. Then I had a scare a month ago where that computer got something that wiped it out, the "Nerd" said if I were you I would not have this online at all. So I took it off line. But ,,,,,, it sucks, now I would have to put everything on a flash and it is a hassle to get to this computer to use that. Anyhow, How can I hook my computer that is online to this computer and just transfer information between them without the machines computer actually going online ? All my computers run XP and ideal would be that 3 of these could file share without the one going online. Funny I called the "nerd" and he says- "what you cant do it yourself", I say, "would I call you if I were clear on how to do it" - he says "well try and call my Monday if you dont get it"- I say, " dont worry I get it, you dont want to do this small job, its not worth your time, dont worry I wont be calling you". So here I sit asking you how to do this, hopefully in a few easy steps? I did have the GF look online, but its like a oil thread
xcflyn is offline   Reply With Quote
Old 02-09-2013, 07:38 AM   #2
It'sNotTheBike
Oddometer: 704
Pay the pro and get it done right the first time.
1. Your nerd is correct that a mission-critical machine running XP should not be
connected to the outside world via internet. Machines running XP are just too
easy to exploit.
2. Your best choice is to pay a pro to set things up correctly. You can create problems
you probably don't need if you start messing with the network settings of the
machines yourself. It comes under the heading of "a little knowledge is a dangerous
thing". What you want is to set up a VPN. Just pay the pro his going rate and get it
done right the first time. You are using the machine to make money, and it makes
sense to use a pro to make sure the machine is set up properly.
2.a. If the guy says to call him Monday, and he has done good work for you before, then
the smart thing to do is call him Monday like he suggested, not to get an attitude and
resolve never to deal with the guy again. Maybe he said to call him Monday because
he was swamped with work until then. Unless the nerd specifically told you he could
not be bothered with such a small job, you have no way of knowing why he didn't want
to deal with your job right away. People may have other commitments that you might not
be aware of, and obviously the guy works for other people too. If you come off like a jerk
when you are trying to deal with someone who can help you, they might not want to help
you. This ought to be obvious to anyone over the age of ten or so, but apparently you didn't
get the memo.
3. Next time you write more than a few sentences ( especially if you are asking for free
advice which usually costs money ) break what you write into paragraphs. The giant
blob of text you created is extremely difficult to read.
It'sNotTheBike screwed with this post 02-09-2013 at 08:05 AM
It'sNotTheBike is offline   Reply With Quote
Old 02-09-2013, 08:05 AM   #3
troidus
Oddometer: 6,916
Add a second NIC to the online box and use Ethernet to connect it to the offline box. Run it through a cheap 5-port switch. Configure the two NICs to be in the same network, but different from the rest of your in-house network. Make sure Internet Connection Sharing is turned off on the online box.
It's not bulletproof, but should work for your needs.
troidus is online now   Reply With Quote
Old 02-09-2013, 08:05 AM   #4
kioti
Cruzinonline
Oddometer: 205
easy to exploit.
get the memo.
The op's post is easier to read than yours, at least he didn't copy and paste from note pad and have the sentences fractured like yours.
kioti is offline   Reply With Quote
Old 02-09-2013, 08:35 AM   #5
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 286
Welcome to the world of network administration! Windows has built in networking software. If you want safety and security without much maintenance, then keep everything offline. Otherwise, there are constant patches and updates necessary for the anti-virus and Windows updates.
Basically, you want one machine to act as a server with three others having only local access. The server would then need to be secured and patched. The other machines would have only local access to this server and no internet access.
All the information to configure such a system is available online using a search engine such as Google - for free. I suggest 'local network with internet server' or 'web server LAN' as search terms to get you started. Here is a diagram link: http://en.wikipedia.org/wiki/Computer_network_diagram
Also, I believe the correct term is 'geek' rather than 'nerd' with 'pencil neck' and 'four eyed' as appropriate adjectives.
Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 02-09-2013, 09:29 AM   #6
xcflyn OP
xcflyn's Avatar
Oddometer: 1,093
Thank you Kioti for that.
Plus I did not ask for a lesson in how to conduct business. This should be easier to read then my past "blob". Funny how improper it was to ask for "free advice" My God no one ever does that on ADV
Old 02-09-2013, 11:36 AM   #7
KSJeff
Yea, I'll go
KSJeff's Avatar
Oddometer: 97
Were you surfing the net on that machine when it had it's problems? Personally, I would just hook it back up and refrain from using the browser.
KSJeff is online now   Reply With Quote
Old 02-09-2013, 01:56 PM   #8
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,139
I have a few customers that have massive manufacturing lines.
The machines connected to the robots are 100% offline because giving people even a little access ends up costing 100's of thousands of $ for them in downed production lines when they get a virus or load games.
Get a nice USB stick and copy your files over. You will be happier and it will take less time that rebuilding your controller.
2007 BMW GS Adventure
2010 Harley Ultra Limited
1975 R90/6
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 02-09-2013, 08:52 PM   #9
PeterW
Oddometer: 1,976
Windows still has the ability to copy files via the serial ports. So, if it has those already, only the correct (null-modem) cable is needed. Any that don't have serial ports, you can use USB to serial adapators.
The advantage of that is that although the performance isn't great, most virii will be 'blind' to the serial sneaker-net.
Still some messing around, but more convenient than USB sticks, which can still be a source of virus problems.
(Oh, and provided you can make the cables, you can run serial through the existing ethernet cabling - label those connectors though, RS-232 and Ethernet don't play nice with one another)
Pete
PeterW is offline   Reply With Quote
Old 02-10-2013, 07:04 AM   #10
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,146
You say it's difficult to get at the machine, I'm guessing to insert a flash drive because the USB port is buried somewhere in the cabinet?
Why don't you get a USB extender, leave that plugged into the machine, and the tag end is zip tied next to the mouse. Walk up, plug in and fire away. $5.
That's about as cheap as I can make it.
Things like computers that take a special skill set I outsource. I'm sure I could eventually figure it out, but my time is worth money and spending it trying to figure out networking when there are tons of people who already know the answer.
Easy decision for me, pay the pro.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 02-10-2013, 10:11 AM   #11
P B G
Oddometer: 9,781
I have a similar issue at work.
I have a PC connected to the Carver - it had too many issues with software getting fubar'ed by updates, needing to roll back, and connectivity issues.
So what I found is that since the only file I need to move to and from is the carve file, I use a USB - now this is annoying unless you put shortcuts to the destination.
That being, you can put a "shortcut" to the carve file folder on the one machine into the USB drive, so you open the USB drive and drag it into the correct folder.
Quick and easy like.
Old 02-10-2013, 10:22 AM   #12
VStromNC
DNS/DNF
VStromNC's Avatar
Oddometer: 535
Slightly off the subject but you can also use remote freebie services such as Googe Drive or DropBox and park any files or photos that you want to share and access from any computer with a Internet browser.
Jon
09 KLX450R (Plated)
06 DL1000K6
VStromNC is offline   Reply With Quote
Old 02-10-2013, 08:56 PM   #13
SgtDuster
SgtDuster's Avatar
Oddometer: 2,079
Hook it to your network without a default gateway; no Internet from the inside, less risky...you know this user clicking on something he should not...
This and a good firewall to protect you from the outside.
Easy, simple.
There are more complicated and "bulletproof" (network wise) methods around but I don't see myself explaining them to someone over a forum.
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster screwed with this post 02-10-2013 at 09:12 PM
SgtDuster is offline   Reply With Quote
Old 02-11-2013, 09:13 AM   #14
ericrat
Oddometer: 871
Here is what I would do. I would run an ethernet cable from the CAD machine to a nearby workstation, you may need to add a second network card, or simply use wireless on this stations connection to the rest of the network. Set the IP address on the CAD machine to one network, say 10.5.5.5 mask 255.255.255.0, no default gateway, no DNS. Set the IP address on the adapter for the "nearby workstation" to 10.5.5.1. Again, no default gateway, no DNS on THIS ADAPTOR. Don't use these addresses anywhere else.
Now the CAD machine is networked to the "nearby" workstation ONLY. Create a folder on the "nearby workstation". Right click on the folder, go the "sharing" tab and share the folder. You really should set permissions on the folder with username/passwords... Now you can "map a drive" to the folder from your CAD machine. You can open that folder on your office workstations to drop files into.
In a larger environment the process control/production networks would be seperated by a firewall. A production machine might be able to initiate a connection into the business side to grab files, but the business side of the network would never be allowed to touch the production side.
This is somewhat specialized work with a deep knowledge set. Perhaps you aren't paying your IT professional enough?
Good luck,
Eric
"Good God. Are we going to be assaulted with chrome Sanka cans now? " Dranrab Luap
ericrat is offline   Reply With Quote
Old 02-11-2013, 09:16 AM   #15
ericrat
Oddometer: 871
Second thought
A cheap linksys firewall right our of the box would work. Plug the "wan" or "cable modem" side into your office network. I am assuming there is DHCP, etc on that side. Plug your CAD system in the "LAN" side.
The default rules on the linksys should allow outgoing connection, but not allow anything inbound. Map to a folder on one of your office machines and make that the "file repository" for this operation.
Times are GMT -7.   It's 11:31 PM.
