Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 02-10-2013, 05:39 PM   #16
TimothyCaseTimothy OP
Oddometer: 501
It's an Audi/VW mechanic and shop that's done work on my Allroad...
TimothyCaseTimothy is offline   Reply With Quote
Old 02-10-2013, 06:12 PM   #17
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,923
I would tend to think shift cables too, but just for the hell of it:
Start the car, hold the clutch to the floor and shift between all the gears, including reverse. Keep holding the clutch to the floor and shifting for a minute or two. Is it getting harder to engage each gear? That'll tell you if you've got a leaky slave or master cylinder...
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 02-10-2013, 06:16 PM   #18
Oddometer: 501
It doesn't do that for sure...
Old 02-10-2013, 06:56 PM   #19
jdiaz
Oddometer: 32,309
Originally Posted by TimothyCaseTimothy View Post
Maybe a basic mechanical question, but what the heck...
I have a 2002 Jetta GLI 6 speed that I bought from a gent on this forum a few months ago...seems like intermittently the car does not like to shift into reverse, especially on chilly mornings or after the car has been sitting for a while...
I just figured out a workaround of sorts...if I shift into first and give the motor a bit of gas and then shift into reverse while the motor is coming down in RPMs (from like 3-4k) it'll shift into reverse no problem...
My garaged 08 GTI is a little balky into reverse occasionally as well. I put it in 1st gear and rock it forward a couple inches, and then its fine.
jdiaz is offline   Reply With Quote
Old 02-11-2013, 06:21 AM   #20
A-Bone
Indubitably
A-Bone's Avatar
Oddometer: 12,790
Originally Posted by Anorak View Post
Doe the clutch seem to engage close to the floor? The clutch slave or master cylinder could be failing. Check the fluid level.
+1
Put your foot under the clutch pedal and see if you can move it back toward you... Does it move to a higher point and remain there??
A-Bone is online now   Reply With Quote
Old 02-11-2013, 06:45 AM   #21
Oddometer: 501
From what I understand this is a cable clutch...the gods have granted me a co-worker at the firehouse this morning who knows a ton about clutches...stay tuned!
Old 02-11-2013, 06:52 AM   #22
Tallbastid
Let's get tropical
Oddometer: 1,410
If it's anything like my Jeep tranny, the gear oil could be old and not letting the synchros do what they should. I had nearly the same issue at 68k, I change the oil to high quality stuff (Pennzoil Synchromesh), ran it for 50 miles, then changed it again and the problem stopped. Hasn't returned, I continue to change it every 10,000 or so miles, and I'm at 127k. Might be worth a shot before you bring it in?
Tallbastid is online now   Reply With Quote
Old 02-11-2013, 07:02 AM   #23
2ndSPACE
2ndSPACE's Avatar
Oddometer: 1,390
A4 Jetta has a hydraulic clutch. The shift cable adjusters are weak. I would start with adjusting them as previously mentioned.
2ndSPACE is offline   Reply With Quote
Old 02-11-2013, 10:03 AM   #24
Commuter Boy
Oddometer: 2,939
VW claimed they had "lifetime" manual tranny fluid. They don't. It wears out. It evaporates out. And it sure as heck isn't
"60wt".
Change it. The VW stuff is good, but pricey. Those of us in colder climates sometimes prefer the Redline products so we can get a lighter weight in the winter. I run half and half MTL and MT90 year round. It isn't that much cheaper, especially if you get the VW stuff with a good discount.
I typically swap the fluid every 4 years or so when I do the "lifetime" coolant as well.....
Commuter Boy is offline   Reply With Quote
Old 02-11-2013, 12:19 PM   #25
Oddometer: 501
"60wt".
Great to know...thanks!
Old 02-11-2013, 04:52 PM   #26
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,032
If the cable adjustment doesn't help, I'll second changing the fluid. One of my previous cars had a terrible time engaging 1st or reverse in the winter. The colder it got outside, the worse it was. I changed to synthetic MTL and it made an incredible difference.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 02-11-2013, 05:21 PM   #27
Oddometer: 501
Are you saying this car has a hydraulic clutch? BTW, it's a 2003, not 2002 (that's my Audi)...
Sorry for being obtuse and thanks for the input...
Old 02-11-2013, 05:32 PM   #28
jdiaz
Oddometer: 32,309
Clutch operation is hydraulic.
Shift mechanism is via cables.
Old 02-11-2013, 05:40 PM   #29
P B G
Oddometer: 10,001
My car does this (not a VW) and just releasing the clutch and depressing the clutch again usually solves it, with rocking as a back up if it did not.
My last golf was a 90's something, and it had a cable to the clutch arm. Snapped the cable and I drove it home in 3rd.
Old 02-12-2013, 03:34 PM   #30
Oddometer: 501
So...took it to the local VW specialist today...he said the tranny is in good shape, likely doesn't need a new clutch, but thinks that the slave cylinder is on the way out...quoted less than $300 parts and labor...
Appointment next Tuesday....
Thread Tools
Times are GMT -7.   It's 05:52 AM.
