Old 02-09-2013, 12:50 PM   #1
Ricardo Kuhn OP
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,367
Wicked PennyTech shop/garage improvements
Here is a simple example..
You only need a holesaw, some scrap wood and you are set to go, I made holes in three different sizes, "glue tubes" (on the left) spray cans and then holes for bigger size can (not shown)..
I used the retaining wall as the "stop" for the tubes, but you can just use a second piece of wood or even the wall.
All utilizing the "wasted" (angled) space underneath the work bench
I have a few other projects but I need to take pictures of them..
Well share your wonderworks now..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn screwed with this post 02-10-2013 at 09:32 PM
Ricardo Kuhn is offline   Reply With Quote
Old 02-09-2013, 05:53 PM   #2
Ricardo Kuhn OP
Oddometer: 12,367
Okay so my little workshop is kind of strange with a big piece of concrete as one of the corners, the wall is about 3 1/2' tall and about 4' deep so I have from that height to the ceiling to be used for storage..
Note: the first few pictures are old but explain better how the structures where build..
Basically I used the longest drawer slide that I can find (24" long) and set them on the "open" position when the "Cubes" are closed..
And then when the cubes are extend it, the drawer slides hold all the loads.
To help the none supported side of the cube I used ONE Skateboard wheel (No need for two)
I have hold up to about a 100pounds and they slide just fine, the only short coming is the "small" opening do to the length of the drawer slides at 24''
I build 5 of this Cubes, and here is how they look today.
Ricardo Kuhn screwed with this post 02-09-2013 at 07:34 PM
Old 02-09-2013, 10:29 PM   #3
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Here's some drawer slides available up to 28", they're a good price for what they are. They also have drawer slides up to 36" elsewhere on the site, but those get up into the $300 range.
Speaking of drawer slides and shop garage improvements, I have a small garage that is functioning as bike and motorcycle storage as well as a woodworking shop. The one area I could expand out into was the adjacent crawlspace- so I have big plywood boxes that go either 4 or 8 feet (different places) back into the crawlspace, about 3' tall, and 40" wide. The 8 foot box is lumber storage, One 4' box stores all my extra motorcycle wheels at the back, and the front part is my drill press and electrical parts, the other 4' box stores lumber and metals at the bottom, and the top is 28" deep drawers for shop chemicals like oils, paints, solvents, lubricants, etc. It's a work in progress, but it gives me a lot of extra space. I'll get some pictures when I can.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 02-10-2013, 03:17 AM   #4
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Very cool! I love threads like this!
With a little thought, you can make anything you want. Homemade is the best! Good job!
kirkster70 is offline   Reply With Quote
Old 02-10-2013, 05:04 PM   #5
Ricardo Kuhn OP
Oddometer: 12,367
Come on share your projects, I'm sure many of you have custom made things of of necessity and full of clever ideas..
Let see them
Old 02-10-2013, 07:02 PM   #6
Ricardo Kuhn OP
Oddometer: 12,367
Okay here is another one, not as PennyTech but who really cares..
So I have this massive sander and not really a space to place it on the floor, So I got my big ass drill and made two holes on the concrete wall, insert lag bolts (made a mistake measuring first) Then used a big aluminum angle that I got for free.
The problem was to how to make it into a "Cantilever" structure, well easy, first I made a block of wood of the same dimensions as the base of the sander and bolt it all together.
To hold the whole thing together from bending/falling down I just used a 2x4 in compression, yeah is not bolted, glue or anything and is been working great for the last three years since I install it.
But enough about my project, now is time to show your own..
Ricardo Kuhn screwed with this post 02-10-2013 at 08:26 PM
Old 02-15-2013, 03:42 PM   #7
Ricardo Kuhn OP
Oddometer: 12,367
Come on guys 800 views and almost no comments, please share your projects and ideas with the rest of us...
Old 02-15-2013, 03:52 PM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Needed a specific sized shelf, made it out of unistrut, wood and VCT:
Not as creative, or tallented, as Ricky, but it does the job!
Jim
Old 02-15-2013, 04:23 PM   #9
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
at the risk of sounding verrrry stupid, what is VCT? vinyl coated....?
Old 02-15-2013, 04:26 PM   #10
Ricardo Kuhn OP
Oddometer: 12,367
Jim
Thanks for sharing senor Jim, but do remember your garage is really well organize and efficient, when mine is a mess "in progress" (reason why I want to learn more tricks to make it better)
Here is another really simple one.
Old road bike Kevlar tire to make a simple "bike stand" it works great, in fact I have a "real" bike stand that almost never use since this works so well.
Two hooks if I want the bike not to rotate, one hook if I want to spin the bike (normal check ups after riding, etc)
Old 02-15-2013, 04:26 PM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Vynle Composition Tile. Same as I used on my floor, and is commonly used in industrial applications.
Jim
Old 02-15-2013, 04:38 PM   #12
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Ahhhh...so you used a plywood substrate then? Very nice my friend!
Old 02-15-2013, 04:44 PM   #13
Ricardo Kuhn OP
Oddometer: 12,367
Vinyl Composition Tile. Same as I used on my floor, and is commonly used in industrial applications.
Oh I need to do something with my floor one of this days, I try epoxy on on side but I run out of resin..
When it gets a little warmer I'm going to make my self one of this to stand on, more than anything because is fun but also very comfortable.
The Doggies love it I'm sure I will do too.
Many more Pictures HERE
Old 02-15-2013, 04:50 PM   #14
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Thanks! Next time it will be porcelain tile. It is tougher and less maintenance. My goal on the floor was just to make it easier to clean than concrete, and keep the dust down!
Jim
Old 02-15-2013, 04:54 PM   #15
Rafiki
Some Dude
Rafiki's Avatar
Oddometer: 1,875
Fucking awesome re-purpose!!
'94 XR650L ΜΟΛΩΝ ΛΑΒΕ
"Monkey killing Monkey over pieces of ground.
Silly monkeys give them thumbs.
They make a club, And beat their brother down."
Rafiki is offline   Reply With Quote
Times are GMT -7.   It's 05:45 AM.
