Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 02-10-2013, 02:56 PM   #1
TimothyCaseTimothy OP
Oddometer: 501
Jetta GLI Manual Tranny Question/Reverse Problems
Maybe a basic mechanical question, but what the heck...
I have a 2003 Jetta GLI 6 speed that I bought from a gent on this forum a few months ago...seems like intermittently the car does not like to shift into reverse, especially on chilly mornings or after the car has been sitting for a while...
I just figured out a workaround of sorts...if I shift into first and give the motor a bit of gas and then shift into reverse while the motor is coming down in RPMs (from like 3-4k) it'll shift into reverse no problem...
Any tips on what to look at or for, common issues, etc.? Tranny fluid looks good, shifts very smooth after driving for a bit, the rest seems to be smooth as silk...
Thoughts?
Tim
TimothyCaseTimothy screwed with this post 02-11-2013 at 05:22 PM Reason: 2003 Jetta, not 2002 as previously supposed
TimothyCaseTimothy is offline   Reply With Quote
Old 02-10-2013, 03:03 PM   #2
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,321
Doe the clutch seem to engage close to the floor? The clutch slave or master cylinder could be failing. Check the fluid level.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-10-2013, 03:05 PM   #3
Oddometer: 501
Clutch seems like it's traveling normal (down and up)...
Old 02-10-2013, 03:50 PM   #4
Big Bird 928
Oddometer: 2,660
When was the last time the trans oil was changed? almost sounds like it is gumming up if the clutch is working right.
Big Bird 928 is online now   Reply With Quote
Old 02-10-2013, 03:52 PM   #5
It'sNotTheBike
Oddometer: 704
It's probably a maladjusted shift cable
See post #7 in this thread :
http://forums.tdiclub.com/showthread.php?t=195536
Also have a look at this video :
http://www.youtube.com/watch?v=sheTKD03hmo
A bit of trial and error may be required before you get the adjustment dead on.
Don't get discouraged, just keep trying and make small adjustments.
It'sNotTheBike is offline   Reply With Quote
Old 02-10-2013, 03:52 PM   #6
Oddometer: 501
I took it in for an oil change and they said the level was normal and it uses 60 weight, which I guess is common for many cars...
Old 02-10-2013, 04:01 PM   #7
It'sNotTheBike
Oddometer: 704
Transmission gear oil
I've been wrenching on VWs for a bit ( since 1974 ).
As I indicated in my previous post, I suggest that your reverse selection problem
will be solved by the shift cable adjustment, assuming the adjustment is done
correctly.
However it IS also a good idea to change the transmission gear oil. By far the best
stuff to use is the stuff VW sells. I've tried every gear oil you can name and all the
others just don't work as well as the VW "G50" or "G52" stuff. If shifts better when
warm and when cold. It's expensive and it is worth every penny.
The VW parts man will know which gear oil you need if you tell him the year and
model of your car. The stuff costs over $30 per liter but it IS the best. Pay the money
and enjoy the way the transmission shifts. The VW stuff is 100% synthetic and has
a viscosity which lies between Redline MT90 and Redline MTL. But the synchronizers
work a lot better with the VW gear oil than with Redline or other brands.
It'sNotTheBike screwed with this post 02-10-2013 at 04:14 PM
Old 02-10-2013, 04:11 PM   #8
It'sNotTheBike
Oddometer: 704
The correct spec for the gear oil in your car is 75W90 GL4.
It is important to make sure gear oil which meets GL5 spec is NOT used.
Your transmission does NOT use 60 weight. No watercooled VW with a manual transmission
has ever used 60 weight gear oil. If that shop added the wrong oil to your transmission
you need to change the gear oil ASAP.
Lighter or heavier oil will cause poor shifting. Do yourself a favor and buy the
Bentley manual for the car so you can increase your knowledge, and also find a
mechanic who knows VW / Audi cars. Taking VWs to any old garage is often a path
toward the car's useful life being shortened. It is false economy to allow people who
are not expert on VWs to work on your car.
Old 02-10-2013, 04:17 PM   #9
Oddometer: 501
Roger. Any mechanical idea why it would shift into reverse easier while coming down from RPM's in/from first?
Old 02-10-2013, 04:23 PM   #10
It'sNotTheBike
Oddometer: 704
If the above problems were happening shifting into *all* gears would be difficult
because the clutch would not be releasing fully and thus synchronization
of the speeds of the gears in the transmission would be adversely affected,
and gears would tend to "grind" when shifting. The OP did not mention any such
symptoms so I have to assume he really is only having problems shifting into
reverse.
The symptom of reverse being the only gear which is difficult to select points to
a linkage adjustment problem as the most likely cause of poor shifting.
Old 02-10-2013, 04:25 PM   #11
Oddometer: 501
In the morning (cold lately), all of the gears are tough, but are good once down the road a bit and then are very smooth...normal on a cold day?
Old 02-10-2013, 04:39 PM   #12
It'sNotTheBike
Oddometer: 704
There may be a bit of slop relative to a shift fork inside the transmission which
is allowing you to shift more easily into reverse by shifting into first gear beforehand.
The stuff I am talking about is all INSIDE the transmission case and you cannot access
it without disassembling the transmission. Your trick of shifting into first is probably moving
a shift fork just a bit and this is compensating for the shift cables being maladjusted.
The important thing is to get the shift cables adjusted correctly so the transmission
is not being asked to do something which it was not designed to do. I suggest you
watch the video I posted the link for and read the post I linked to and adjust the
cables. If you lack the tools or don't feel comfortable adjusting it yourself, find
a good independent VW shop and pay them to do it. They should not charge more
than .5 hour labor for this job and I suggest you make sure they are willing to
do the adjustment for such a price so you don't get overcharged.
I think if you watch the video and read that post you should be able to do it
yourself, even if you are not "mechanically inclined". Do the adjustment with the car
parked where it doesn't have to be moved suddenly so you have time for trial and error.
I say this because if you go too far in the wrong direction you may find you won't be able
to shift into fifth or sixth gear. The idea is that when the adjustment of the cables is
correct all the gears can be selected easily. By the way unless you "force" the shifter
to go into a gear you cannot do any damage by a trial-and-errror process of adjustment.
If the transmission won't shift easily into a gear, DO NOT force it and shut the engine
off and tweak the cable adjustment again and then start the engine and try to shift again.
It is essential to have the engine running when you test the shifting.
Good luck, and let us know how it goes.
Old 02-10-2013, 04:42 PM   #13
It'sNotTheBike
Oddometer: 704
If you are in Denver as your info indicates, yes it is 100% normal for the shifting to
be stiff on a cold morning. When I say cold I mean when it is below 35 degrees F.
It is also normal for the shifting to become easier and smoother once the engine
and transmission are warmed up. From what I read this is what your car is doing,
so I doubt your transmission has internal problems.
If it is much colder than 35 degrees, then the car will probably shift stiffly for the
first 20 minutes you drive ( assuming you began your drive with a dead-cold engine ).
Parking the car in a heated garage will help the car shift better from a cold start,
but most of us don't have such luxuries ( I sure don't ).
If all the gears other than reverse shift well once your car is warmed up,
the shifting problem is more than likely due to the shift cables being mis-adjusted.
It'sNotTheBike screwed with this post 02-10-2013 at 04:48 PM
Old 02-10-2013, 05:00 PM   #14
Oddometer: 501
Thanks all...I really appreciate it...keep the suggestions coming and I'll report back on Tuesday after my mechanic appointment...currently parked nose out.
Old 02-10-2013, 05:11 PM   #15
It'sNotTheBike
Oddometer: 704
I hope the shop you are going to take your car to has a tech who has experience
adjusting VW / Audi shift cables. It's not rocket science but someone who has done
it before will know exactly what to do and that's always better than someone starting
from zero knowledge.
Thread Tools
Times are GMT -7.   It's 09:07 PM.
